Fiberglass hood photos Please |
Shivers |
Nov 25 2024, 11:25 AM
Senior Member Group: Members Posts: 2,790 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
I’d love to have one for the rear. That would be a nice chunk of weight off the back.
sixnotfour |
Nov 25 2024, 03:37 PM
914 Wizard Group: Members Posts: 10,645 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
How about a fiberglass engine lid ??? I have one... (IMG:style_emoticons/default/piratenanner.gif)
brant |
Nov 25 2024, 06:00 PM
914 Wizard Group: Members Posts: 11,802 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
I run glass front and rear
Neither fit great That 500 version is without the balsa As is mine. Cheaper but not correct One of the worse fitting hoods I’ve seen was my buddy’s real m471 On the car since factory build and 1-2 inch side gaps from the factory |
Nov 25 2024, 06:52 PM
914-6 GT in waiting Group: Members Posts: 19,610 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I run glass front and rear Neither fit great That 500 version is without the balsa As is mine. Cheaper but not correct One of the worse fitting hoods I’ve seen was my buddy’s real m471 On the car since factory build and 1-2 inch side gaps from the factory If I had a real GT, I would celebrate the handmade nature of the car. On a tribute, it might just look unfinished. |
brant |
Nov 26 2024, 07:53 AM
Prior to using a glass hood I built this for weight
Shivers |
Nov 26 2024, 09:03 AM
Prior to using a glass hood I built this for weight I was going to do this, I collected your pics from a build thread but having the tub bare I accidently found out that the backend of my car is heavier than the front. Then add an engine, trans and suspension and I changed my mind on lightening anything up front. I'm still doing the through the hood oil cooler exhaust like your street car but it will be build with my steel hood. I do not have all the goodies up front like others do. |
campbellcj |
Nov 26 2024, 11:09 AM
I can't Re Member Group: Members Posts: 4,590 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
FWIW I came up with 44 pounds savings from just the two lids and the front springs. Pretty significant and also it's up high. I actually did the Getty lids in 2009 - damn time flies. They were unpainted raw amber f/g from 2009-11 then got painted.
Nov 26 2024, 01:12 PM
Sitting in an airport one day, I penciled out about 300lbs that I could remove from a 914-4. Even with a stock engine, a 15% weight savings would make a significant difference in acceleration, braking and handling.
Nov 26 2024, 01:56 PM
Resident German Group: Admin Posts: 41,904 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Sitting in an airport one day, I penciled out about 300lbs that I could remove from a 914-4. Even with a stock engine, a 15% weight savings would make a significant difference in acceleration, braking and handling. My car is under 2000lbs and i didn't really try hard to save weight. And it has a full roll-cage. And probably more than 50lbs in bondo. (IMG:style_emoticons/default/wacko.gif) |
rgalla9146 |
Nov 26 2024, 04:28 PM
Advanced Member Group: Members Posts: 4,657 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
As I watched this video I couldn't help but notice the surface condition as the GT hood
was opened.' The video is attached to a current thread on 914 World. 'Real GT' https://www.youtube.com/watch?v=A8aeyzpt5Mo...nnel=BillyShott |
PanelBilly |
Nov 26 2024, 05:22 PM
914 Guru Group: Members Posts: 5,861 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
As I watched this video I couldn't help but notice the surface condition as the GT hood was opened.' The video is attached to a current thread on 914 World. 'Real GT' https://www.youtube.com/watch?v=A8aeyzpt5Mo...nnel=BillyShott Bernie told me that several people have told him they could sand the hood so you couldn’t see the fiberglass texture. He said that was the way Porsche made it and he was keeping it that way |
brant |
Nov 26 2024, 07:07 PM
When I built the race car in 2003 my cost/benefit formula for weight was 50$/pound
Making glass hoods an obvious choice at 500/600$ for 20plus pounds How we got to 1815lbs wet with a /6 that has 19 quarts of oil in it (5 gallon bucket of oil almost) I took 500 lbs out of the chassis’s before I added the /6 Aluminum hardware in all non structural areas Air craft wiring with thinner insulation And went from an aluminum 2.0/6 To a mag 2.0/6 to save weight |
Nov 26 2024, 07:58 PM
As I watched this video I couldn't help but notice the surface condition as the GT hood was opened.' The video is attached to a current thread on 914 World. 'Real GT' https://www.youtube.com/watch?v=A8aeyzpt5Mo...nnel=BillyShott Bernie told me that several people have told him they could sand the hood so you couldn’t see the fiberglass texture. He said that was the way Porsche made it and he was keeping it that way It's easy to forget that back in the day the factory race program did not give a rats ass about showing those cars at a concours or in a museum. Many of the original parts have a rather rough finish and often don't fit/align well. (IMG:style_emoticons/default/popcorn[1].gif) |
raynekat |
Nov 27 2024, 01:20 AM
Advanced Member Group: Members Posts: 2,164 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest |
raynekat |
Nov 27 2024, 01:23 AM
rgalla9146 |
Nov 27 2024, 08:10 PM
Maltese Falcon |
Nov 27 2024, 10:53 PM
Advanced Member Group: Members Posts: 4,852 Joined: 14-September 04 From: Mulholland SoCal Member No.: 2,755 Region Association: None |
@Maltese Falcon I drive FM311 often. Sounds like you have had work done at Lozano Brothers. I’m wanting to add unfinished fiberglass with balsa wood mostly for the looks, I bought the car from D. Driver out of Reno NV. It’s a x track car, so not concerned about not being factory. Absolutely... Lozano Brothers Porting; Ben, Armando and the crew are amazing engine builders ! Post pics of your project (red 914 in picture? ) when you get the f'glass hood installed. (IMG:style_emoticons/default/marty914.jpg) |
sixnotfour |
Nov 28 2024, 09:43 AM
As I watched this video I couldn't help but notice the surface condition as the GT hood was opened.' The video is attached to a current thread on 914 World. 'Real GT' https://www.youtube.com/watch?v=A8aeyzpt5Mo...nnel=BillyShott Bernie told me that several people have told him they could sand the hood so you couldn’t see the fiberglass texture. He said that was the way Porsche made it and he was keeping it that way It's easy to forget that back in the day the factory race program did not give a rats ass about showing those cars at a concours or in a museum. Many of the original parts have a rather rough finish and often don't fit/align well. (IMG:style_emoticons/default/popcorn[1].gif) 100% Factory pieces are thin, body shop wanted to flatten mine also.. No just scuff and paint... Getty ones are a bit thicker and are flatter for paint.. |
Lo-Fi Version | Time is now: 30th November 2024 - 10:55 PM |
