> 2056 Build
SteveNMaine
post Dec 2 2024, 08:17 AM
I am trying to work out compression ratio of my 2056 build. In calculating head volume my understanding from the forum is that stock 2.0 heads have 57mm and the valve pockets on the pistons I am going to use is 3mm. Do I add these together to use 60mm in my calculations for head volume?
Geezer914
post Dec 2 2024, 09:25 AM
Geezer914
Yes, anything that adds volume.
technicalninja
post Dec 2 2024, 09:50 AM
You should measure the valve depressions, head CCs and deck height yourself.
Don't EVER trust published data.
Now if the data came from Len Hoffman, LN engineering, or Raby I'd trust it...
Most published data shows the 2.0 head at 60cc and the 1.8 head at 55cc
I'd still check it.
What you need is a clear round piece of Lexan (Plexi-glass) approximately 105 mm in diameter (fits the cylinder register in the head) with two holes in it across the combustion chamber. One of the holes should be large enough to socket a 60cc veterinarian syringe in it and the other hole (completely across from the first but in the chamber depression) is an air bleed hole and can be very small.
A 60cc veterinarian syringe will work fine for anything below 10-1 but if you want to get "technical" a graduated burette is more accurate (and much bitcher to use)
You use a bit of grease/Vaseline to seal the edges of the plate to the flat surfaces in the head and then twist and turn until you can get all of the bubbles on of the air bleed hole. The placement of this hole is critical to reduce the bull shit you will encounter trying to remove the bubbles. I want the air bleed directly next to the edge of the chamber depression so I can tilt the head a little bit and have the critter bleed itself.
I'd LOVE to find a 70 or 80cc syringe but haven't been able too. 60s are super common. Burettes came in 100cc increments and work better with larger combustion chambers.
I'll sometimes use the 60cc syringe and then a 5 or 10cc syringe when I'm messing with things over 60 cc. Most combustion chambers are at 60 or below.
Use the plate directly on the piston to measure valve depression volume.
(IMG:style_emoticons/default/ninja.gif)
rfinegan
post Dec 2 2024, 12:31 PM
IM doing this too..
This may help
https://www.youtube.com/watch?v=THjjnmbzDqk
amazon has the plastic circles already cut and the cheep syringes
http://www.914world.com/bbs2/index.php?sho...=371399&hl=
technicalninja
post Dec 2 2024, 12:56 PM
Another tip is to reduce the surface tension of the fluid (water) you are using to measure.
"Water wetter" or a bit of antifreeze does the trick.
This makes the bubbles "flow" together better and reduces tension in both the fluid and the technician doing the measuring.
barefoot
post Dec 2 2024, 06:40 PM
My understanding is that 2L heads are 60 cc and 1,7/1.8 heads are 48 cc.
Jack Standz
post Dec 2 2024, 10:41 PM
QUOTE(SteveNMaine @ Dec 2 2024, 09:17 PM) *
Yes, you add the combustion chamber volume to the volume of the valve pockets on the top of the pistons. You figure out these two volumes by doing what the above posters said. You actually measure the volume.
Suggest you use one of those plastic circles with a hole drilled in it. Along with a burette with rubbing alcohol with a drop of food coloring in it. Best wishes for getting your compression ratio right.
emerygt350
post Dec 3 2024, 06:25 AM
I used my kids crayon clay and compared it to oil, came out the same for me but mileage may vary. You just drop the clay in a graduated cylinder with water and watch the displacement. It's clean and easy but I have access to stuff like graduated cylinders.
930cabman
post Dec 3 2024, 10:59 AM
QUOTE(SteveNMaine @ Dec 2 2024, 09:17 AM) *
I built a 2056 a couple years ago, worked out very well. Ended up at 8.8:1 CR Never pings, run on high test and pulls nice
technicalninja
post Dec 3 2024, 12:16 PM
QUOTE(Jack Standz @ Dec 2 2024, 10:41 PM) *
QUOTE(emerygt350 @ Dec 3 2024, 06:25 AM) *
The use of clay and a burette is a good idea.
Not sure about the alcohol, might work fine, evaporates so fast that it MIGHT cause inaccuracies. Normally I just use antifreeze.
I use a bunch of alcohol in my Automotive AC business, probably 100 gallons a year.
One thing to ALWAYS be aware of is the fact that alcohol burns with a flame that you CANNOT see unless the room is dark.
You can be ON FIRE and not know it!
The actual clearance volume measurement is a bit more complicated.
+Head CC
+ valve pocket CC
+ deck height CC
+ clearance around top of piston to first ring land (usually around 1cc)
In the case of a stock 2056 flat top at optimal quench (.040") with two 1.5cc valve depressions would go like this.
Head= 60 measured
Valve pockets 3 measured
deck height at .040 7 calculated
upper ring clearance 1 calculated
total "clearance volume" of 71cc
Swept volume of 514 (calculated)
(Swept + clearance) / clearance = compression ratio
or
Swept / clearance +1 = compression ratio
514+71 / 71 = 8.24
No valve reliefs and 55 cc heads
clearance = 63
63+514 / 63= 9.16
One of the reasons I decided to not walk the T4 route is the difficulty in hitting 10/1 ratios without stroker cranks/ pistons larger than 96mm or other "fully bespoke engine" type mods.
That second example, which is just over 9/1 will require verifying valve to piston clearances and it will most likely limit valve travel.
