> 1971 turn signal relay question, turn signal
Mike1981
post Dec 1 2024, 04:37 PM
Hello Everyone
I'm making a list of items that need attention on my 1971 914.
I have determined what I need for my shifter bushing project.
Now I'm onto my turn signal project.
I have an aftermarket steering wheel on this car and the turn signals do not work>
I'm hoping to check the relays first before tearing into the wiring.
Can anyone help me identify the relays under my dash please?
Mike1981
post Dec 1 2024, 06:49 PM
QUOTE(Mike1981 @ Dec 1 2024, 06:37 PM) *
Hello Everyone
added 2nd pic
Artfrombama
post Dec 2 2024, 11:50 AM
Looks like an old headlight relay with a circuit breaker
RAX914
post Dec 2 2024, 01:54 PM
Since you mentioned you have an aftermarket steering wheel, have you taken it off yet? If not pull it off and check if the cancel ring was installed on your after market wheel. Also check that the wavy spring is mounted on the right hand side of the steering column.
Mike1981
post Dec 2 2024, 02:19 PM
QUOTE(Artfrombama @ Dec 2 2024, 01:50 PM) *
Thanks it does look like a circuit breaker ill get back under there and see if there is a reset button.
Mike1981
post Dec 2 2024, 02:20 PM
QUOTE(RAX914 @ Dec 2 2024, 03:54 PM) *
Well, I was hoping to rule out the relay before cracking into the steering column.
- Lo-Fi Version Time is now: 4th December 2024 - 02:19 AM
