> Steel GT Fenders / 15x8 Fuchs Rubbing, Help!, 15x8 Fuchs with 235/30 tires *NOT 335*
chris.t.10
post Nov 21 2024, 01:01 AM
Hey everyone! My 914 gt project came to a screeching halt when I tried to put on the rear wheels. The fender rubs right at the top of the tire, a problem that I didn't think was going to happen with the size of wheel I chose. They are 15x8 fuchs with 235/30 toyo proxes tires.
Does anyone know how I can fix this? I've been advised to add negative camber and roll fenders, but I want to check with the community as well. Will add photos below
mate914
post Nov 21 2024, 05:53 AM
Matt
QUOTE(chris.t.10 @ Nov 21 2024, 03:01 AM) *
Hey everyone! My 914 gt project came to a screeching halt when I tried to put on the rear wheels. The fender rubs right at the top of the tire, a problem that I didn't think was going to happen with the size of wheel I chose. They are 15x8 fuchs with 335/30 toyo proxes tires.
Your tire size it way to big. I run 245/45 on 9''x16'' and that all I can fit with fiberglass. Metal fender will need even smaller tires to not rub.
Matt
rick 918-S
post Nov 21 2024, 06:49 AM
Hey nice rack! -Celette
(IMG:style_emoticons/default/thisthreadisworthlesswithoutpics.gif)
I really want to see those tires!
BTW I had Toyo Proxies on my BMW M3. They are really soft. They lasted about 8000 miles. You will not want to run any camber with those tires or you will shorten the life even more.
brant
post Nov 21 2024, 07:07 AM
Smaller tires
More ride height
Cairo94507
post Nov 21 2024, 07:48 AM
Michael
This site is full of members who have been there, done that and got the T-shirt. You may be better served if you discuss your build and plans so others can chime in and let you know their experiences. Saves time, money and anxiety; just a thought. (IMG:style_emoticons/default/beerchug.gif)
BillJ
post Nov 21 2024, 07:53 AM
Yeah your tire selection is super wide. 245 is probably the largest you can go. Wheel size is totally fine. Need to see ride height as well.
sixnotfour
post Nov 21 2024, 08:15 AM
AA flares have a wide lip,,trim it ..
A picture is worth a thousand words..
Steve
post Nov 21 2024, 08:41 AM
Unless they added metal when they installed them, I have not seen greater than 255 with race tires. I am running 245 street tires. My Michelin Pilot tires have a rib, so I had to drop down to 245.
rick 918-S
post Nov 21 2024, 08:51 AM
I run 255/50/16's on the rear but I have Glass Flares with a piece of round stock bonded to the inside with no lip.
mlindner
post Nov 21 2024, 09:48 AM
I'm running 225/50 rears and 215/40 fronts with factory steel flares. Best, MarkAttached Image
post Nov 21 2024, 09:52 AM
Resident German
QUOTE(sixnotfour @ Nov 21 2024, 06:15 AM) *
The obvious would be to see if there is a lip you can roll to gain some more room.
335 is a lot of tire for an 8" rim. I'd like to see some pictures of that.
NARP74
post Nov 21 2024, 10:00 AM
What engine do you have? That a lot of meat to get to hook on the road.
Root_Werks
post Nov 21 2024, 10:21 AM
Village Idiot
QUOTE(SirAndy @ Nov 21 2024, 07:52 AM) *
(IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif)
Trim or roll the lip, probably smaller tires. If you have pictures, please post them.
ChrisFoley
post Nov 21 2024, 10:22 AM
I am Tangerine Racing
QUOTE(chris.t.10 @ Nov 21 2024, 02:01 AM) *
Hi Chris,
I thought you told me 235 width on the phone.
The only way to get 335 tires under GT flares is by custom modification.
mb911
post Nov 21 2024, 11:07 AM
QUOTE(ChrisFoley @ Nov 21 2024, 08:22 AM) *
Hi Chris,
If they are 235s then clearly the OP has an issue with flare placement
sixnotfour
post Nov 21 2024, 12:02 PM
All Depends on flair install ,, Eric at PMB same issue,,factoryflares.
Mine old 245/50 on 15x9s, factory flares, lip rolled up..
sixnotfour
post Nov 21 2024, 12:10 PM
My other 914-6, factory flares, 1.5 inch for more room/look, sames wheels tires.
chris.t.10
post Nov 21 2024, 01:20 PM
QUOTE(chris.t.10 @ Nov 20 2024, 11:01 PM) *
CORRECTION! I just realized i typed 335 i meant 235! Uploading photos now
post Nov 21 2024, 01:33 PM
914-6 GT in waiting
You can trim the lip
Roll the lip
Pull in the flare and make more room
Raise the car
Use different tires
Etc.
Every car fits a bit differently and every flare install will vary a bit.
campbellcj
post Nov 21 2024, 04:33 PM
I can't Re Member
^^^ Yup! I went thru multiple wheel/tire combos along my journey. Felt like a wheel collector/dealer at one point.
3 User(s) are reading this topic (2 Guests and 0 Anonymous Users)
1 Members: brant
- Lo-Fi Version Time is now: 24th November 2024 - 07:17 AM
