Puck for the horn, want dimensions |
worn |
Sep 4 2024, 07:24 PM
can't remember Group: Members Posts: 3,376 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
emerygt350 |
Sep 5 2024, 11:18 AM
Advanced Member Group: Members Posts: 2,523 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
Ishley |
Sep 5 2024, 01:48 PM
Member Group: Members Posts: 180 Joined: 4-October 21 From: Clarendon Hills Il Member No.: 25,957 Region Association: Upper MidWest |
I was wondering if a groove in the top would allow to fit a thin piece of polished aluminum for a more original look. I groove like 6MM wide.
emerygt350 |
Sep 5 2024, 01:59 PM
I was wondering if a groove in the top would allow to fit a thin piece of polished aluminum for a more original look. I groove like 6MM wide. That would be another way of doing it. I was going to use spray chrome on that ring. I think it might be pretty difficult to find the right kind of chrome piece to make it look good. I wish I could figure out how to print a leather texture on that portion and then I would reverse that Porsche emblem so it was a cavity rather than standing proud. |
Ishley |
Sep 5 2024, 02:23 PM
I’d cut the circle on a bandsaw and do the inside with a hole saw. Grind it to fit perfectly and then polish it with polishing compound to get it to a chrome finish.
worn |
Sep 5 2024, 05:23 PM
emerygt350 |
Sep 5 2024, 06:05 PM
The rabbit hole is deep... I am now learning how to do the leather surface....
emerygt350 |
Sep 6 2024, 10:14 AM
worn |
Sep 6 2024, 11:42 AM
emerygt350 |
Sep 6 2024, 03:55 PM
This stuff is black magic. Makes me have a ton more respect for the people that make those cgi movies like Shrek.
Ishley |
Sep 6 2024, 05:39 PM
I contacted a friend of mine who does printing… and he ran the first model you published. He said he stopped and changed the wire to silver when it got to the logo portion.
I haven’t physically seen it yet… but I thought you’d be interested in this variation. Attached image(s) |
emerygt350 |
Sep 6 2024, 06:02 PM
That is really nice. I should update the files with the new one. I have been running into issues on my machine. Research students damaged the membrane on the uv printer ....
emerygt350 |
Sep 7 2024, 09:55 AM
emerygt350 |
Sep 13 2024, 07:07 AM
burton73 |
Sep 13 2024, 12:45 PM
burton73 Group: Members Posts: 3,700 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
This is a real early 911 horn button on my 6. To get it to look like this, you need the good leather and some padding behind it. Fully restored on chrome and plastic by PMB
Best Bob B |
emerygt350 |
Sep 13 2024, 01:25 PM
emerygt350 |
Sep 13 2024, 03:41 PM
This is a real early 911 horn button on my 6. To get it to look like this, you need the good leather and some padding behind it. Fully restored on chrome and plastic by PMB Best Bob B That picture gives me a good idea of the diameter compared to the wheel. I thought mine was a little narrow but I looks like there is a visible edge on the wheel under the puck. |
sixnotfour |
Sep 14 2024, 09:45 AM
914 Wizard Group: Members Posts: 10,692 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
Worn has an actual piece he did dimensioning off..
Ya I polished my og ring, shiny brass.. Attached thumbnail(s) |
Sep 14 2024, 10:53 AM
914-6 GT in waiting Group: Members Posts: 19,669 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
This is a real early 911 horn button on my 6. To get it to look like this, you need the good leather and some padding behind it. Fully restored on chrome and plastic by PMB Best Bob B That picture gives me a good idea of the diameter compared to the wheel. I thought mine was a little narrow but I looks like there is a visible edge on the wheel under the puck. Yes, it needs a bit of room so it can function as a horn button. It’s doing the same thing as a batwing and moving a bit to make contact for the horn to work |
emerygt350 |
Sep 23 2024, 10:46 AM
I have uploaded the most recent version. I have been having issues printing it so I haven't been able to test fitment but I figured uploading the stl wouldn't hurt.
https://www.thingiverse.com/thing:6238862 |
Lo-Fi Version | Time is now: 2nd January 2025 - 07:10 AM |
