Battery Voltage Low - most likely culprit?, Does not start well when warm |
Chaznaster |
Sep 9 2024, 04:51 PM
Member Group: Members Posts: 325 Joined: 22-November 15 From: Concord, MA Member No.: 19,389 Region Association: North East States |
I got back to the car today and retook measurements after ensuring it was completely warmed up.
850-900 RPM D+ = 0.80 D- = 0 DF = 0.61 Batt = 12.2 1000 RPM D+ = 12.3 D- = 0 DF = 6.5 Batt = 12.4 1400 RPM D+ = 13.7 D- = 0 DF = 5.0 Batt = 13.3 2000 RPM D+ = 13.3 D- = 0 DF = 3.3 Batt = 13.2 If I go to 1400 then back down to 850, The numbers come back down. So no alternator output at low levels ... does that point to a rebuild? Many thanks. |
rhodyguy |
Sep 9 2024, 05:44 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,193 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Starts fine when cold? When it’s hot it still spins up, just won’t catch? Have you considered hot fuel? When you are starting when hot, are you touching the gas pedal? My car (Webers) stumbles at startup when hot. 3 pedal pumps then feathering the pedal. You have to get those throttle plates open. Things calm down when the carbs are full of fresh tank fuel. Actually it’s only a few seconds. Are you using phenolic spacers/gaskets on the intake bases? I thought the voltage numbers were more about what the ‘brain’ needed to function.
emerygt350 |
Sep 9 2024, 05:50 PM
Advanced Member Group: Members Posts: 2,511 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
You want 13.5 at idle. After I switched to a modern VR I get 13.7 at idle and 13.7 at whatever rpm you like. At the battery. When you have to turn your wipers on and your heater blower and your cool air blower and your headlights you don't want to be wondering about your battery.
Spoke |
Sep 9 2024, 07:55 PM
Jerry Group: Members Posts: 7,104 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
I got back to the car today and retook measurements after ensuring it was completely warmed up. 850-900 RPM D+ = 0.80 D- = 0 DF = 0.61 Batt = 12.2 1000 RPM D+ = 12.3 D- = 0 DF = 6.5 Batt = 12.4 1400 RPM D+ = 13.7 D- = 0 DF = 5.0 Batt = 13.3 2000 RPM D+ = 13.3 D- = 0 DF = 3.3 Batt = 13.2 If I go to 1400 then back down to 850, The numbers come back down. So no alternator output at low levels ... does that point to a rebuild? Many thanks. @Chaznaster When you go from 1400 to 850, does D+ go back to 0.6V? D+ at 0.6V means the alternator is not running. One other test to do is the D+ to DF short with VR pulled. Check D+ and VBATT at 850, 1400, 2k. Do them quick since D+ shorted to DF is maximum output. I would want to know if the alternator can work at 850. |
Chaznaster |
Sep 10 2024, 06:11 PM
Starts fine when cold? When it’s hot it still spins up, just won’t catch? Have you considered hot fuel? When you are starting when hot, are you touching the gas pedal? My car (Webers) stumbles at startup when hot. 3 pedal pumps then feathering the pedal. You have to get those throttle plates open. Things calm down when the carbs are full of fresh tank fuel. Actually it’s only a few seconds. Are you using phenolic spacers/gaskets on the intake bases? I thought the voltage numbers were more about what the ‘brain’ needed to function. It starts great cold and most of the time hot. I have a single, central Weber 32/36. It is not over the heads so should not get excessively hot. I am running the spacers, as well, just in case. I usually give it a single pump on the throttle to reset to fast idle. When it does start it comes right to life. |
Chaznaster |
Sep 10 2024, 06:13 PM
I got back to the car today and retook measurements after ensuring it was completely warmed up. 850-900 RPM D+ = 0.80 D- = 0 DF = 0.61 Batt = 12.2 1000 RPM D+ = 12.3 D- = 0 DF = 6.5 Batt = 12.4 1400 RPM D+ = 13.7 D- = 0 DF = 5.0 Batt = 13.3 2000 RPM D+ = 13.3 D- = 0 DF = 3.3 Batt = 13.2 If I go to 1400 then back down to 850, The numbers come back down. So no alternator output at low levels ... does that point to a rebuild? Many thanks. @Chaznaster When you go from 1400 to 850, does D+ go back to 0.6V? D+ at 0.6V means the alternator is not running. One other test to do is the D+ to DF short with VR pulled. Check D+ and VBATT at 850, 1400, 2k. Do them quick since D+ shorted to DF is maximum output. I would want to know if the alternator can work at 850. When I go from 1400 to 850 D+ does go back to 0.6V. And back up upon returning to 1400. I'll try the next test and get back as soon as I have some more numbers. As always - thanks. EDIT: This might not make any sense, but could the belt be slipping at low engine speeds. I would think that would happen when fast ... |
iankarr |
Sep 10 2024, 11:52 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,526 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
Just dealt with this on my green car. Replaced the VR and battery and running 13.5-13.7 all the time now.
Spoke |
Sep 11 2024, 06:53 AM
When I go from 1400 to 850 D+ does go back to 0.6V. And back up upon returning to 1400. EDIT: This might not make any sense, but could the belt be slipping at low engine speeds. I would think that would happen when fast ... That is weird that going from 1400 to 850 causes the alternator to turn off. Usually once the alternator is bootstrapped it keeps on running. BTW, when at 850 and V+ = 0.6V, is the GEN light on? About the belt, it should be tight. Is it? |
Chaznaster |
Sep 12 2024, 04:37 PM
Chaznaster |
Sep 12 2024, 04:38 PM
When I go from 1400 to 850 D+ does go back to 0.6V. And back up upon returning to 1400. EDIT: This might not make any sense, but could the belt be slipping at low engine speeds. I would think that would happen when fast ... That is weird that going from 1400 to 850 causes the alternator to turn off. Usually once the alternator is bootstrapped it keeps on running. BTW, when at 850 and V+ = 0.6V, is the GEN light on? About the belt, it should be tight. Is it? At 850 the gen light is flickering. It goes out as soon as I rev the engine. I'll check the loose belt and do other tests this weekend. I recently had the engine out and pulled the alternator / replaced and tensioned the belt but maybe I did not get it right ... |
Chaznaster |
Sep 17 2024, 02:48 PM
So ... I feel a bit foolish about this ... the cause of the wonky alternator voltages was a loose fan belt. Must have been slipping at lower engine speeds.
Thanks to all for all the help, as always. Special thanks to @Spoke for walking me through the diagnostics. Now we will see whether we still have a hard start when warm. |
emerygt350 |
Sep 18 2024, 01:16 PM
So ... I feel a bit foolish about this ... the cause of the wonky alternator voltages was a loose fan belt. Must have been slipping at lower engine speeds. Thanks to all for all the help, as always. Special thanks to @Spoke for walking me through the diagnostics. Now we will see whether we still have a hard start when warm. Don't feel bad, happened to me after I rebuilt my engine. I freaked out for a couple days and then realized I was hearing some strange sounds... |
Lo-Fi Version | Time is now: 22nd December 2024 - 05:26 AM |
