> Gas tank removal, How to?
mwizard1
post Jul 13 2024, 08:44 AM
I removed the top strap from the gas tank and it still will not come out. Is there an attachment under it?
brant
post Jul 13 2024, 08:55 AM
No attachment below
Sometime they are stuck to the side pads from years /time
Just pull harder
2 bodies can help
post Jul 13 2024, 09:11 AM
Vice grips on the seam helps. Just get one side up/loose then remove the rubber blocks one at a time should come up easily at that point. (IMG:style_emoticons/default/beerchug.gif)
post Jul 13 2024, 09:15 AM
914-6 GT in waiting
Like the guys said, breaking the seal on the rubber pads will release the tank.
mwizard1
post Jul 13 2024, 02:02 PM
QUOTE(mepstein @ Jul 13 2024, 08:15 AM) *
Is there a gas line connection at the botton?
post Jul 13 2024, 03:49 PM
914-6 GT in waiting
QUOTE(mwizard1 @ Jul 13 2024, 04:02 PM) *
Yes, two lines.
mwizard1
post Jul 13 2024, 04:14 PM
QUOTE(brant @ Jul 13 2024, 07:55 AM) *
No attachment below
Just pull harder
2 bodies can help
No problem w/ the fuel line connections as they just pull off but I did need to remove the evaperative apperrastus off the top to get it passed the hood. Thanks for the help.
GregAmy
post Jul 15 2024, 06:18 PM
Hey, pull the pads from the chassis and check for body rust underneath.
Same thing for on the tank where they lied.
Tends to rust due to retention of moisture.
25 User(s) are reading this topic (25 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 31st March 2025 - 05:00 PM
