Intermittent Temp Gauge |
Missio1 |
Nov 8 2024, 03:48 PM
Newbie Group: Members Posts: 5 Joined: 10-November 16 From: Maryland Member No.: 20,574 Region Association: MidAtlantic Region |
Recently had some major engine work done on my 74 914 2.0. Car runs great except the temp gauge is acting funny. Sometimes it works fine, sometimes it stops working completely, and, most recently, the needle was twitching slightly in time to the turn signal when it was blinking. Thanks for any help you can give me.
So sorry for my first post. I accidentally wrote fuel gauge in the body of the post instead of temp gauge (which is in the heading). My apologies for sending people on a wild goose chase. |
NARP74 |
Nov 8 2024, 04:36 PM
Senior Member Group: Members Posts: 1,268 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
Major engine work should be unrelated to the fuel sender, unless they messed with fuel lines or took the tank out. Easy to pull the sender and give it an inspection and a clean. Make sure the float is moving freely. If it is very old, think about replacing it due to bad gas, corrosion etc. Not sure about the voltage surge from the turn signals.
Just noticed you have temp gauge in the title and fuel in the body. Not sure which one I answered for now. |
930cabman |
Nov 8 2024, 05:04 PM
Advanced Member Group: Members Posts: 3,695 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
Could be as simple as a loose connection. Have you spoken to the repair shop? did the condition exist prior to their work Our 914's are quite basic to work on, you might want to purchase a Haynes or Clymer repair manual for reference |
DC_neun_vierzehn |
Nov 8 2024, 07:17 PM
Member Group: Members Posts: 466 Joined: 16-November 20 From: Delaware Shore Member No.: 24,893 Region Association: MidAtlantic Region |
Is it your fuel or temp gauge that’s an issue. The title of your post says temp but your post says fuel.
dtmehall |
Nov 8 2024, 08:50 PM
Member Group: Members Posts: 62 Joined: 21-December 23 From: Farmington Hills, Michigan Member No.: 27,808 Region Association: Upper MidWest |
If it is your fuel gauge, besides checking the sender, have you ever had the gauge repaired?
I've used these guys and they are very good https://www.nhspeedometer.com/ |
Nov 9 2024, 10:34 PM
914 Idiot Group: Members Posts: 15,060 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
It's a bad connection somewhere. Very possibly on a ground.
--DD |
Missio1 |
Nov 18 2024, 02:51 PM
Major engine work should be unrelated to the fuel sender, unless they messed with fuel lines or took the tank out. Easy to pull the sender and give it an inspection and a clean. Make sure the float is moving freely. If it is very old, think about replacing it due to bad gas, corrosion etc. Not sure about the voltage surge from the turn signals. Just noticed you have temp gauge in the title and fuel in the body. Not sure which one I answered for now. Apologies. Meant temp not fuel gauge. |
Missio1 |
Nov 18 2024, 02:52 PM
Missio1 |
Nov 18 2024, 02:53 PM
(IMG:style_emoticons/default/welcome.png) Could be as simple as a loose connection. Have you spoken to the repair shop? did the condition exist prior to their work Our 914's are quite basic to work on, you might want to purchase a Haynes or Clymer repair manual for reference Appreciate the tip. Yes, I have spoken to the shop about it and they are non-responsive. No, the condition did not exist prior to their work. |
DC_neun_vierzehn |
Nov 18 2024, 03:41 PM
What year is your car? What size engine? What temp gauge (factory console gauge)? Pics?
Missio1 |
Nov 20 2024, 03:22 PM
914Sixer |
Nov 21 2024, 06:14 AM
914 Guru Group: Members Posts: 9,018 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Check continuity of wire from sender at bottom of engine to the plug on engine shelf. They get brittle from engine heat, causing high joint(intermittent going open)
Porschef |
Nov 23 2024, 10:30 AM
How you doin' Group: Members Posts: 2,180 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States |
Like Dave said, check the ground. Run a wire directly from the gauge (-) to the chassis and see if that does it. That’ll give you a starting point if it’s not. (IMG:style_emoticons/default/beerchug.gif)
Lo-Fi Version | Time is now: 24th November 2024 - 07:06 AM |
