The Case of Disappearing Oil, What happened to the oil level? |
VaccaRabite |
Sep 24 2024, 05:45 AM
En Garde! Group: Admin Posts: 13,636 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
If the oil light went on during a longer corner, it could totally be oil sloshing away from the pickup. It is not challenging to do that in a 914 - I did it myself this summer at the Northeast Gathering during a long fast sweeper. BUT - if the oil pressure loss happened on a straight road or a slight bend, sloshing isn't your answer.
And, the oil HAD to go somewhere. Burning a quart of oil in an afternoon is pretty excessive. Likewise you would see signs of a leak all over the top or bottom of your motor. Have you looked at the bottom of your engine? Is it coated in oil? Zach |
DrinkMan |
Sep 24 2024, 07:37 AM
Member Group: Members Posts: 63 Joined: 25-February 17 From: Hoschton, GA Member No.: 20,872 Region Association: South East States |
If the oil light went on during a longer corner, it could totally be oil sloshing away from the pickup. It is not challenging to do that in a 914 - I did it myself this summer at the Northeast Gathering during a long fast sweeper. BUT - if the oil pressure loss happened on a straight road or a slight bend, sloshing isn't your answer. And, the oil HAD to go somewhere. Burning a quart of oil in an afternoon is pretty excessive. Likewise you would see signs of a leak all over the top or bottom of your motor. Have you looked at the bottom of your engine? Is it coated in oil? Zach No excessive oil on the bottom of the engine. When we pulled over, at least 3 people looked and could not find anything. The oil light never came on, i reacted to the cabin gauge. Part of the issue is the sloshing but where the oil went is still a mystery. No blue smoke except occasional puffs when shifting (we were in a line of 914's all day and had witnesses). And we still have not lost a drop since the incident (3 tanks of gas ago). I think the pump starving and low pressure was definitely slosh but being that low is unsolved. I'm almost done with the TR6 (yesterday we discovered that rear SU carb piston was sticking and that the heat shield was interfering with the linkage synchronization so now we are in final mode of buttoning it up and the only thing left is a much worse hot restart discovered during the test drive. It has always had a small hot restart issue but after fixing the piston and heat shield, it has gotten worse. We should be able to finish that today) and we have 914 parts coming in (including a new mechanical oil pressure gauge that we will replace the engine mounted one) so we can put the 914 on the lift and get to it this evening or tomorrow. One of the funny things during this is when we were at our rental cabin, every morning we would move the car and study the gravel to see if anything dripped. One time, my wife found some stained gravel and picked it up and smelled it - not oil. I told her that only true gearhead smell gravel to determine what dripped. |
930cabman |
Sep 26 2024, 04:49 PM
Advanced Member Group: Members Posts: 3,834 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
If the oil light went on during a longer corner, it could totally be oil sloshing away from the pickup. It is not challenging to do that in a 914 - I did it myself this summer at the Northeast Gathering during a long fast sweeper. BUT - if the oil pressure loss happened on a straight road or a slight bend, sloshing isn't your answer. And, the oil HAD to go somewhere. Burning a quart of oil in an afternoon is pretty excessive. Likewise you would see signs of a leak all over the top or bottom of your motor. Have you looked at the bottom of your engine? Is it coated in oil? Zach No excessive oil on the bottom of the engine. When we pulled over, at least 3 people looked and could not find anything. The oil light never came on, i reacted to the cabin gauge. Part of the issue is the sloshing but where the oil went is still a mystery. No blue smoke except occasional puffs when shifting (we were in a line of 914's all day and had witnesses). And we still have not lost a drop since the incident (3 tanks of gas ago). I think the pump starving and low pressure was definitely slosh but being that low is unsolved. I'm almost done with the TR6 (yesterday we discovered that rear SU carb piston was sticking and that the heat shield was interfering with the linkage synchronization so now we are in final mode of buttoning it up and the only thing left is a much worse hot restart discovered during the test drive. It has always had a small hot restart issue but after fixing the piston and heat shield, it has gotten worse. We should be able to finish that today) and we have 914 parts coming in (including a new mechanical oil pressure gauge that we will replace the engine mounted one) so we can put the 914 on the lift and get to it this evening or tomorrow. One of the funny things during this is when we were at our rental cabin, every morning we would move the car and study the gravel to see if anything dripped. One time, my wife found some stained gravel and picked it up and smelled it - not oil. I told her that only true gearhead smell gravel to determine what dripped. picked it up and smelled it - not oil Now that's a real keeper (IMG:style_emoticons/default/cheer.gif) |
type2man |
Sep 26 2024, 08:23 PM
Member Group: Members Posts: 355 Joined: 3-March 09 From: Miami, Fl Member No.: 10,127 Region Association: South East States |
You need to fill it up past the dipstick line. It is not going to hurt anything except maybe the breathers will blow out the excess oil. Better safe than sorry. An easy way to tell if youre burning excess oil is to stick your finger in the tailpipe and swirl it around. Then try to remove the black soot from your finger with your other hand. If its still black, youre burning. Do the same with the new car in your driveway and youll see what I mean.
DrinkMan |
Sep 26 2024, 08:43 PM
You need to fill it up past the dipstick line. It is not going to hurt anything except maybe the breathers will blow out the excess oil. Better safe than sorry. An easy way to tell if youre burning excess oil is to stick your finger in the tailpipe and swirl it around. Then try to remove the black soot from your finger with your other hand. If its still black, youre burning. Do the same with the new car in your driveway and youll see what I mean. You assume we have a new car. Everything is over 15 years old. It's parked next to the Elise. I'll compare the two. |
JamesM |
Sep 26 2024, 10:13 PM
Advanced Member Group: Members Posts: 2,032 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
As for where did the oil go It probably burned (IMG:style_emoticons/default/agree.gif) Going to guess you were driving more "spirited" while out with the boys than you normally would, more sustained time at higher RPM and loading it up. Oil went out the crankcase vent as vapor |
Geezer914 |
Sep 27 2024, 04:08 AM
Geezer914 Group: Members Posts: 1,819 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States |
If he burned 1-1 1/2 quarts of oil, his car would have looked like a mosquito sprayer!
sixnotfour |
Sep 27 2024, 04:46 AM
914 Wizard Group: Members Posts: 10,704 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
type4fsaie
DrinkMan |
Sep 27 2024, 11:26 AM
If he burned 1-1 1/2 quarts of oil, his car would have looked like a mosquito sprayer! Absolutely!! I had an old Alfa that would burn 1 qt per 300 miles and I was embarrassed. Finally rebuilt it to cure the embarrassment. There were lots of people behind us during the various drives and none of them detected any smoke except a little puff at shifting sometimes. No smoke here: (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-20872-1727457988.1.jpg) |
Lo-Fi Version | Time is now: 15th January 2025 - 06:05 AM |
