Shifter Cone Screw Keeps Loosening, Thread Locker or Worn? |
Spoke |
Dec 6 2024, 07:30 AM
Jerry Group: Members Posts: 7,104 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
Every 6 months I have to retighten the cone screw on the shifter. This time it came out real quick. I thought it might come out all together. I couldn't get 2nd without hitting reverse. The picture shows how much the screw backed out.
Not sure how much torque I applied but I was bending the allen wrench. Questions: Should I have thread locker on this? What is the torque required for the cone screw? Possible that the threads have been widened by repeated looseness? Why didn't they put a bolt through this to really lock the hub onto the shaft? TIA (IMG:style_emoticons/default/beerchug.gif) Attached image(s) |
brant |
Dec 6 2024, 07:33 AM
914 Wizard Group: Members Posts: 11,824 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
Intended to be one time use
Replace both. And you’ll be done |
Spoke |
Dec 6 2024, 08:03 AM
The cone screw thread appears to be folded over at the bottom. Really messed up.
Superhawk996 |
Dec 6 2024, 08:29 AM
914 Guru Group: Members Posts: 6,598 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Why didn't they put a bolt through this to really lock the hub onto the shaft? The conical screw provides a positive indexing that couldn’t be obtained by simply matching a flat on the shift rod or using a hole and a through bolt. The amount of torque that can be used is limited by the material used and the size of the fastener. Again, a bolt of the same size (M6 if I recall) offers no advantage over the conical set screw. The conical set screw seating into the pocket on the shaft offers positive retention. Should it loosen, the coupler can’t become disconnected from the shaft even though things get terribly sloppy well before the screw could fall out alllowing for a disconnect to occur. This is a very safe failure mode. |
Superhawk996 |
Dec 6 2024, 08:33 AM
The cone screw thread appears to be folded over at the bottom. Really messed up. Looks like maybe the cone maybe is hitting the top of the pocket in the shaft (rolling the 1st thread). Hard to say if the cone screw wasn’t machined properly or maybe the pocket in the shaft is getting enlarged by having been loose for too long. Inspect Remove 1st thread if needed to allow the set screw to seat fully in the shaft pocket. |
Steve |
Dec 6 2024, 08:55 AM
914 Guru Group: Members Posts: 5,766 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
Unless their worn or partially stripped, I just put blue loctite on them and reuse them. But yes they are one time use. Some of the new ones i received have a hole in them with a plastic piece to keep it from coming out, but the plastic piece that holds it in, only works once.
VaccaRabite |
Dec 6 2024, 09:02 AM
En Garde! Group: Admin Posts: 13,616 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
A small amount of blue loctite is all you need.
Though as buggered as those threads are I'd get a new screw. Zach |
Superhawk996 |
Dec 6 2024, 09:22 AM
A small amount of blue loctite is all you need. Though as buggered as those threads are I'd get a new screw. Zach (IMG:style_emoticons/default/agree.gif) Inspect the threads in the coupler carefully. That screw may have torn up the aluminum as it was removed and may necessitate a helicoil repair to the coupling. |
87m491 |
Dec 6 2024, 09:25 AM
Member Group: Members Posts: 326 Joined: 29-July 12 From: Portland, the original! Member No.: 14,731 Region Association: North East States |
The cone screw thread appears to be folded over at the bottom. Really messed up. Indeed, also the first of your 2 pix shows a void in the threads where a silicone anti vibration, anti backout slug, would be sitting in a new factory screw. Both of those items likely causing you backing out. |
930cabman |
Dec 6 2024, 10:50 AM
Advanced Member Group: Members Posts: 3,780 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
A small amount of blue loctite is all you need. Though as buggered as those threads are I'd get a new screw. Zach (IMG:style_emoticons/default/agree.gif) I have a couple on the shelf for good measure. One time use, but a dab of blue Locktite will do the job |
ejm |
Dec 6 2024, 11:14 AM
I can see the light at the end of the tunnel Group: Members Posts: 2,705 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
First time I've seen a cone screw facing up. Is there something else going on here?
rjames |
Dec 6 2024, 11:44 AM
I'm made of metal Group: Members Posts: 4,158 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
QUOTE Not sure how much torque I applied but I was bending the allen wrench. I don't know what the exact spec is, but it's nowhere near that much. |
GregAmy |
Dec 6 2024, 11:49 AM
Advanced Member Group: Members Posts: 2,412 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
I know it's often said these are one-use items, but there's nothing with the threads that would support that contention, other than new ones come with a dab of loctite (or similar) on them.
In my case I clean the hell out of the threads (usually brake clean) and dab with blue loctite (I use the semi-solid "Quickstix" dispenser version) and - knock on wood - I've never had a problem in either car. And they're part of a standard underside inspection every oil change. But that one with the buggered threads? Nope. And that may have buggered the aluminum casting in the process. |
Spoke |
Dec 6 2024, 12:26 PM
I cleaned up the first thread on the cone nut and reinstalled with loctite but there was nothing left of the treads. The threads are stripped. So either heli-coil or new coupler.
930cabman |
Dec 6 2024, 12:52 PM
flipb |
Dec 6 2024, 03:26 PM
Senior Member Group: Members Posts: 1,771 Joined: 2-September 09 From: Fairfax, VA Member No.: 10,752 Region Association: MidAtlantic Region |
If you want to replace the coupler, the part number is 911-424-221-00
My local Porsche dealer obtained it for $56 (plus shipping) a few years ago. |
mb911 |
Dec 7 2024, 07:20 AM
914 Guru Group: Members Posts: 7,370 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Every 6 months I have to retighten the cone screw on the shifter. This time it came out real quick. I thought it might come out all together. I couldn't get 2nd without hitting reverse. The picture shows how much the screw backed out. Not sure how much torque I applied but I was bending the allen wrench. Questions: Should I have thread locker on this? What is the torque required for the cone screw? Possible that the threads have been widened by repeated looseness? Why didn't they put a bolt through this to really lock the hub onto the shaft? TIA (IMG:style_emoticons/default/beerchug.gif) Man I have seen a lot of 914s and their shift linkages but wondering why the cone screw is at the top versus the bottom like all of the ones I have ever seen seen? |
DC_neun_vierzehn |
Dec 7 2024, 08:42 AM
Member Group: Members Posts: 485 Joined: 16-November 20 From: Delaware Shore Member No.: 24,893 Region Association: MidAtlantic Region |
This is the cheapest I've found the Genuine Porsche cone screws ($8) and the coupler from the same source at a nice price as well ($61):
https://www.delawareporscheparts.com/oem-pa...nb3J5IFBhZ2U%3D https://www.delawareporscheparts.com/oem-pa...int-91142422100 |
Bartlett 914 |
Dec 7 2024, 08:43 AM
Advanced Member Group: Members Posts: 2,218 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
I reuse mine. I use a torch and warm the screw. You will see the plastic ball soften. It will come out easily. I then insert a 1/8" nylon ball n place. A drop of instant adhesive will hold in in place. When inserting the screw, some will be cut off. You may think it all came out but it hasn't. I have done this for yr\ears. McMaster Carr will sell 100 1/8" nylon balls for less than a single cone screw. I have done this for years and no issues!
brant |
I've salvaged knuckles in the past...
take them apart. tig weld the alloy housing with the stripped hole. re-tap. |
Lo-Fi Version | Time is now: 27th December 2024 - 10:16 AM |
