SOLD FS: VDM GT Steering Wheel Core 914.347.805.10 |
johnhora |
Oct 6 2024, 01:09 PM
Senior Member Group: Members Posts: 874 Joined: 7-January 03 From: Derby City KY Member No.: 107 Region Association: None |
SOLD
For Sale is a VDM 914.347.805.10 GT steering wheel. This is sold as a core. Make your self a genuine 914-6 GT wheel. The master restorers like Dallas Wheels and others can make this look brand new. Looked up the other day and hanging on the garage shop wall was this thing. Think the last time I used it and why it was siting there was to move rollers and parts cars around. Sold my last project in late 2019. Not doing anymore. Hard enough to keep the 70' 914-6 in running shape. It's a good solid core and the welds are good. Has the horn ring loose. So here you go a real project. With a little work you have a $1k wheel $75 plus shipping |
johnhora |
Oct 6 2024, 01:10 PM
johnhora |
Oct 6 2024, 01:11 PM
johnhora |
Oct 8 2024, 11:59 AM
Well apparently looks like no one wants to take on a challenging project.
Still awaiting your courage |
BillJ |
Oct 8 2024, 01:35 PM
Senior Member Group: Members Posts: 1,216 Joined: 4-March 13 From: charlotte, NC Member No.: 15,610 Region Association: None |
Will this fit my 1970 914-6 spline correctly without adapter?
Oct 8 2024, 01:43 PM
914-6 GT in waiting Group: Members Posts: 19,642 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
porbmw |
Oct 8 2024, 06:49 PM
Senior Member Group: Members Posts: 813 Joined: 10-September 08 From: Vancouver, B.C. Member No.: 9,534 Region Association: None |
Will this fit my 1970 914-6 spline correctly without adapter? Yes. It’s identical to an 803 10 or 806 10 wheel in every way except the 805 part number. so....if i could be educated, if it is identical except for the number...is there ANY difference, other than the number? |
johnhora |
Oct 8 2024, 07:16 PM
BillJ....as mepstein mentioned.. yes it fits std spline
914 Steering Wheel Numbers 914/6: 914.347.803.10 for 914/6 Model 70/71 hard rubber 914.347.806.10 for 914/6 Model 70/71 leather 914.347.805.11 for 914/6 Model 72 leather 914/4 Model 70/71: 914.347.804.10 for 914/4 Model 70/71 hard rubber 914.347.805.10 for 914/4 Model 70/71 leather 914.347.090.10 for 914/4 Model 70/71 hard rubber w/ horn pad USA only 914.347.091.10 for 914/4 Model 70/71 leather w/ horn pad USA only 914/4 Model 72 onwards: 914.347.804.11 for 914/4 Model 72 onwards hard rubber 914.347.090.11 for 914/4 Model 72 onwards hard rubber w/ horn pad USA only 914.347.805.11 for 914/4 Model 72 onwards leather 914.347.091.11 for 914/4 Model 72 onwards leather w/ horn pad USA only 914.347.809.00 for 914/4 Model 72 onwards foamed ring |
Oct 8 2024, 07:23 PM
Will this fit my 1970 914-6 spline correctly without adapter? Yes. It’s identical to an 803 10 or 806 10 wheel in every way except the 805 part number. so....if i could be educated, if it is identical except for the number...is there ANY difference, other than the number? No difference. Ends in 10 = early with Porsche steerer Ends in 11 = later with VW steerer. The splines are the same throughout all the wheels but the base on a Porsche hub is 90 degrees to the shaft. The base on a VW hub is chamfered. Both will fit each other but not well and not how Porsche designed them to fit. The wheels that end in 10 are the ones you want for early 911’s. |
BillJ |
Oct 8 2024, 07:52 PM
I will take a gamble at $80 shipped. Let me know!
johnhora |
Oct 8 2024, 11:09 PM
BillJ...thanks for the offer...will pm you payment info
Oct 9 2024, 05:34 AM
BillJ....as mepstein mentioned.. yes it fits std spline 914 Steering Wheel Numbers 914/6: 914.347.803.10 for 914/6 Model 70/71 hard rubber 914.347.806.10 for 914/6 Model 70/71 leather 914.347.805.11 for 914/6 Model 72 leather 914/4 Model 70/71: 914.347.804.10 for 914/4 Model 70/71 hard rubber 914.347.805.10 for 914/4 Model 70/71 leather 914.347.090.10 for 914/4 Model 70/71 hard rubber w/ horn pad USA only 914.347.091.10 for 914/4 Model 70/71 leather w/ horn pad USA only 914/4 Model 72 onwards: 914.347.804.11 for 914/4 Model 72 onwards hard rubber 914.347.090.11 for 914/4 Model 72 onwards hard rubber w/ horn pad USA only 914.347.805.11 for 914/4 Model 72 onwards leather 914.347.091.11 for 914/4 Model 72 onwards leather w/ horn pad USA only 914.347.809.00 for 914/4 Model 72 onwards foamed ring That’s the most accurate chart I have seen. The one the guys use on early911Sreg is completely wrong. |
johnhora |
Oct 9 2024, 11:23 AM
SOLD....Thanks
Lo-Fi Version | Time is now: 22nd December 2024 - 12:22 AM |
