> 914World Classifieds Rules
> WTB: 1.8 L-Jet Brain
Rob-O
post Nov 21 2024, 04:08 PM
I’d really love for this to be a ‘Want To Borrow’ initially. But ‘Want To Buy’ is certainly okay by me.
My L-Jet is still ‘missing’ at certain times. I’ve checked and replaced tons of parts. I’ve narrowed the timing of the miss down. Starting up the car is fine and settles into a perfect idle. After about 10-15 minutes it develops a miss.
Distributor is a 123. New coil, new temp sensor, checked and cleaned all grounds. No vacuum leaks that I’ve detected. AAR has been checked, TB was rebuilt, all FI wiring was checked for continuity before installing several years back. AFM was changed out to a known good unit (thanks @clayperrine ). I feel like I’ve checked everything except changing out the brain. And since the brain can’t be easily bench tested I thought I’d reach out here to see if someone had one laying around.
JeffBowlsby
post Nov 21 2024, 05:13 PM
914 Wiring Harnesses
Send it to https://www.ecudoctors.com/
$149. they will evaluate it for you and can do repairs.
bdstone914
post Nov 21 2024, 05:39 PM
bdstone914
QUOTE(Rob-O @ Nov 21 2024, 04:08 PM) *
@Rob-O
I may have one. Is it for a 74 or 75?
What is the part number on it?
fiacra
post Nov 21 2024, 06:37 PM
Person.Woman.Man.Camera.TV
I have an ECU for a 1974 1.8 that I bought from Len Hoffman a while back. The backstory was that it had been taken out of a running car and sat on a shelf in dry storage for ~25 years. Not tested by Len or me, but if you want you can borrow it to run in your car. Just cost you postage both ways, and if it cures your problem I'll sell it to you for a more than reasonable price.
technicalninja
post Nov 21 2024, 06:50 PM
I'm out of Granbury Texas and have two that you are welcome to borrow.
One is a recent Bosch "rebuilt" that I purchased off of another member that replaced everything with a stand-alone Megasquirt system.
Everything was working fine 2 years back per the seller.
I don't want to sell either but using them as a diagnostics check is fine with me.
PM me if you'd like to come down south...
ClayPerrine
post Nov 21 2024, 09:55 PM
Rob,
I have a few laying around here. You may borrow one if you need to test yours.
Also, did you check the wires on the dropping resistors? They break from vibration and may sometimes cause an intermittent miss.
Clay
Geezer914
post Nov 22 2024, 05:33 AM
Geezer914
What year 914? 74 1.8 is different than a 75-76 unit.
StarBear
post Nov 22 2024, 09:12 AM
QUOTE(ClayPerrine @ Nov 21 2024, 10:55 PM) *
Rob,
Clay
Didn’t know there are so many 1.8 ECUs out there. Yes, 74 and 75/76 are different.
Curious as to how many 76 1.8Ls were produced.
StarBear
post Nov 22 2024, 09:14 AM
QUOTE(JeffBowlsby @ Nov 21 2024, 06:13 PM) *
@jeffbowlsby
Can they do 1.8L ECUs? Very important and maybe the only ones if they can.
JeffBowlsby
post Nov 22 2024, 09:34 AM
QUOTE(StarBear @ Nov 22 2024, 07:14 AM) *
@jeffbowlsby
Contact them to verify.
Rob-O
post Nov 23 2024, 04:24 PM
QUOTE(bdstone914 @ Nov 21 2024, 03:39 PM) *
@Rob-O
@clayperrine
I’ll check the part number ASAP but I can tell you the AFM has six pins,
So ‘74.
Rob-O
post Nov 23 2024, 04:29 PM
@fiacra and @technicalninja . Thanks gentleman. I may take you up on your offers. Clay is local (well, closer than Granbury, TX at least). If he has one I’ll go that route. If not I’ll ping you fellas. Would be nice to eliminate or confirm this as the issue.
- Lo-Fi Version Time is now: 24th November 2024 - 06:23 AM
