> Hard hot starting solution…?
oakdalecurtis
post Oct 8 2024, 03:08 PM
Oakdalecurtis
I know we’ve discussed this, but here’s the situation. 76 fuel injected with stock 2.0 other than Crane ignition, runs perfectly. I installed the 6v Ford relay on the starter a few years ago. Good Optima redtop battery. I have cleaned all the grounds at body and transmission. Still, after driving and shut off, it barely, if at all, turns over on immediate restarts. I thought I would just run a negative cable directly from the battery negative post to the starter to see if that helped. Questions:
Is that an appropriate possible fix?
If so, what gauge cable (will make one up) should I use?
Any thoughts on general optimal routing in the engine bay?
Any other thought?
Ty
emerygt350
post Oct 8 2024, 03:22 PM
I ran a neg cable from the battery post to the fan shroud, fixed all my ills. You may have a failing starter but I would try the neg cable first. I kept the post to body ground as well. And the transmission ground of course.Attached Image
oakdalecurtis
post Oct 8 2024, 07:58 PM
Oakdalecurtis
QUOTE(emerygt350 @ Oct 8 2024, 02:22 PM) *
I’ll try that, ty! I like simple first. What gauge wire?
914werke
post Oct 8 2024, 08:22 PM
technicalninja
post Oct 8 2024, 08:37 PM
QUOTE(oakdalecurtis @ Oct 8 2024, 08:58 PM) *
You can test if that is going to help with jumper cables.
Don't have to purchase anything.
Bigger is better for cables. Cheap 24" battery cable (FLAPS) will work fine.
You can purchase them with eyelets on both ends...
emerygt350
post Oct 9 2024, 05:18 AM
Yep, that one is a starter cable from flaps for a lawn tractor. 4 gauge? 8 gauge? Can't remember.
davep
post Oct 9 2024, 07:18 AM
914 Historian
This was my solution 20 years ago and it worked. try 2 or 4 AWG; remember the starter amps will be over 200 for at least a moment.
r_towle
post Oct 9 2024, 06:53 PM
Custom Member
I might suggest the 50 year old starter needs lubrication..maybe a rebuild.
I ran a ground cable, 3 feet long, to the mounting bolt on the starter.
rick 918-S
post Oct 9 2024, 08:14 PM
Hey nice rack! -Celette
I am not a believer in those Rubgoldberg devices. Try the Ed test. When the engine fails to start when hot, run a new set of jumper cables from the battery to the starter. Try to crank it. If you are still running 50 year old battery cables like me because they look new from the outside it is time to replace them.
oakdalecurtis
post Oct 10 2024, 01:36 PM
Oakdalecurtis
Emery wins!
I installed a 4 gauge lead from battery negative to fan housing as you suggested. Starts hot now like never before! Thank you....
emerygt350
post Oct 10 2024, 01:41 PM
excellent. Make sure you keep the body ground as well.
914werke
post Oct 10 2024, 06:04 PM
QUOTE(rick 918-S @ Oct 9 2024, 07:14 PM) *
(IMG:style_emoticons/default/unsure.gif) what are you talking about? (IMG:style_emoticons/default/confused24.gif)
emerygt350
post Oct 10 2024, 06:39 PM
QUOTE(914werke @ Oct 10 2024, 06:04 PM) *
I think it's the Ford solenoid he is referring to.
- Lo-Fi Version Time is now: 22nd December 2024 - 12:13 AM
