Rear Trunk Support DIY, Made my own |
jcambo7 |
Oct 12 2024, 01:49 PM
Senior Member Group: Members Posts: 1,691 Joined: 24-December 08 From: Graham, WA Member No.: 9,867 Region Association: Pacific Northwest |
Does anyone have a different trunk support then gas struts? I am thinking of a simple single rod style older cars had for the engine hood support. I have searched the site and haven't found any results other then gas struts.
Picture of an example |
Oct 12 2024, 02:40 PM
Resident German Group: Admin Posts: 41,937 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
The pre-production prototypes had a simple prop rod for both the trunk lid and the engine lid.
(IMG:style_emoticons/default/idea.gif) |
Oct 12 2024, 02:43 PM
914-6 GT in waiting Group: Members Posts: 19,642 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Only problem is the lids are heavy and make the rear lid hang crooked when it’s up.
dr914@autoatlanta.com |
Oct 12 2024, 02:48 PM
914 Guru Group: Members Posts: 8,109 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
use the original torsion rods
Does anyone have a different trunk support then gas struts? I am thinking of a simple single rod style older cars had for the engine hood support. I have searched the site and haven't found any results other then gas struts. Picture of an example |
jcambo7 |
Oct 12 2024, 02:54 PM
Only problem is the lids are heavy and make the rear lid hang crooked when it’s up. That was my concern. An option to prevent that is having the pivot on the actual hood near the middle and angle down to the tail area possibly (this option may be difficult to do with the roof installed though) Another option is having one on each side similar to the gas struts locations. |
jcambo7 |
use the original torsion rods Does anyone have a different trunk support then gas struts? I am thinking of a simple single rod style older cars had for the engine hood support. I have searched the site and haven't found any results other then gas struts. Picture of an example No thanks. |
jcambo7 |
Oct 12 2024, 02:57 PM
The pre-production prototypes had a simple prop rod for both the trunk lid and the engine lid. (IMG:style_emoticons/default/idea.gif) Looks like you can still access it with the roof installed as well... Any pictures of the rod end that touches the bottom of the rear trunk? Is their a slot for the rod or is it rubberized to grip? |
infraredcalvin |
Oct 12 2024, 03:11 PM
Distracted Member Group: Members Posts: 1,575 Joined: 25-August 08 From: Ladera Ranch, CA Member No.: 9,463 Region Association: Southern California |
Oct 12 2024, 03:16 PM
Stock is a pretty elegant solution.
jcambo7 |
Oct 12 2024, 03:17 PM
Ski pole works well… Or these… https://www.thoro-tec.de/en/p/hood-holding-...ack-porsche-914 https://www.thoro-tec.de/en/p/bonnet-holding-rod-porsche-914 Or adjustable hiking poles...or a broken plastic handle from on old car washing brush which is current set up... (IMG:style_emoticons/default/lol-2.gif) |
Oct 12 2024, 03:31 PM
Looks like you can still access it with the roof installed as well... Any pictures of the rod end that touches the bottom of the rear trunk? Is their a slot for the rod or is it rubberized to grip? It appears to just have been a pin that rests in a hole in the deck-lid frame. (IMG:style_emoticons/default/popcorn[1].gif) |
technicalninja |
Oct 12 2024, 03:54 PM
Advanced Member Group: Members Posts: 2,087 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region |
Without some way of "locking" it in the upright position to the trunk lid I wouldn't trust it.
Imagine a gusty day. Sort of like a giant mouse trap! The possibility of bending the lid over time would worry me as well. |
Literati914 |
Oct 13 2024, 09:31 AM
Senior Member Group: Members Posts: 1,777 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
I like this idea for both front and rear lids, and have considered it on a number of occasions, just never pursued the idea beyond a though or two. I'd be surprised if a stock setup already in use from some other car mfg. couldn't be incorporated to work with the 914. Nissan comes to mind.. I've had a D21 pickup and a more recent Rogue that both had these kinds of hood supports. The roof storage (procedure) is the problem as someone else has pointed out, unless mounting the support rod on one of the sides... I'm not sure the lid sitting crooked is all that much of an issue, since you never have the thing open for very long - least i wouldn't. Let us know what you come up with, if you do it.
This 911 front prop rod might be made to work on the rear of the 914: https://www.tiporscheproducts.com/product-p...-fiber-prop-rod ..and the 914-6 GT front prop rod style set ups are available on-line from various sources. They are obviously, normally used with the fiberglass GT hoods, but I doubt that's necessary. |
Garland |
Oct 13 2024, 09:48 AM
Restoration Fanatic Group: Members Posts: 1,397 Joined: 8-January 04 From: ......Michigan...... Member No.: 1,535 Region Association: Upper MidWest |
use the original torsion rods Does anyone have a different trunk support then gas struts? I am thinking of a simple single rod style older cars had for the engine hood support. I have searched the site and haven't found any results other then gas struts. Picture of an example No thanks. Why not? |
PanelBilly |
Oct 13 2024, 10:58 AM
914 Guru Group: Members Posts: 5,863 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
I have an umbrella that i carry in the trunk. If im putting away the roof i ask someone to hold it open.
jcambo7 |
use the original torsion rods Does anyone have a different trunk support then gas struts? I am thinking of a simple single rod style older cars had for the engine hood support. I have searched the site and haven't found any results other then gas struts. Picture of an example No thanks. Why not? I'm trying to KISS. The torsion bars seem to cause issues in the long run with the hinge area, and they're difficult/dangerous to remove/install. A simple prop is easier to install and replace if needed. |
930cabman |
Oct 13 2024, 11:08 AM
Advanced Member Group: Members Posts: 3,775 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
I am planning on using a stick, but I have been a carpenter for 50+ years.
Will try 3/4"x2" and report back |
Garland |
Oct 13 2024, 08:57 PM
Garland |
Oct 13 2024, 09:01 PM
Duplicate post
targa72e |
Oct 13 2024, 09:47 PM
Member Group: Members Posts: 276 Joined: 11-September 16 From: colorado Member No.: 20,392 Region Association: None |
I had to remove the T bars when i installed a MFI engine for clearance. I have a really cool bespoke high tech Carbon fiber support with padded ends.
Reality: Found a golf club with head broken off and added a cover on broken end. Light weight and functional. I am planning on using hydraulic lifts on my current build ( have kit in box). Not a fan of the T bars. John |
Lo-Fi Version | Time is now: 22nd December 2024 - 02:29 AM |
