> Fuel pump relocation and wiring
captjm
post Nov 22 2024, 09:03 PM
I need some help with wiring a 914 fuel pump being relocated to the front fuel tank location exactly like the 75/76 914's. The car is a 1971 914/4 being set up for a carbureted 2.4 six cylinder. My question is about where to pick up the power to run the pump correctly.
I would like it to have any relay protections like the original if that is the way it is suppose to be. I think the positive power is to come from the engine compartment relay board from the forward connector pin 13? I plan on running the positive wire from pin 13 under the driver side rocker panel forward to to the fuel tank bay and picking up the ground from the closest grounding point nearest to the tank bay. Any comments or advice would be helpful. Thank you
dtmehall
post Nov 22 2024, 09:12 PM
it was 40 years ago when i did this. i believe your estimation of the relay plate is what i did. but i did run the wire up the tunnel.
JeffBowlsby
post Nov 22 2024, 09:32 PM
914 Wiring Harnesses
It’s a 12 ga wire.
dtmehall
post Nov 22 2024, 09:38 PM
it was 12 gauge for the fuel injection pump. i would suspect that whatever pump you are using for carbs, will draw far fewer amp. hence a lower gauge wire requirement
North Coast Jim
post Nov 24 2024, 08:22 AM
I ran the wire thru the tunnel wired as above. Bought a 2 conductor, red/blk paired wire from West Marine. It had a jacket around the pair, white in color, similar to Romex. Worked great. Oh and the stranded conductor count was IFRC was 19.
North Coast Jim
post Nov 24 2024, 08:25 AM
I ran a two conductor wire thru the tunnel wired as above. It was a red/blk pair jacketed like romex, white in color. Bought it at West Marine. Worked great. Oh, if IIRC the conductor count was 19 strands.
davep
post Nov 24 2024, 12:24 PM
914 Historian
QUOTE(dtmehall @ Nov 22 2024, 11:38 PM) *
But the wire length is about double. The original wire seemed undersized to me when I looked at 20 harnesses with most pump wires cooked. I would not go less than the 12AWG that Jeff recommends.
- Lo-Fi Version Time is now: 24th November 2024 - 02:43 PM
