| ILM914 |
Aug 2 2024, 02:18 PM
Member ![]() ![]() Group: Members Posts: 104 Joined: 3-March 09 From: NC Member No.: 10,126 Region Association: None |
Hi folks I have 74 2.0 car with original fuel injection. I'm looking for the metal fittings that come out of the bottom of the fuel tank part # 91420104110 and 91420104310 . I have the nuts but I need the gasgets too - I think I might be able to still buy the gaskets? Thank you guys
| bdstone914 |
Aug 2 2024, 03:21 PM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,216 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Hi folks I have 74 2.0 car with original fuel injection. I'm looking for the metal fittings that come out of the bottom of the fuel tank part # 91420104110 and 91420104310 . I have the nuts but I need the gasgets too - I think I might be able to still buy the gaskets? Thank you guys I have the tubes. Does your tank use one large and one small? I have oaper gaskets i make by hand Bruce |
| ILM914 |
Aug 2 2024, 04:53 PM
Thank you , the nuts do have different size holes from each other , also do have a place/brand you recommend to purchase a fuel pump? thank you again
| bdstone914 |
Aug 2 2024, 07:06 PM
@ILM914
date='Aug 2 2024, 03:53 PM' post='3159946'] Thank you , the nuts do have different size holes from each other , also do have a place/brand you recommend to purchase a fuel pump? thank you again [/quote] This should be what you need. The original fuel pumps are expensive and available. You can convert to a two port pump but it requires some adapting. The regular suppliers carry them. Attached thumbnail(s) |
| pglotzbecker |
Oct 17 2024, 02:57 PM
Newbie ![]() Group: Members Posts: 1 Joined: 17-October 24 From: Cincinnati, Ohio Member No.: 28,420 Region Association: Upper MidWest |
I have been searching high and low for these fittings, do you have anymore?
| 914werke |
Oct 17 2024, 04:40 PM
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,483 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest
I have them as well.
| pglotzbecker |
Oct 17 2024, 05:25 PM
Thank you! Just got them off your site.
Newbie here and this forum is a wonderful community. |
| 9146-racer |
Dec 15 2025, 12:45 PM
Newbie ![]() Group: Members Posts: 29 Joined: 4-September 20 From: hampshire uk Member No.: 24,659 Region Association: None |
Hi Bruce do you have any of the below ? are you willing to ship to UK ?
Thanks Ian ian9146@gmail.com 91420189310 gasket 2 111209147A Filter 2 311201235A Gasket 2 91420114710 Gasket 2 91420104110 Pipe 2 91420104310 Pipe 2 311201231A Union nut 2 91420115310 Union nut 2 |
| bdstone914 |
Dec 15 2025, 10:16 PM
Hi Bruce do you have any of the below ? are you willing to ship to UK ? Thanks Ian ian9146@gmail.com 91420189310 gasket 2 111209147A Filter 2 311201235A Gasket 2 91420114710 Gasket 2 91420104110 Pipe 2 91420104310 Pipe 2 311201231A Union nut 2 91420115310 Union nut 2 Email sent. I should have all if those parts. Bruce |
Lo-Fi Version | Time is now: 17th December 2025 - 11:30 PM |
