2 Pages V < 1 2
> Cosmetic rubber interior windshield trim, How to install?
914sgofast2
post Dec 3 2024, 06:08 PM
Post #21
On my 1970 model year, I removed the old crusty seal, as well as the metal clip under it. The 914 Rubber piece has its own lips to grip the metal flange running along the base of the windshield. I think it works best if you remove both of the "A" pillar plastic trim pieces on the windshield uprights. That way the new rubber seal along the base can be tucked completely into the lower corners of the windshield and will be held in place by the "A" pillar trims when you re-install them after fitting the rubber seal to the base of the windshield. I also started from the center of the windshield and worked toward each side more or less equally.
FlacaProductions
Post #22
Certainly looks like an improvement to me!
drmitch
post Dec 3 2024, 07:24 PM
Post #23
QUOTE(914sgofast2 @ Dec 3 2024, 05:08 PM) *
A pillar trim would've been a good move and I considered it. Just didn't want to do it. It's good as-is, but I appreciate the input.
drmitch
post Dec 3 2024, 08:36 PM
Post #24
Thanks for the help, everyone. Next project might be replacing the fog lights...I'm sure I'll be back with more questions!
2 Pages V < 1 2
- Lo-Fi Version Time is now: 4th December 2024 - 01:20 PM
