Setting deck height for 9:1 compression |
Chad911sc |
Dec 23 2024, 10:45 AM
Newbie Group: Members Posts: 28 Joined: 24-September 24 From: Florida Member No.: 28,374 Region Association: South East States |
Trust me! That was my first thought when purchasing a 914. Stick a turbo Subi engine into it, but when I seen this Olympic blue 914 on Craigslist, I loved it just as it was. I figured I would leave it original and possibly let my daughter, who just turned 17, have it as her second fun car to sport around on the weekends. I haven’t finished the bug yet, have all the fabrication work done but still have to finish the body work and paint. I can’t wait to drive it! The engine purrs like a kitten. I used the Cobb system to tune it and have it close, but I will go to the local Subaru dyno shop to get the perfect set up once it’s finished.
The 911sc engine is exactly like it came from Max Moritz, I had the local Porsche guru fit the new tensioners and Mahle pistons and cylinders when I purchased it over 20 years ago. I don’t think it had a bunch of extra hp, but when Sid Collins tore it apart to rebuild it, the case halves were polished internally and it’s fuel injectors were longer and different shape than the factory ones. Sid said it was done for better distribution of the fuel for efficiency in the burn. Never had it on the dyno, but it definitely scoots. I have only put about 10k miles on it in the past 23 years. I bought the Corvette from a man down in Miami who had it stolen from his driveway and purchased a new one with the insurance money. They found it 3 months later in a shipping container bound for overseas. I picked it up for 7k and dropped 7k in the engine and suspension. It’s a Super fun car to drive….endless burnouts for days and Sooo much fun to power slide through long corners…lol. Attached thumbnail(s) Attached image(s) |
Chad911sc |
Dec 24 2024, 12:47 PM
Talked to the machine shop today and they ended up taking .010 off of the deck to flatten it out on the crankshaft line, and .030 off of the heads to get me down to the 54cc target for my desired compression ratio. Pretty much what I was thinking.
Can’t wait to get back to Florida and start the assembly process once more! Thanks again for all your help guys! So glad I listened to your advice and tore it back apart (IMG:style_emoticons/default/beerchug.gif) |
technicalninja |
Dec 24 2024, 01:02 PM
Advanced Member Group: Members Posts: 2,119 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region |
Will .010 give you the deck height you needed?
I thought you needed .013 from your initial post... I'd have gone a little bit deeper allowing for shimming. If your using cast pistons it will probably work fine at .037 but that is getting close in my book. |
Jack Standz |
Dec 24 2024, 03:01 PM
Member Group: Members Posts: 419 Joined: 15-November 19 From: Happy Place (& surrounding area) Member No.: 23,644 Region Association: None |
Merry Christmas everyone!
Well, you'll figure out the next step when you measure everthing and do the mock-up. Fingers crossed that you're not too tight on the deck height. As technicalninja says, you don't want to be too close. Pistons hitting valves do tend to ruin one's day (IMG:style_emoticons/default/smile.gif) . But, sometimes we do tend to push the envelope. And sometimes the envelope pushes us. For a 2056, you don't need to cut it that close anyway and they are a fun motor in a 914. |
technicalninja |
Dec 24 2024, 03:41 PM
I always check deck height of ALL of the pistons.
As tight as you are, make SURE you don't have one that is .002 different. "Pop goes the Weasel" is what you want to avoid at all costs. I sort of expect you know this already! It's more for the other folks watching the thread... I would not release a customer job that tight. MIGHT use that shit myself... You WANT to decrease piston to head clearance as much as possible in my book. Close should be better! Right up till the point the pistons KISS the head which always hurst the motor and sometimes DESTROYS EVERYTHING... Have a Merry Christmas! Rick |
Chad911sc |
Dec 25 2024, 09:35 AM
Merry Christmas Everyone!!
