rosenfe |
Senior Member ![]() ![]() ![]() Group: Members Posts: 564 Joined: 14-October 13 From: northern california Member No.: 16,512 Region Association: None ![]() |
I replaced door switch as I was not getting buzzer or interior lights. I have buzzer key in or out with door open ,still no interior light. No power to light switch. Fuse 11 ok. I’m not sure of correct 4 wire placement in door switch. Anyone have pictures of correct placement?
914_teener |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,245 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California ![]() |
It matters what year to address your question.
before up to 73 and then after 74. I've done this one. The switches on the doors are gounding the circuit(s). Sounds like either the ground side or just the power to the light. I'd make sure the power to the light trace and the fuse panel is wired right and also that the "holder" for the light is nice and tight as the switch is a really bad design. I replaced mine for an led light since the stock light basically was worthless for light. I know there are several threads on this....pretty sure I did one with pictures IIRC. Good luck. |
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,604 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
Power to the light switch comes from a black wire on the junction box beneath the passenger seat. IIRC, there are 2 black wires. The one you need is always HOT. If you have a clock the feed to the auction comes from this circuit. I would suspect something is off on that junction block because you mention the buzzer works. This junction block included the Seat Belt interlock circuit. (IMG:style_emoticons/default/beerchug.gif)
rosenfe |
Power to the light switch comes from a black wire on the junction box beneath the passenger seat. IIRC, there are 2 black wires. The one you need is always HOT. If you have a clock the feed to the auction comes from this circuit. I would suspect something is off on that junction block because you mention the buzzer works. This junction block included the Seat Belt interlock circuit. (IMG:style_emoticons/default/beerchug.gif) My car a 73 does not have a junction box under seat. I believe power goes along tunnel to fuse box. It should be always hot. Not sure how I test where it’s not connected |
Lo-Fi Version | Time is now: 7th September 2024 - 05:32 PM |
