> Solvent HELP, Cannot find solvent to dissolve adhesive
Gatornapper
post Sep 3 2024, 06:31 PM
I love the black leather Dino steering wheel that is on my 944 S.
I want to put it on my 914.
So I got a tan Dino steering wheel to go in my 944 S that has a tan interior.
One problem - I can find no solvent to remove the adhesive from the new tan steering wheel. It had clear plastic protecting the chrome which pulled off easily. But I can find no solvent to dissolve the adhesive that held the clear plastic on.
I have tried gasoline, strong carb cleaner, brake cleaner, acetone, lacquer thinner, WD-40,
Seafoam, and even Super Glue Remover.
I can't take the nice wheel out of the 944 S until the new one can go in.
HELP. Looking for advice on a solvent that will dissolve this adhesive.
Pics below - many thanks to all suggestions.
GN
(IMG:http://www.914world.com/bbs2/uploads_offsite/hosting.photobucket.com-21449-1725409879.1.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/hosting.photobucket.com-21449-1725409879.2.JPG)
JeffBowlsby
post Sep 3 2024, 06:38 PM
914 Wiring Harnesses
Tried Goof Off? Or Goo Gone? They seem to be a mixture of several solvents, maybe something in them will work.
technicalninja
post Sep 3 2024, 06:48 PM
Another member found the orange citrus hand cleaner worked well on ancient back pad glue in the 914.
Might be worth a try...
Gatornapper
post Sep 3 2024, 07:00 PM
Jeff -
My BAD. Yes I did. Didn't touch it. Forgot to add that to my list.
GN
QUOTE(JeffBowlsby @ Sep 3 2024, 06:38 PM) *
Gatornapper
post Sep 3 2024, 07:01 PM
Great idea!
Have some on hand - will try it!
Thanks!
GN
QUOTE(technicalninja @ Sep 3 2024, 06:48 PM) *
IronHillRestorations
post Sep 3 2024, 07:19 PM
I. I. R. C.
Denatured alcohol? Lighter fluid? Acetone? The hotter the solvent the more risky it can be for collateral damage.
dhuckabay
post Sep 3 2024, 07:21 PM
Have had good luck with Xylol or Xylene, one in the same. Home Depot has it. Really good also for removing tar and undercoating without damage to the paint.
Gatornapper
post Sep 3 2024, 07:31 PM
Acetone did'nt touch it.
The Citris seemed to cut it some, but now much - but the pumice in the cleaner didn't do the chrome any favors...... (IMG:style_emoticons/default/sad.gif)
Dawn dishsoap seemed to cut it some but not without tons of scrubbing & elbow grease.
But still wouldn't get it all off...
QUOTE(IronHillRestorations @ Sep 3 2024, 07:19 PM) *
Spoke
post Sep 3 2024, 07:36 PM
Jerry
I use naphtha to dissolve glue.
bkrantz
post Sep 3 2024, 08:23 PM
3M Adhesive Remover.
(adhesive remover is right in the name. (IMG:style_emoticons/default/piratenanner.gif) )
KELTY360
post Sep 3 2024, 08:35 PM
914 Neferati
I’ve used lighter fluid with success. Good luck finding an answer.
worn
post Sep 3 2024, 09:18 PM
can't remember
QUOTE(KELTY360 @ Sep 3 2024, 07:35 PM) *
You have exhausted the non-polar solvent approach. Perhaps something like rubbing alcohol or denatured ethanol will do the trick. Not sure about the underlying aluminum, but ammonia might also work. Lately I have found that a single edge razor blade held perpendicular to the surface can make a pretty controllable scraper blade. Good luck! I like your choice of steering wheel.
Ishley
post Sep 3 2024, 09:20 PM
Toluene is a good chemical to clean adhesives. You can also try heat from a heat
Gun. Slowly heat the area and be careful not to damage anything. Most glues and epoxies will breakdown with heat.
Superhawk996
post Sep 3 2024, 10:15 PM
If it were me, I would contact seller and/or manufacturer and see what they recommend or exchange/refund it.
That’s unacceptable to have an adhesive like that on a show surface. (IMG:style_emoticons/default/headbang.gif)
Gatornapper
post Sep 4 2024, 07:00 AM
First thing I did was ask seller - he was clueless.
Thanks to all for the suggestions.
Pumice in the Orange/citrus cleaner scratched the chrome - my bad again.
Slowly coming off with Dawn dish soap, but not all will come off even with tons of hard rubbing.....
GN
QUOTE(Superhawk996 @ Sep 3 2024, 10:15 PM) *
Gatornapper
post Sep 4 2024, 07:01 AM
Might I find this at Advance Auto or Autozone?
Thanks!
GN
QUOTE(bkrantz @ Sep 3 2024, 08:23 PM) *
krazykonrad
post Sep 4 2024, 07:03 AM
QUOTE(bkrantz @ Sep 3 2024, 06:23 PM) *
technicalninja
post Sep 4 2024, 08:24 AM
Sorry bout the pumice!
Often times heat can help.
Now, don't use so much heat it jacks with the leather/padding.
I've used adhesive remover many times as well.
Not sure if you've tried alcohol yet, probably won't help (because of the stronger stuff you've already tried) but cannot hurt.
I use GALLONS of the stuff, but it is more for flushing stronger chemicals out of an AC system then actual trash.
Alcohol evaporates leaving nothing behind. I call it "medically clean".
post Sep 4 2024, 08:42 AM
https://www.amazon.com/3M-03618-Adhesive-Re...z/dp/B000BQYA7W
dr914@autoatlanta.com
post Sep 4 2024, 08:54 AM
3m makes commercial body shop adhesive remover. You could also use lacquer thinner if all else fails!
- Lo-Fi Version Time is now: 21st December 2024 - 07:03 AM
