Pedal Cluster Rubber Base Mat, Part Number or Material Source |
DennisV |
Sep 5 2024, 07:10 AM
Senior Member Group: Members Posts: 543 Joined: 8-August 20 From: Santa Rosa, CA Member No.: 24,575 Region Association: Northern California |
Does anyone recognize this thin rubber mat found under the pedal cluster that can offer a part number? Ours is breaking down.
I looked in the PDF parts catalog and searched on vendor sites but can't find a part number. Alternatively, is there a material source that I can cut my own? Thank you. |
bdstone914 |
Sep 5 2024, 07:17 AM
bdstone914 Group: Members Posts: 4,693 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Does anyone recognize this thin rubber mat found under the pedal cluster that can offer a part number? Ours is breaking down. I looked in the PDF parts catalog and searched on vendor sites but can't find a part number. Alternatively, is there a material source that I can cut my own? Thank you. I recently pulled the pedal cluster on a low mile car and did not see anything like that under the cluster. When you install the cluster put some sealant around the studs that go through the firewall. It prevents wayer entry which is why clusters rust out on the bottom. Porsche started doing that on 1978 911"s |
dr914@autoatlanta.com |
Sep 5 2024, 09:18 AM
914 Guru Group: Members Posts: 8,092 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
nothing the factory installed
Does anyone recognize this thin rubber mat found under the pedal cluster that can offer a part number? Ours is breaking down. I looked in the PDF parts catalog and searched on vendor sites but can't find a part number. Alternatively, is there a material source that I can cut my own? Thank you. |
914Sixer |
Sep 5 2024, 09:31 AM
914 Guru Group: Members Posts: 9,004 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Probably installed when pedal cluster rebuilt? Rust control?
Craigers17 |
Sep 5 2024, 10:04 AM
Senior Member Group: Members Posts: 795 Joined: 5-August 17 From: Rome, GA Member No.: 21,317 Region Association: South East States |
When I pulled the pedal cluster out of a 74" that I used to have, this was several years ago, there was a piece under the pedal cluster as well. I have attached a couple of pics, and even though it looks like it's metal, if I recall correctly, it too was made of a rubbery compound. (in the pic, it looks suspiciously like the piece of metal that was removed for the master cylinder hole, but they weren't the same size.
The reason I believe it was made of rubber(even though it looks rusty), is that I replaced it with a couple of sheets of "Flex Tape". You can see on the floorboard where it sat beneath the pedal cluster. I cannot say for certain that the pedal cluster had never been removed, but it sure looked original. |
914werke |
Sep 5 2024, 10:13 AM
"I got blisters on me fingers" Group: Members Posts: 10,777 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
When you install the cluster put some sealant around the studs that go through the firewall. It prevents water entry which is why some clusters rust out on the bottom. Porsche started doing that on 1978 911"s |
friethmiller |
Sep 5 2024, 12:48 PM
Senior Member Group: Members Posts: 649 Joined: 10-February 19 From: Austin, TX Member No.: 22,863 Region Association: Southwest Region |
DennisV |
Oct 20 2024, 07:50 PM
When you install the cluster put some sealant around the studs that go through the firewall. It prevents wayer entry which is why clusters rust out on the bottom. Porsche started doing that on 1978 911"s What is the recommended sealant? Presumably Porsche used something from Wurth? I removed the rubber pad and did some wire wheel action on the visible rust. Some more surprises. Like @Craigers17 I have an odd circular area which looks like someone tried to seal it. |
Craigers17 |
Oct 21 2024, 04:16 AM
When you install the cluster put some sealant around the studs that go through the firewall. It prevents wayer entry which is why clusters rust out on the bottom. Porsche started doing that on 1978 911"s What is the recommended sealant? Presumably Porsche used something from Wurth? I removed the rubber pad and did some wire wheel action on the visible rust. Some more surprises. Like @Craigers17 I have an odd circular area which looks like someone tried to seal it. @DennisV The "disk" in my hand in my post was sitting right in the area that you have circled in red. I wonder if you clean up that sealant what you find under it ...if anything. |
doug_b_928 |
Oct 21 2024, 10:43 AM
Senior Member Group: Members Posts: 704 Joined: 17-January 13 From: Winnipeg Member No.: 15,382 Region Association: Canada |
Based on my impression when I removed my pedal cluster (many years ago), I think the factory laid down some seam sealer, then set the round disc thingy in place and then installed the pedal cluster to compress everything. That way the sealer cured with everything in position. That’s how I’m going to do it when I reinstall mine.
DennisV |
Oct 22 2024, 06:08 AM
The "disk" in my hand in my post was sitting right in the area that you have circled in red. I wonder if you clean up that sealant what you find under it ...if anything. Ours has the disc and half round cut-out too. What is the proper way to reinstall? Here is a shot from below. What the hell was the purpose of this? |
Craigers17 |
Oct 22 2024, 07:23 AM
Sorry, but I’m not sure of the exact placement or procedure to re-install. I think I put the disk back in and covered it with a couple strips of thick flex tape, but it’s been a while, and I sold that car a couple years ago. I consider myself the village idiot in these matters, so I would consult others.
Superhawk996 |
Oct 22 2024, 08:36 AM
914 Guru Group: Members Posts: 6,492 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
“ What the hell was the purpose of this?”
Drain hole for when the body went though dip tanks prior to paint. |
Craigers17 |
Oct 22 2024, 09:18 AM
Just for shits and grins.....a few pics from my old car of that area after I cleaned it up a bit:
Superhawk996 |
Oct 22 2024, 09:32 AM
Doh! Accidental post
DennisV |
Oct 23 2024, 01:22 PM
“ What the hell was the purpose of this?” Drain hole for when the body went though dip tanks prior to paint. I could see the half-circle cut out helping with that. Why the underside ring and channel? Is this also part of the drainage mechanism? I'm guessing the cars were vertical dip and remove in 1970, not flipped over like cars today. |
Lo-Fi Version | Time is now: 25th October 2024 - 06:00 PM |
