> Fuel Pressure Regulator
StratPlayer
post Nov 13 2024, 08:20 PM
StratPlayer
Going to slap one of these into my new motor, I saw where PMB was building a new 2258 and had one of these units installed on the motor.
https://thedubshop.com/universal-fuel-press...or-package-914/
bkrantz
post Nov 13 2024, 08:29 PM
That's what I have in my system (from the Dub Shop). No complaints, so it must be working. (IMG:style_emoticons/default/biggrin.gif)
Actually, I do know that it reaches and holds required pressure, based on when I had a manual gauge plumbed into the engine fuel line loop.
GregAmy
post Nov 13 2024, 08:31 PM
I use it on my Microsquirt-converted D-Jet. 3-bar solid with my standard D-Jet pump.
Also used it on my Microsquirt-converted Toyota MR2 race car. Solid there, too.
jim_hoyland
post Nov 15 2024, 12:34 PM
Get that VIN ?
QUOTE(StratPlayer @ Nov 13 2024, 06:20 PM) *
How did you mount it ? I’m
StratPlayer
post Nov 15 2024, 04:22 PM
StratPlayer
QUOTE(jim_hoyland @ Nov 15 2024, 11:34 AM) *
It mounts where the old fuel pressure regulator goes install is easy.
jim_hoyland
post Nov 15 2024, 07:21 PM
Get that VIN ?
Can it adjust the fuels pressure ?
bkrantz
post Nov 15 2024, 08:17 PM
Here's how I mounted mine. First the Dub Shop bracket.
bkrantz
post Nov 15 2024, 08:19 PM
And regulator.
GregAmy
post Nov 16 2024, 08:08 AM
QUOTE(StratPlayer @ Nov 15 2024, 05:22 PM) *
Ditto. I just screwed mine into that same flange using its fittings.
QUOTE(jim_hoyland @ Nov 15 2024, 08:21 PM) *
No, it's fixed at 3 bar. If you're tuning most EFIs at our level then that's a good baseline.
Stock D-Jet fuel pressure is 28; 3 bar is 43.5 psi. You could account for that with a tunable MPS from Tangerine: https://tangerineracing.com/shop/ols/produc...t-mps-diaphragm
Mario also offers a 4 bar: https://thedubshop.com/fuel-pressure-regulator-builder/
Being a standard Bosch regulator, you could possibly find alternatives.
Vicioso
post Feb 27 2025, 09:22 AM
When you change from fuel injection to Carbs on a 74 2.0 do you need to change out the fuel pressure regulator?
Superhawk996
post Feb 27 2025, 09:52 AM
QUOTE(Vicioso @ Feb 27 2025, 11:22 AM) *
You need to change to a low pressure pump.
Regulating a high pressure fuel injection pump down to 2-3 psi for use with carbs isn’t recommended.
Vicioso
post Feb 27 2025, 10:06 AM
Thanks for the quick reply I'll order today, when I remove and replace do I need to clamp the fuel line?
Superhawk996
post Feb 27 2025, 12:29 PM
Sorry, I Don’t understand the question.
930cabman
post Feb 27 2025, 12:53 PM
Being a Weber guy, I would like to see a fuel pressure regulator with a built in gauge.
Currently I am running a cheapie regulator with a cheapie gauge. Engine runs great, but would prefer an all in one regulator/gauge
friethmiller
post Feb 27 2025, 01:57 PM
QUOTE(930cabman @ Feb 27 2025, 12:53 PM) *
@930cabman - see @Retroracer s comment in this recent thread:
http://www.914world.com/bbs2/index.php?sho...p=3193899&#
I'm currently adding a return line to my carb setup and want a regulator that can be set to 3psi. Apparently, most return type regulators seem to have a higher pressure range.. like >4. This one is low pressure, has the gauge built-in and increases your engine horse power just by looking at it. (IMG:style_emoticons/default/biggrin.gif)
slivel
post Feb 27 2025, 03:39 PM
Old car....... older driver
[/quote]
I run a Holley bypass regulator model 12-881 adjustable from 4.5 to 9 psi. The bypass regulator is right after the pump and a second Holley regulator model 12-804 adjustable from 1-4 psi at the engine to feed my Webers. My fuel pump is a Holley Blue 14psi.
In order: Tank - Shut off valve - Fuel filter - Fuel pump - Bypass regulator - Regulator - Carbs.
I've had this arrangement for years on track and now street only. Works great!
neyen14
post Jan 14 2026, 12:41 PM
With dual Webers what is preferable, one pressure gauge at the regulator, or one before the "T", or two.... after the "T" but before each carb?
friethmiller
post Jan 14 2026, 01:12 PM
QUOTE(neyen14 @ Jan 14 2026, 12:41 PM) *
@neyen14 - You've got options and I've seen some diagrams out on the Internet that can probably help you. I went with the PMO regulator. I've installed a return line and have dual Webers. I guess this would be an internal "T" out to the carbs.
friethmiller
post Jan 14 2026, 01:47 PM
Here's my post from the other thread. It has the diagrams I mentioned. Also see @Retroracer post with his install photo/comments.
http://www.914world.com/bbs2/index.php?s=&...t&p=3193899
neyen14
post Jan 14 2026, 04:38 PM
QUOTE(friethmiller @ Jan 14 2026, 11:47 AM) *
Thank you @friethmiller for this. I have a regulator that I'm going to use that doesn't have a return line and will go from there. I'm hoping to get mine started for the first time this week and will make adjustments/upgrades as things show up.
thank you for the rapid response with insightful info!!
3 User(s) are reading this topic (1 Guests and 0 Anonymous Users)
2 Members: neyen14, seanpaulmc
- Lo-Fi Version Time is now: 15th January 2026 - 08:25 AM