After I had hand lapped the registers and rechecked my deck height on 2 of the cylinders I was at .050 total, so I should be right at .040 now that the deck has been decreased by .010 I figured I should be between .038 - .040 I always try to get my squish right at the perfect spot for combustion burn efficiency. I will definitely clay check it on every cylinder to see exactly what my piston to head clearance is…. Thanks again guys!! |
technicalninja |
Dec 25 2024, 10:09 AM
Will .010 give you the deck height you needed? I thought you needed .013 from your initial post... I'd have gone a little bit deeper allowing for shimming. If your using cast pistons it will probably work fine at .037 but that is getting close in my book. The above (and the next post from me) is TOTAL BS! I even sucked Jack Standz in... I got the math BACKWARDS AGAIN!!!! (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) It looks like he didn't remove ENOUGH material. This would have put the piston DOWN the bore, not up. He's NOT tight, he's loose!!!! I'm happy he rechecked his shit and choose the proper amount to remove. In my book .040 is OPTIMAL and safe enough to release to non-technical folks. He's as TECHNICAL as I am... I still suggest checking all of them and (this might be important!) check to verify the jug fins are NOT hitting the head. The check I did for him on register depth on my stock junk was eye opening! It looked like either fly cutting head OR cutting top of jugs would require doing something to the fin section of the jug. Without the original compression ring it looked like they ALMOST touched the head in STOCK form! And I truly believe, on pump gas, the deck height is the MOST important measurement to get right. Something without quench pads, something using fuel that is not prone to detonate, it's not nearly as critical. But for the crap we can get out of a commercial pump (besides E/85) deck height is stupid important... Merry Christmas all! (IMG:style_emoticons/default/ninja.gif) Edit: Everyone, even brand-new members, can add good info to the forum. Chad has given me a small Christmas present (and he didn't even try!). This guy has a functional turbocharged air-cooled VW (the Sun Bug) at 220 hp! I want to know ALL about that set up! I VASTLY prefer to force feed engines below 3.5L It's my NORMAL recipe. I automatically discounted "turbo" due to the limitations of the T4. Might have been short sighted... I hope "Nickies" are not part of the equation; blows budget bigtime. Chad, we will have PM conversations regarding this after the holidays. And LOTS of folks on here would be interested in turbocharging the T4. It would make a KILLER thread on its own! |
sixnotfour |
Dec 25 2024, 03:24 PM
914 Wizard Group: Members Posts: 10,681 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
OMG...
porschetub |
Dec 25 2024, 08:29 PM
Advanced Member Group: Members Posts: 4,754 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
OMG... (IMG:style_emoticons/default/agree.gif) ,hopefully for the same reason ?,that last reply made little sense to me . |
technicalninja |
Dec 26 2024, 10:19 AM
I have a disease….. Project mania…lol Love to build stuff and can’t say no when I see something in my reach. I have some of them done, but most are still works in progress. 1) my daily driver, she is my true love. 15 years of daily driver flawless service! 2004 4Runner. 2) My first car from 1986 that I still have. Building it for my now 17 years old daughter. It’s a 74 Sun Super Bettle. Has 2110 turbo, 220 hp on water dyno 3) 1979 911sc Max Moritz German born import. Finished painting about a year ago, but this is how she still sits. 4) 1969 beetle with 2.5L turbo STI forged stuffed into it. Crazy amount of fab work. Done with everything but body and paint. 5) 1998 C5 naturally aspirated 470rwhp on the dyno….so much fun! 6) 1972 CJ5 lifted on 39.5’s with hydraulic assisted steering and 4 wheel disk brakes. First V8 that Jeep made AMC 304. 7) My daughters go kart 8) Dads go kart with forged internals of course..lol 9) 2006 Buell 1250 scg 10) 2006 Screamin’ Eagle V-rod 11-12) YSR 50 and the yellow one is a YSR with a IT 175 2 stroke 6 speed with custom frame and reinforced swing arm. Clocked at 87 mph in a 25 speed limit by local policemen in my neighborhood. He let me go (IMG:style_emoticons/default/first.gif) 13) 1991 FZR 400 with 632 big bore Wiseco motor stuffed into it. Also very fun little corner ripper that I take to the Dragon in Tennessee every couple of years. I do all my own work on everything and nothing has stickers on them…all paint. Oh yeah…and last but not least the 74 2.0 Olympic blue 914 that I’m currently building a 2056 for. Actually, just the math was bad. The rest of the posts were fine. I do not like to make simple mistakes. "In front of me" I'd have been fine. Sometimes "over the keyboard" can create confusion. In the "show us what you've got thread" Chad911sc posted this tidbit "2) My first car from 1986 that I still have. Building it for my now 17 years old daughter. It’s a 74 Sun Super Bettle. Has 2110 turbo, 220 hp on water dyno" He's got a bunch of nice stuff but that caught my eye as it is the most Type4 like. I'd like to know how that was done, how long it's run, and what problems he's had along the way. I'd stay Type4 on my 75 if I could make that type of power without spending 20K... |
emerygt350 |
Dec 26 2024, 03:37 PM
Advanced Member Group: Members Posts: 2,516 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
No kidding. I think it would be fun to try and build something like that. I wonder what boost and compression look like.
Lo-Fi Version | Time is now: 27th December 2024 - 08:46 AM |
