FS New side shift type engine bar mount plate sets, One set with all hardware needed $60 a ser shipped |
bdstone914 |
Jul 18 2024, 09:04 PM
bdstone914 Group: Members Posts: 4,744 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Edit. One set left.
I have three sets left of these plate sets. The side shift engine bar mounts to these plates which bolt to the engine mount console. They are made of thicker steel and yellow zinc plated. Most used sets are bent from lifting the car from the engine bar. $60 a set shipped. Attached thumbnail(s) |
Tabsocal |
Jul 18 2024, 10:08 PM
Newbie Group: Members Posts: 1 Joined: 25-September 23 From: Southern California Member No.: 27,608 Region Association: Southern California |
Put me down for a set with the bolts. I’ll pick them up when the other parts are done if that works Bruce.
Troy |
bdstone914 |
Jul 19 2024, 02:01 AM
@Tabsocal
date='Jul 18 2024, 09:08 PM' post='3157420'] Put me down for a set with the bolts. I’ll pick them up when the other parts are done if that works Bruce. Troy [/quote] Sure. The fog light brackets will be done Tuesday. The washers are coming in from China so i do not have a firm date yet. |
seanpaulmc |
Jul 19 2024, 02:24 PM
Member Group: Members Posts: 375 Joined: 6-December 16 From: Orlando, FL Member No.: 20,649 Region Association: South East States |
I will take a set without bolts,
Thanks |
bdstone914 |
Jul 19 2024, 05:55 PM
@seanpaulmc
' date='Jul 19 2024, 01:24 PM' post='3157497'] I will take a set without bolts, Thanks [/quote] PM sent |
Garland |
Jul 20 2024, 07:36 AM
Restoration Fanatic Group: Members Posts: 1,400 Joined: 8-January 04 From: ......Michigan...... Member No.: 1,535 Region Association: Upper MidWest |
PM sent
bdstone914 |
Sep 4 2024, 08:31 PM
Bump.
Have several pair left. |
seanpaulmc |
Sep 9 2024, 02:22 PM
bdstone914 |
Sep 9 2024, 05:54 PM
Your welcome. I made them as almist every pair i have removed from a car were in bad shape.
I have several more pairs if anyone needs them. |
bdstone914 |
Sep 19 2024, 06:44 PM
Bump
JeffBowlsby |
Sep 19 2024, 08:02 PM
914 Wiring Harnesses Group: Members Posts: 8,806 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
I’ll take a set with bolts Bruce.
Puebloswatcop |
Sep 20 2024, 05:49 AM
Senior Member Group: Members Posts: 1,417 Joined: 27-December 14 From: Mineola, Texas Member No.: 18,258 Region Association: Southwest Region |
Good Morning Bruce,
If you have a set with Bolts left, I'd like a set Thanks |
bdstone914 |
Sep 20 2024, 06:32 AM
bdstone914 |
DC_neun_vierzehn |
Sep 21 2024, 12:36 PM
Member Group: Members Posts: 492 Joined: 16-November 20 From: Delaware Shore Member No.: 24,893 Region Association: MidAtlantic Region |
Lo-Fi Version | Time is now: 15th January 2025 - 01:21 AM |
