2 Pages V < 1 2
> 1975 1.8 Driver Restoration, Driver quality restoration of a 1975 1.8
seanpaulmc
post Oct 27 2024, 04:28 PM
Post #21
There’s more there to cut out and replace than you think. Ask me how I know?
It’s rewarding though. Looks like a nice one to get back on the road.
You will definitely need to do door braces and fix those areas in the longs. I’ve done a lot of the same repairs on my project. I may even have some of the metal you’ll need. You’re in good hands with Fred looking over your shoulder. You may want to consider adding a stiffening kit to the longs for added piece of mind.
Take a look at my thread, you can find it with my name seanpaulmc, and you can see the same repair areas. I was trying to minimize how much I cut out, not always successful, but Fred is on a different level with his LE resurrection.
Have fun.
Best,
Sean
didenpx
post Oct 27 2024, 05:18 PM
Post #22
Sean, I've referenced your thread a few times to get an idea what sorts of things to anticipate.
Can't wait to peel off those inner rockers and see what I'm dealing with! Probably looking at sometime in December. Maybe I can make an Advents calendar out of the rusty patches that I cut out.
Paul
friethmiller
post Oct 27 2024, 06:41 PM
Post #23
@didenpx - yep gotya! Thanks for the additional pics! I'd always assume the P.O. did a sh*tty job until you can prove otherwise (IMG:style_emoticons/default/biggrin.gif). Look, you've got a good car here. It's going to be some work but its totally savable. I'd brace the doors and start on the passenger side longitudinal. Be prepared to cut the front of the rear fender out. It'll give you better access. Make sure you cut high enough to get to the hell hole area. My advice is to focus on just the longitudinal / jack point area, fix it up and then attack the hell hole. If needed, do the suspension consoles after that. Replace the lower fender and then move to the other side and repeat the process. It's all up to you and how you decide to go. That's the best part of YOUR restoration. Remember, don't get overwhelmed. As they say... “Eat the elephant one bite at a time”.
Having the car up and up at a 45 degree angle is where I like to have the car most of the time. If you want to know more about how to make a rotisserie let me know. I have built two in the last 6 years (IMG:style_emoticons/default/blink.gif)
didenpx
post Jan 4 2025, 09:37 AM
Post #24
An update on the project….but first an admission that my description of the work at hand as “trivial” in comparison to a previous Volvo project was a bit optimistic.
Nevertheless the car is structurally sound, though needing a lot of attention in LOTS AND LOTS of different places.
I re-awakened my welding “skills” by concentrating on the nose section first and that’s done-ish until body work begins.
Next I dug in on the LH longitudinal. Initially I was thinking I could get away with simply patching, but after cutting it open a bit and getting a better look at the inside I decided to open it up from aft of the A-pillar backwards. I used Tangerine Racing chassis braces to stabilize the structure.
Sections of the inner rocker, especially the section behind where the jacking point used to be, were badly compromised, but inside the inner long section was not too bad. there was some surface rust and scale on the bottom of this section which I cleaned up and then sealed.
After I got the middle part of the long sorted out I sectioned out the piece that goes behind the jack point (the part with the two circular holes, into one of which the jacking box section protrudes). This was weak/rotted away on the lower section below the holes so I patched it up with 16 gauge material.
I also found some rot on the interior the part of the long that starts kicking up and inward toward the engine, so I fabricated a stiffening piece and welded that in before priming everything. I also used Eastwood frame sealer to treat the upper portions of the interior of the long in the trunk/engine bay area. Hopefully this will stabilize things for as long as it will be relevant to me.
Once this was done I welded back in the patched section that reinforces the area behind the jacking point and then welded in the aft section of the inner rocker.
The most time consuming part came next; fabricating a patch for the inner rocker skin over the rear part of the long where it starts to kick up/in and covering the area where the jacking point attaches. I ultimately used 20 gauge steel which I cut and formed to fit the shape of the area. Where the jacking box section goes through the skin I spot welded in a piece of 16 gauge backer. This repair section was plug welded to the pieced behind and spot welded to the flange of the inner long section.
Now I’m moving on to the front section of the long including the bottom part of the A-pillar. Got that all peeled apart and the inner part of the long here looks solid with just surface rust and scale which I will Ospho and then seal before closing things back up.
After this it’s on to patching up the front fender and then back to the sail panel rot and replacing the LH door jamb.
