Installing the shifter springs |
jrrobertson |
Jan 11 2025, 09:03 PM
Newbie Group: Members Posts: 42 Joined: 28-December 16 From: Wolverine Lake , Michigan Member No.: 20,704 Region Association: Upper MidWest |
Garland |
Jan 11 2025, 09:14 PM
Restoration Fanatic Group: Members Posts: 1,400 Joined: 8-January 04 From: ......Michigan...... Member No.: 1,535 Region Association: Upper MidWest |
jrrobertson |
Jan 11 2025, 09:19 PM
Thanks, John. See you Monday.
Shivers |
Jan 11 2025, 09:38 PM
Senior Member Group: Members Posts: 2,867 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
I did the punch but I grabbed the other end with vice grips and forced the spring into the other holes location. Then moved the vice grips tilting sideways to start flattening the spring into place as I am putting pressure on the punch to drive it through the spring to the other holes location. It worked really well even with limited room.
Jan 11 2025, 10:16 PM
Custom Member Group: Members Posts: 24,695 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
A vice is much safer….just sayin
Jan 12 2025, 05:59 AM
914-6 GT in waiting Group: Members Posts: 19,696 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
However you do it, wear eye protection
Lo-Fi Version | Time is now: 12th January 2025 - 06:58 AM |
