WTB Heater Ventilation Box, Wanted Ad for Blower Box |
56kabrio |
Nov 20 2024, 03:54 PM
Member Group: Members Posts: 57 Joined: 1-December 05 From: Nashville, TN Member No.: 5,219 Region Association: None |
Disassembling my 914 today and found that the heater ventilation box (blower box in the frunk) had a broken drain. It also only had a single omega clip on it and mismatched mounting bolts! (IMG:style_emoticons/default/WTF.gif)
I am in need of a replacement. Must be in excellent condition. It is for a ‘73. ( Mfg date 1/73) Thanks in advance Mack |
bdstone914 |
Nov 20 2024, 10:17 PM
bdstone914 Group: Members Posts: 4,705 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Disassembling my 914 today and found that the heater ventilation box (blower box in the frunk) had a broken drain. It also only had a single omega clip on it and mismatched mounting bolts! (IMG:style_emoticons/default/WTF.gif) I am in need of a replacement. Must be in excellent condition. It is for a ‘73. ( Mfg date 1/73) Thanks in advance Mack Hard to find good ones that do not have over spray. You can repair the broked drain with the lower part of a rain tray funnel. Clips are eay to replace. Not sure about the mis matched bolts as they thread into a 6mm nut in the box. I can check to see if i have a good box. |
56kabrio |
Nov 21 2024, 04:48 AM
Disassembling my 914 today and found that the heater ventilation box (blower box in the frunk) had a broken drain. It also only had a single omega clip on it and mismatched mounting bolts! (IMG:style_emoticons/default/WTF.gif) I am in need of a replacement. Must be in excellent condition. It is for a ‘73. ( Mfg date 1/73) Thanks in advance Mack Hard to find good ones that do not have over spray. You can repair the broked drain with the lower part of a rain tray funnel. Clips are eay to replace. Not sure about the mis matched bolts as they thread into a 6mm nut in the box. I can check to see if i have a good box. Bruce If you have one, that would be great. Meanwhile I can try to repair this one. What adhesive would you use on the plastic? Mack |
bdstone914 |
Nov 21 2024, 07:02 AM
Disassembling my 914 today and found that the heater ventilation box (blower box in the frunk) had a broken drain. It also only had a single omega clip on it and mismatched mounting bolts! (IMG:style_emoticons/default/WTF.gif) I am in need of a replacement. Must be in excellent condition. It is for a ‘73. ( Mfg date 1/73) Thanks in advance Mack Hard to find good ones that do not have over spray. You can repair the broked drain with the lower part of a rain tray funnel. Clips are eay to replace. Not sure about the mis matched bolts as they thread into a 6mm nut in the box. I can check to see if i have a good box. Bruce If you have one, that would be great. Meanwhile I can try to repair this one. What adhesive would you use on the plastic? Mack The glue used for model airplanes should work. |
Lo-Fi Version | Time is now: 21st November 2024 - 07:04 PM |