There’s so much more yet to do that it seems pretty daunting….thank goodness for all of the Porsche resurrection videos on Youtube! When it all seems to much I watch one of those and think to myself “one patch at a time.” Still hoping to have all welding done and (stretch goal) body work complete by the time the salt is off the roads in New England.
didenpx
post Apr 28 2025, 05:55 AM
Post #25
OK, the dream of a quick refresh and recommissioning is dead and this has become the full blown restoration project that I swore it wouldn't. Readers probably are not surprised.
My intent all along was to leave the drivetrain in the car as it was running and driving. My logic was that I could fix what needed fixing on the body and get it back on the road quicker.
That began to go out the window once I found that an old rear impact had gone so far as to start crumpling the crumple zone. Off came the LH rear quarter to sort that out. In the close up photo below you can see that the inner quarter was trimmed back extensively near the tail lights, presumably to cut out metal that was too mangled to make look right. In the photo I'm holding the repair piece in its proper position on the outside of the inner quarter.
I knew all along that I'd need to replace the rear of the trunk floor and the rear panel (badly repaired after collision and bodged by PO who had mounted a 911 "Porsche" rear panel).
This weekend I pulled rear panel and started looking at structure and how the transaxle is mounted and started thinking that maybe it's just ridiculous to try to do all of this work around the drivetrain in situ.
What's the advice of the experienced who have worked through similar problems? Are there any pros to going with my original plan? Was I crazy to formulate it in the first place?
In other developments: originally I was going to keep the car as stock as possible (read: keep the BUBs). I've now decided to ditch that plan and backdate the bumpers. I figure the weight savings on a stock 1.8 will be helpful and I have always really liked the look of the early bumpers. It also helps that going this route will let me use the RD rear trunk floor pan piece without modification.
Attached Image Attached ImageAttached Image
Geezer914
post Apr 28 2025, 06:25 AM
Post #26
Geezer914
Welcome to 914 World! That's the problem buying a car from Maine. Rock salt and snow. You have your work cut out for you but you are doing a nice job on the restoration. Hope you got a good deal.
friethmiller
post Apr 28 2025, 07:38 AM
Post #27
You are the owner of this car. If you want to backdate the bumpers... go for it. For me, I'd leave it what it is... a '75. But don't let anyone tell you which way to go. It just a choice that you need to make. Regardless, you've got some fabrication work ahead of you. Nice! What you've done so far looks great. Keep it up (IMG:style_emoticons/default/smilie_pokal.gif)
didenpx
post Apr 29 2025, 06:41 AM
Post #28
@geezer914 the rust isn't as bad as you might expect...it's the old collision damage that has slowed me down the most. I think I got a decent deal on it....$5,700 running and lot driving with a bunch of spare parts and some new replacement sheet metal from RD.
@friethmiller thanks Fred...I lurk on your thread in the background and am amazed at what you are doing there. If this were an LE I'd obviously be going for bone stock, but I don't think a base level 75 1.8 is ever going to have any real collector value (unless it's an unrestored survivor or something).
friethmiller
post Apr 29 2025, 07:03 AM
Post #29
QUOTE(didenpx @ Apr 29 2025, 07:41 AM) *
Sounds good! Can't wait to see the results! (IMG:style_emoticons/default/popcorn[1].gif)
burton73
post Apr 29 2025, 01:16 PM
Post #30
Senior member, and old dude
@didenpx
You have a lot on you plate and it looks like you have that handled but, you may need to address the pan on your car. After you remove the tar, poke the metal hard because it can look good but may have rust in the channels on the pan. This is my 6 run from 1970 to 1986 till it could not pass smog. It is a Los Angeles car with no rust except what you see. (The red on pan) I personally stripped the paint down to metal. The PO told me he used to take it to the snow to go So California skiing.
Best Bob B
(IMG:style_emoticons/default/driving-girl.gif) (IMG:style_emoticons/default/driving-girl.gif) Attached Image Attached Image Attached Image
didenpx
post Apr 29 2025, 03:06 PM
Post #31
Thanks @burton73 . I have found a few very small holes in floor pan so far. I’m looking forward to getting the big stuff done so that I can get to finishing touches like that! Maybe by the late Summer or Fall…..
2 Pages V < 1 2
- Lo-Fi Version Time is now: 30th April 2025 - 02:42 AM