And it gets more critical as valve diameters go up.
And all this measuring and calculation means NOTHING AT ALL if you haven't properly selected the cam you will be using.
The engine actually runs on what is called "dynamic" compression ratio.
You cannot verify this by measuring. It takes a dynamic compression ratio calculator program. Dynamic compression ratio is often 2 full points LOWER that static comp ratio (10/1 engine is really an 8/1 engine!).
Higher static compression ratio DEMANDS larger duration camshafts...
Compression ratio, available fuel octane, intended use, expected RPM range, transmission gearing, induction and exhaust all factor into your camshaft choice.
Raby is RIGHT!
It's the total combination of everything that makes it work!
porschetub
post Dec 3 2024, 04:15 PM
Did all that when I did my last build for a customer,was using NOS raised dome high compression pistons and barrels from a 411 FI ,had some research to do and a respected builder on the Samba helped there and tested for volume over and over and got 8.8 to 1 which was suitable for this motor ,had to play with base shims to achieve this however .
On my engine stand this turned out to be a strong motor and buyer happy,its a lot of time but differance between a strong motor and average one.
emerygt350
post Dec 3 2024, 04:55 PM
Well spent time. And on a type 4 it's some pretty easy time compared to water buffaloes or fancier air cooled.
technicalninja
post Dec 3 2024, 05:42 PM
@porschetub The .028 on the top of the piston is negative deck height, correct?
Did you use a fire ring?
If so, how thick?
If not, .028 is 4 thousands CLOSER than anything I've ever run across or built.
I have built a tight bore, cast piston water pumper at .033-.034.
It worked fine but I was nervous about lack of clearance.
.028 sets a new "low" for me...
@emerygt350 OMG are you right! You take off too much on a water pumper there are only two ways to save it.
Thicker head gasket (if someone makes it!!!)
Replace block (and do ALL of the block machine work again!!!).
I do my WP builds WITHOUT decking the block.
Get everything perfect before pulling it back down for the decking.
I also let the machine shop know that if they take more than I ask for they will get to purchase and machine another block for me!
I'll also pay DOUBLE for the extra precision!
Jack Standz
post Dec 4 2024, 02:17 PM
QUOTE(technicalninja @ Dec 4 2024, 01:16 AM) *
+Head CC
+ valve pocket CC
+ deck height CC
Head= 60 measured
or
514+71 / 71 = 8.24
clearance = 63
63+514 / 63= 9.16
Raby is RIGHT!
Seemed like the poster was looking for CR calculations 101. You went to graduate school here (IMG:style_emoticons/default/biggrin.gif) in your answer. But, something a lot of us strive for, getting the best combination we can with our parts, time, tools and skills.
Use whatever fluid in your burette you like. But, if your alcohol evaporates enough to make a meaningful difference in your calculations, you're a tad bit slower at it than we are (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/beerchug.gif) .
technicalninja
post Dec 4 2024, 04:27 PM
Jack, I am the TECHNICALninja...
I earned that name and did not choose it myself.
That was compression calculations 101!
You know this; you're serious too...
Do you disagree with what I posted?
If you don't take everything into consideration, you're not doing it correctly!
Thank God he's using flat tops.
Imagine the difficulty with an exotic shaped piston crown.
That is where I've used the clay before.
And, yep, during a build, speed is not a factor.
I seldom have to go back "in" however...
I want to do it exactly right ONE SINGLE TIME!
And I use the alcohol BECAUSE of the fast, clean evaporative qualities.
Every AC system I flush is finished with alcohol as to guarantee nothing is in the system when I pull a vacuum.
A single drop of the other AC flushing chemicals will kill a new system.
I call this "medically clean"- not even germs...
Geezer914
post Dec 5 2024, 09:30 AM
Geezer914
Deck height should be around 0.040, if less, check the piston to valve clearance with modeling clay
Jack Standz
post Dec 5 2024, 10:06 AM
QUOTE(technicalninja @ Dec 5 2024, 05:27 AM) *
Yes, we are both serious about this stuff. And I don't disagree with your post, except maybe the minor criticism you had about using colored alcohol to check combustion chamber volume (this has the added quality of confirming if your valves are sealing well, as I think alcoholwill leak past a valve easier than coolant) (IMG:style_emoticons/default/smile.gif) . So, if you see leaks/drips into the ports, your valves need some more work.
We've used play dough to check piston to valve clearance. It gives a nice visual check on the clearance and when you carefully measure the thickness at the closest point of valve to piston contact, it will confirm/not confirm other calculations or measurements.
On Type IV motors you really don't want to go back in there, especially if it involves splitting the case. It's a messy process and cleaning the case and re-gluing it back together is never part of the plan. And not getting things right the first time can be really expensive. Time (redoing things, sourcing parts), machining, parts, broken parts, etc.
Plan the build well, measure, clean, mock things up multiple times, etc, etc. and execute well. Or something like that.
porschetub
post Dec 7 2024, 01:28 PM
[quote name='technicalninja' date='Dec 4 2024, 12:42 PM' post='3180074']
If so, how thick?
[/quote
No ,you can ignore that number as it has no relation to the final correct result ,no fire rings used as have seen too many fail only thicker than normal base gaskets .
- Lo-Fi Version Time is now: 22nd November 2026 - 08:26 AM
