| mwizard1 |
Jul 12 2024, 09:08 AM
Newbie ![]() Group: Members Posts: 22 Joined: 25-May 24 From: N San Diego Co Member No.: 28,148 Region Association: None |
I think I saw somewhere that the lower mount for the front strut could be moved to improve handling. Any info on this?
| brant |
Jul 12 2024, 01:23 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,272 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains
I think I saw somewhere that the lower mount for the front strut could be moved to improve handling. Any info on this? It’s for bump steer purposes That only comes into play if a car is lowered so much that the stock geometry of the suspension is compromised by lowering the car The modification is to correct the compromise of lowering By changing the steering arm On the bottom of the strut I’m less aware of modifications that would move or change Some use offset ball joints when trying to increase negative camber There are other things that can be done My strut housing were sectioned. And with custom race Kori’s that are shorter than stock to give back shock travel on a lowered car Get a performance oriented 4 wheel alignment with tires that are soft. Like 100 treadwear rated. And high end brake pads. You’ll enjoy that for a performance handling |
| mwizard1 |
Jul 13 2024, 08:41 AM
I think I saw somewhere that the lower mount for the front strut could be moved to improve handling. Any info on this? It’s for bump steer purposes That only comes into play if a car is lowered so much that the stock geometry of the suspension is compromised by lowering the car The modification is to correct the compromise of lowering I am building an autocross car so I will be lowering it a lot. Where can I get more info or parts? |
| brant |
Jul 13 2024, 08:51 AM
The steering arm modification is usually done by a shop
It’s the same as what 911 guys do The steering arm is heated and bent Then cooled in vermiculite over a 3-5 day period Another option is to buy a bump steer kit that mounts where the tie rod mounts go |
| stownsen914 |
Jul 13 2024, 09:10 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,029 Joined: 3-October 06 From: Ossining, NY Member No.: 6,985 Region Association: None |
OP may be thinking of raising the spindles on the strut. Depending on your setup, this can help keep the suspension geometry in a favorable range on a very lowered car. Brant may be referring to this in writing about a sectioned strut. The amount to raise the spindle depends how lowered the car is and how large in diameter your wheel/tire are. The modification is usually done by a shop set up to do the work.
| mepstein |
Jul 13 2024, 09:21 AM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,903 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
First learn about suspension setup or get an informed overview from someone who knows what they are doing. Then decide what you want to accomplish and how you plan to do it. Then buy parts, make modifications, etc.
Just doing random things to your car because you heard it might be better is like traveling without a map or destination. |
| technicalninja |
Jul 13 2024, 11:06 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,531 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region
First learn about suspension setup or get an informed overview from someone who knows what they are doing. Then decide what you want to accomplish and how you plan to do it. Then buy parts, make modifications, etc. Just doing random things to your car because you heard it might be better is like traveling without a map or destination. (IMG:style_emoticons/default/agree.gif) Start with small changes first! Learn how to tune what you have... The 914 has a WONDERFUL front upper mount that allows easy suspension adjustments on the fly. First get used to what you already have the ability to do. The lower mount would be one of the last things I'd mess with while learning how to tune my suspension. Now, one mod I have bought already installed in a set of 911 A-arms is this set up. https://www.elephantracing.com/porsche/914/...914/polybronze/ And these https://www.elephantracing.com/porsche/914/...trol-arm-mounts Those self-centering mounts do allow some suspension adjustment. It has to do more with how braking effects the front suspension (you can alter the "anti-dive response") but the changes you can achieve with these are MINOR IMO. Now, I'm also planning on using an adjustable front sway bar and that is a GOOD mod IMO... Like this. https://tarett.com/products/front-swaybar-a...AiABEgKpRvD_BwE That will change the "feel" more than anything else... |
| mwizard1 |
Jul 16 2024, 08:55 AM
Thanks for the info.
| Charles Freeborn |
Jul 16 2024, 09:03 AM
Member ![]() ![]() Group: Members Posts: 344 Joined: 21-May 14 From: United States Member No.: 17,377 Region Association: Pacific Northwest |
Elephant Racing and Tarett are both solid sources for info and parts.
| Krieger |
Jul 20 2024, 10:40 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,879 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None
Tangerine Racing can raise your spindles on the strut and recurve the steering knuckle.
Lo-Fi Version | Time is now: 11th September 2026 - 03:54 PM |
