| Gearup |
Nov 19 2024, 06:40 PM
Member ![]() ![]() Group: Members Posts: 165 Joined: 21-April 15 From: Denver Member No.: 18,660 Region Association: None |
Curious if anyone has used a product like Vapor Trapper in their setups. I have quite a bit of smell coming from the vent line of my modified in tank pump assembly. I hear this product works well with classic cars and modified classics but was hoping for a cheaper solution. The Vapor Trapper with mounting brackets is $349. I’m tired of my garage smelling of gas as well as the passenger compartment. |
| Chris914n6 |
Nov 19 2024, 07:41 PM
Jackstands are my life. ![]() ![]() ![]() ![]() Group: Members Posts: 3,562 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
Pricey for a charcoal canister.
You can make one out of tupperware and fish filter charcoal if so inclined. |
| technicalninja |
Nov 19 2024, 08:43 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,531 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region
That's a SCAM at 350...
Nothing but a charcoal canister if that! Find a 914 canister and affix it appropriately. Some of them are openable and you can change the 'activated charcoal" out yourself. A charcoal canister is a "sponge" for fuel vapors, and you dry the sponge with airflow through it. Most of the time the vapor rich air from this canister is induced into the intake stream. Most cars use a "purge valve" which allow flow during cruise (not idle or WOT). This is fed into the intake manifold past the throttle blade. This requires a check valve that can be vacuum operated or electronic in nature. The late 914 set up used bleed air from the fan housing and merely fed it into the air filter housing. If the engine is running canister purge is occurring. This IS the simplest canister purge I've ever encountered! |
| mb911 |
Nov 20 2024, 05:59 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,820 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest
I need to do something this next year with mine
| mxkinn01 |
Nov 20 2024, 08:44 AM
Member ![]() ![]() Group: Members Posts: 292 Joined: 18-June 17 From: Las Vegas, NV Member No.: 21,195 Region Association: Southwest Region
I am lucky enough to have the plastic late canister. The end pops right off and I replaced the original charcoal with fresh from a fish tank supply. Problem solved. FYI I threw the old charcoal in the trash and it smelled for two weeks.
Mike |
| slowrodent |
Nov 20 2024, 08:47 AM
Member ![]() ![]() Group: Members Posts: 247 Joined: 29-February 20 From: Tucson/Oro Valley Member No.: 23,981 Region Association: Southwest Region
I made my own per these instructions... Not running yet, but I'm optimistic (IMG:style_emoticons/default/biggrin.gif)
https://classicbroncos.com/forums/threads/d...anister.322134/ |
| Steve |
Nov 20 2024, 08:51 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,096 Joined: 14-June 03 From: Laguna Niguel, CA Member No.: 822 Region Association: Southern California
I am lucky enough to have the plastic late canister. The end pops right off and I replaced the original charcoal with fresh from a fish tank supply. Problem solved. FYI I threw the old charcoal in the trash and it smelled for two weeks. Mike Same here.. I mounted it in front of the battery on my six conversion. Only had to run one hose from the tank. |
| slowrodent |
Nov 20 2024, 08:56 AM
| worn |
Nov 20 2024, 07:58 PM
Winner of the Utah Twisted Joint Award ![]() ![]() ![]() ![]() Group: Members Posts: 3,654 Joined: 3-June 11 From: Madison, WI and North Bend WA Member No.: 13,152 Region Association: Upper MidWest
| slowrodent |
Nov 21 2024, 08:46 AM
As per the instructions (above)... it is indeed PVC with steel wool and charcoal.. (IMG:style_emoticons/default/smile.gif)
| Root_Werks |
Nov 21 2024, 10:34 AM
Village Idiot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,072 Joined: 25-May 04 From: About 15NM from Canada Member No.: 2,105 Region Association: Pacific Northwest
I am lucky enough to have the plastic late canister. The end pops right off and I replaced the original charcoal with fresh from a fish tank supply. Problem solved. FYI I threw the old charcoal in the trash and it smelled for two weeks. Mike Same here.. I mounted it in front of the battery on my six conversion. Only had to run one hose from the tank. Same here, mines in the engine bay. If you can find one, get the plastic can and swap out the charcoal. |
| technicalninja |
Nov 21 2024, 10:53 AM
| Justinp71 |
Nov 22 2024, 09:46 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,647 Joined: 11-October 04 From: Sacramento, CA Member No.: 2,922 Region Association: None
I just ran a small diameter hose to under the car by the steering rack, eliminated the smell inside the car, reduced the smell in the garage quite a bit, it makes the vapor have to work to get out. This would be a good next step.
Might be able to use a radiator overflow tank as an option, I actually own the below for another car, the second tube comes up to the top of the canister, not sure though if that would be too restrictive. The PVC version would be easier to use, just thinking of options. |
Lo-Fi Version | Time is now: 21st October 2026 - 07:42 PM |
