Dash lights are out |
JeffBowlsby |
Oct 23 2024, 08:38 PM
914 Wiring Harnesses Group: Members Posts: 8,703 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
The headlight switch does not have 56a.
Spoke |
Oct 23 2024, 08:46 PM
Jerry Group: Members Posts: 7,076 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
The schematic shows 2 black/blue stripe wires at 56a but I have 4??? @Geezer914 Are you referring to pin 58a? I didn't find a pin 56a on either the '74 or '75 schematics. The '74 schematic shows 4 wires on pin 58a and the '75 schematic shows only 2 wires. Any chance your 914 is wired like a '74? The 4 wires on a '74 go to: 1) Dash lights 2) Hazard light 3) Heater control lights 4) Temperature control light The 2 wires on a '75 go to: 1) Dash lights 2) ***Seem to go nowhere*** All wires are black/blue. |
Spoke |
Oct 23 2024, 08:52 PM
@Geezer914
I quoted info from a Haynes manual for the 914. For the '75, it shows 2 wires on 58a. However on Jeff's site, the '75-'76 schematic shows 4 wires just like the '74 schematic. Not sure why the Haynes is different. Both Jeff's and Haynes look to be identically laid out except for the 2 less wires on the Haynes. |
Spoke |
Oct 23 2024, 08:57 PM
When I turn on the headlights, the fuse blows, so I have a short somewhere. @Geezer914 Which fuse blows? It looks like fuse S7 power the rheostat and the light in the engine compartment. Might want to check that socket too. |
Ishley |
Oct 23 2024, 09:45 PM
Member Group: Members Posts: 148 Joined: 4-October 21 From: Clarendon Hills Il Member No.: 25,957 Region Association: Upper MidWest |
Seems like your only path is to pull the gauges and remove each of the lights. Then plug in a bulb… insert it into the gauge and energize the system. Work along until you find the offending item. Check each socket carefully and look for issues.
I had a situation where the hot wire inside one socket had broken loose and was grounding and blowing a fuse on my ‘72. I was able to fix it with some creative soldering. My guess would be a faulty socket some where in the chain. |
Geezer914 |
Oct 23 2024, 09:59 PM
Geezer914 Group: Members Posts: 1,742 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States |
I stand corrected, 58a it is. I checked all the dash lights, all is good. It has to be one of those other wires. Will check by process of elimination. Thanks for the replies.
Geezer914 |
Oct 24 2024, 06:29 AM
Dash lights are working! (IMG:style_emoticons/default/piratenanner.gif) Eliminated the wire that was causing the short. Thanks to all who commented and offered their expertise. We can accomplish anything when we pool our knowledge. (IMG:style_emoticons/default/driving.gif)
Spoke |
Oct 24 2024, 07:41 AM
Which wire was it? Did you eliminate the short or the wire? |
sixnotfour |
Oct 24 2024, 07:50 AM
914 Wizard Group: Members Posts: 10,587 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
(IMG:style_emoticons/default/beerchug.gif) Which wire was it? Did you eliminate the short or the wire? yes what wire,,my neighbors 914 does the eact same thing.. |
Geezer914 |
Oct 24 2024, 08:50 AM
I didn't trace it back to the source but it was either the heater fan switch light on the center console (which I don't have) or the temperature control lights. 1974 has 4 wires coming off the headlight rheostat while the 75 only has 2. Hazards, fog lights, and 4 way flashers all work along with headlights, parking lights, and the dash lights.
Oct 24 2024, 01:25 PM
914 Idiot Group: Members Posts: 15,051 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
How would the license plate lights effect the dash lights? The gray wires (two of them) connect into the black/blue circuit at the fuse panel. Terminal "K" on the headlight switch feeds fuse #7, which has a gray wire and a black/blue wire connected to its output side. The black/blue goes to the dimmer, while the gray goes to the center console illumination light plug and the rear trunk and license plate lights. --DD |
Lo-Fi Version | Time is now: 28th October 2024 - 02:48 AM |
