brant |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,708 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains ![]() ![]() ![]() |
Does anyone have a trick to help this job
Trying to put the springs back into the bottom of the shifter Attached thumbnail(s) ![]() |
technicalninja |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,807 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region ![]() ![]() |
I'll sometimes use a skinnier rod/screwdriver to act as a guide before I try to install the pins.
I'll get it skewered up like a shish kabob first on all springs. Phillips work best for me, pointy ends and all... |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,480 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
First, always wear eye protection
Use a Phillips screwdriver on one end and hold the spring with a pair of vice grips. Get the spring set in place with the vice grips and then replace the screwdriver with the pin. Takes minutes when you get it right. |
technicalninja |
Gloves are not a bad idea either. I've skewered myself a number of times... |
brant |
Thanks everyone!!!
I’ll give it a shot |
bkrantz |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,004 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains ![]() ![]() |
Good luck. Sorry, but I do not remember how I did it--but I did get it done.
brant |
Worked. !!!!!
No stab wounds and both eyes intact I didn’t remember how I had done it 25 years ago |
Lo-Fi Version | Time is now: 7th September 2024 - 05:55 PM |
