Repairing the main seal leak, Finally got to the first part of it. |
Superhawk996 |
Dec 1 2024, 07:51 PM
914 Guru Group: Members Posts: 6,544 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Yeah that big ‘un looks like a casting inclusion but it isn’t where the seal lip rides.
However, the other areas of the flywheel look like rust pitting got to it including the area where the seal lip rides. I think you made the right choice to get a new flywheel. Be sure to recheck crankshaft end play with the new flywheel. Don’t assume it will remain unchanged. |
mmichalik |
Dec 2 2024, 12:31 AM
MikeM Group: Members Posts: 734 Joined: 27-January 16 From: Valley Center, CA Member No.: 19,600 Region Association: Southern California |
One of the things I ordered was a dial indicator, just for that purpose. Plus a few new spacers as well.
Hopefully I got everything covered |
Superhawk996 |
Dec 2 2024, 08:08 AM
StarBear |
Dec 2 2024, 09:12 AM
Advanced Member Group: Members Posts: 2,074 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States |
Might check the trans input shaft also for leakage (IMG:style_emoticons/default/agree.gif) I believe that’s the source my small leak (trans fluid). Question for the community: If replacing that trans seal best to replace the main rear seal too, or leave it alone as it’s not leaking? (IMG:style_emoticons/default/dry.gif) |
Geezer914 |
Dec 2 2024, 09:40 AM
Geezer914 Group: Members Posts: 1,775 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States |
Might check the trans input shaft also for leakage (IMG:style_emoticons/default/agree.gif) I believe that’s the source my small leak (trans fluid). Question for the community: If replacing that trans seal best to replace the main rear seal too, or leave it alone as it’s not leaking? (IMG:style_emoticons/default/dry.gif) As the old saying goes, if you don't disturb shit, it won't stink! Don't go looking for problems that don't exist. |
technicalninja |
Dec 2 2024, 10:13 AM
Advanced Member Group: Members Posts: 2,026 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region |
Wow, I'm exactly opposite to Geezer.
If you have it all apart and short-change the job it just means you'll get to do it again... Anything rubber that is more than 20 years old should be automatically replaced when the unit is torn down. Now, finding a good RMS for a T4 looks like a bit of a crap-shot. It seems the quality of the newer stuff has dropped off significantly. Does anyone know of a "safe" brand of RMS today? Because of this, if the RMS is not leaking and is less than 20 years old, I would probably leave it alone... |
Lo-Fi Version | Time is now: 4th December 2024 - 02:34 AM |
