> 914World Classifieds Rules
> WTB 12 Pole Socket
Puebloswatcop
post Nov 6 2024, 07:14 PM
I am looking for a 12 pole socket with cover for the engine wiring harness where it plugs into the relay board.
Thanks
JeffBowlsby
post Nov 6 2024, 08:19 PM
914 Wiring Harnesses
PN 911.612.122.04
Severl sources including dealers. if you want the housing and cover only, try https://www.djetparts.com/
Puebloswatcop
post Nov 7 2024, 05:51 PM
QUOTE(JeffBowlsby @ Nov 6 2024, 08:19 PM) *
PN 911.612.122.04
Thanks Jeff,
The part number I had kept coming back NLA. I should have known you would have the info and I should have just PM'ed you from the get go
morehills
post Nov 8 2024, 06:10 AM
I couldn't find a 12 pole either, so I just used a 14 and set it up like the 12 with two holes blank.
ClayPerrine
post Nov 9 2024, 10:05 PM
QUOTE(Puebloswatcop @ Nov 6 2024, 07:14 PM) *
Thanks
I have one, but you have to come get it.
Clay
Puebloswatcop
post Nov 10 2024, 07:14 AM
Thanks Clay. Not exactly sure when I can get over your way. I'll let you know as soon as I can find a day to drive over. By the way, Did you ever get the wire you needed for the fuel pump?
ClayPerrine
post Nov 10 2024, 12:49 PM
QUOTE(Puebloswatcop @ Nov 10 2024, 07:14 AM) *
Not yet. I need the black with a red stripe from a 75-76 harness to relocate the pump up front.
Thanks,
Clay
rgalla9146
post Nov 14 2024, 10:02 PM
QUOTE(Puebloswatcop @ Nov 6 2024, 08:14 PM) *
Thanks
Did you end up getting the 12 pin connector ...or not?
Steve
post Nov 15 2024, 05:33 AM
Pelican carries it. https://www.pelicanparts.com/More_Info/9116...04#backToTopAnc
Puebloswatcop
post Nov 15 2024, 05:48 AM
QUOTE(rgalla9146 @ Nov 14 2024, 10:02 PM) *
Thanks
I did but if you have an extra, I could use another one.
- Lo-Fi Version Time is now: 21st November 2024 - 08:10 PM
