FS: Microsquirt kit |
Montreal914 |
Nov 16 2024, 12:34 PM
Senior Member Group: Members Posts: 1,696 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
For Sale:
Never fired Microsquirt ECU with an array of sensors and components to upgrade your type 4 engine. (IMG:style_emoticons/default/smile.gif) A while back I had started the Microsquirt conversion of my 2056 but the project got halted by my still on-going (IMG:style_emoticons/default/rolleyes.gif) shell restoration. More recently, I acquired a 3.2 six that I will be using for my build so I am moving on and offering this to the next interested World member! (IMG:style_emoticons/default/smile.gif) This thread below explains my whole process and where I stood at the time of stopping. A lot of research was done here (IMG:style_emoticons/default/smilie_pokal.gif) and on Shoptalkforums (they have pretty good info there too (IMG:style_emoticons/default/biggrin.gif)) to determine which components to select. Thread: http://www.914world.com/bbs2/index.php?sho...=342361&hl= If you are looking at doing this project, I believe this is a good starting point where a chunk of the work has been done. (IMG:style_emoticons/default/smash.gif) All part listed below were acquired new and prepared/installled per build thread, but never ran. I will refer them as new in my list below unless otherwise indicated. List of the kit's content: - New Microsquirt ECU (Dub Shop) - New Short MS cable harness (Dub Shop) - New crank trigger wheel, pick up sensor and cracket (Dub Shop) - New Throttle position switch with custom made adaptor for 2 liter throttle body - New VW ignition coil pack with custom built bracket - New Magnecore ignition cables for type 4 custom modified to fit new VW coil pack - Used BMW air cooled motocycle cylinder head temperature sensor (M10 thread) - New 1 Bar MAP sensor (intake vaccuum level) - New 3 Bar MAP sensor (atmospheric pressure monitoring) - New Resistance pack for stock D-Jet injectors with custom bracket - New BMW auxiliary air valve with custom mounting bracket - Used D-Jet air intake temperature sensor - Custom made block-off plate for plenum auxiliary injector delete - New CB Performance distributer delete plug - New relays and fuse block Price: $575 + shipping (IMG:style_emoticons/default/smile.gif) Pick up welcome in Claremont or Pasadena Kit (not everything shown) Crack trigger wheel Crank trigger sensor and bracket Throttle position switch with custom bracket Ignition coil subassembly Ignition coil, MAP, and custom bracket Magnecore cables BMW cylinder head temp sensor BMW head sensor installed in stock location on head 1 of 2 MAP sensor Resistance pack for D-Jet injectors BMW auxiliary air valve mounted subassembly Auxiliary air valve subassembly with custom bracket Distributor delete plug Cold start injector delete block off plate |
technicalninja |
Nov 16 2024, 12:47 PM
Advanced Member Group: Members Posts: 2,000 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region |
This is a pretty cool kit!
Swap the 3/1 bar sensor for application. This will work as is in waste spark but if you modified a distributor to become a "cam sensor" this would work sequential as well. That's a nice and tidy coil pack; the wires are kick ass! Nicely done Montreal! (IMG:style_emoticons/default/first.gif) If I was still planning on a T4 I'd buy this (and I'm a cheap bastard). Looks like more than 1K of stuff if you pieced this together... This set up can easily adapt to modern injectors if desired. This will support ANY T4 build, Wimpy or Wild! GLWS! |
Montreal914 |
Nov 16 2024, 01:05 PM
Thank you Ninja!
FYI, Microsquirt is waste spark only. (IMG:style_emoticons/default/smile.gif) Although I don't have knowledge in this, I am not a fan of the distributor trigger driven stuff (conceptually). It could have been an option, but I preferred the precision of the crank trigger wheel. (IMG:style_emoticons/default/sunglasses.gif) |
bdstone914 |
Nov 16 2024, 01:41 PM
bdstone914 Group: Members Posts: 4,705 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
@Montreal914
Bring that tomorrow to the swap meet. That may go on my 2056. ' date='Nov 16 2024, 01:05 PM' post='3177492'] Thank you Ninja! FYI, Microsquirt is waste spark only. (IMG:style_emoticons/default/smile.gif) Although I don't have knowledge in this, I am not a fan of the distributor trigger driven stuff (conceptually). It could have been an option, but I preferred the precision of the crank trigger wheel. (IMG:style_emoticons/default/sunglasses.gif) [/quote] (IMG:style_emoticons/default/beerchug.gif) |
Montreal914 |
Nov 16 2024, 02:30 PM
Pending!
GregAmy |
Nov 16 2024, 04:25 PM
Advanced Member Group: Members Posts: 2,397 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
NOOOOOOOOOOOOOOOO!!!!!!!!!!!!!!!!!!!!
Dammit man... I get it, I get it. But dammit. EDIT: Eric was a key help in getting my design going (see link in sig) and I was hoping he'd get it all together for himself. I'm disappoint. But if I can help the next guy along, do let me know. - GA |
Montreal914 |
Nov 16 2024, 05:59 PM
@GregAmy
I know (IMG:style_emoticons/default/sad.gif) i was sad preparing this add this morning. I don’t like to leave unaccomplished project… (IMG:style_emoticons/default/dry.gif) At least I had fun getting to where I was and sharing with you! (IMG:style_emoticons/default/beerchug.gif) I can only build one car and it looks like it’s going to be a 3.2. Pretty scary for a just a amateur like me but there is a lot of great help here! (IMG:style_emoticons/default/smilie_pokal.gif) I take it your microsquirt conversion is still running like a champ! (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/sunglasses.gif) Thank you for chiming in! (IMG:style_emoticons/default/smile.gif) |
GregAmy |
Nov 17 2024, 09:50 AM
Lo-Fi Version | Time is now: 21st November 2024 - 06:43 PM |
