Cup Holder, Simple Option |
jdamiano |
Jan 13 2025, 03:01 PM
Member Group: Members Posts: 336 Joined: 18-March 18 From: Jacksonville Member No.: 21,981 Region Association: South East States |
Wife told me last weekend she needed a cup holder before she would ride with me again. I got the one below made for a chair but it was perfect for a 914.
https://www.amazon.com/dp/B0BTYMS7HT/ref=em...?th=1&psc=1 Attached thumbnail(s) |
930cabman |
Jan 13 2025, 03:18 PM
Advanced Member Group: Members Posts: 3,874 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
lucky you, wife won't ride with me "too fffiinn stinky"
sb914 |
Jan 13 2025, 03:34 PM
Surf Guru Group: Members Posts: 4,430 Joined: 25-November 12 From: Brookings,Oregon Member No.: 15,191 Region Association: Southern California |
Looks like it’s made for it .
ClayPerrine |
Jan 13 2025, 05:07 PM
Life's been good to me so far..... Group: Admin Posts: 16,064 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
lucky you, wife won't ride with me "too fffiinn stinky" Could be worse... I have to ride "bitch". (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/driving-girl.gif) (IMG:style_emoticons/default/betty914.jpg) |
Osnabruck914 |
Jan 13 2025, 06:07 PM
Member Group: Members Posts: 98 Joined: 19-December 22 From: United States Member No.: 27,038 Region Association: South East States |
Or you can do this -
Go to a pick & pull junkyard and find yourself a suitable cup holder, 90's cars are usually the best. Then procure a spare center console cushion (don't sacrifice your original!). Carve out a cylinder in the cushion for the holder to sit in flush as you can get it. Paint the cup holder to match your interior scheme. The holder I used also has a removable ash tray with a hinged lid that I use as a spare change holder, that just pops out when you want to use the cup holder portion. |
worn |
Jan 13 2025, 06:10 PM
Winner of the Utah Twisted Joint Award Group: Members Posts: 3,417 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
Or you can do this - Go to a pick & pull junkyard and find yourself a suitable cup holder, 90's cars are usually the best. Then procure a spare center console cushion (don't sacrifice your original!). Carve out a cylinder in the cushion for the holder to sit in flush as you can get it. Paint the cup holder to match your interior scheme. The holder I used also has a removable ash tray with a hinged lid that I use as a spare change holder, that just pops out when you want to use the cup holder portion. I did the same thing with a pair of ss cup holders purchased from a yachting supplier. I can think of 914 adds with horses and airplanes but cannot recall one with a yacht. Maybe 914s don’t float so well. |
Geezer914 |
Jan 14 2025, 07:08 AM
Geezer914 Group: Members Posts: 1,832 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States |
Here is mine.
930cabman |
Jan 14 2025, 09:54 AM
East coaster |
Jan 14 2025, 10:11 AM
Senior Member Group: Members Posts: 1,811 Joined: 28-March 03 From: Millville, NJ Member No.: 487 Region Association: None |
friethmiller |
Jan 14 2025, 10:15 AM
Senior Member Group: Members Posts: 751 Joined: 10-February 19 From: Austin, TX Member No.: 22,863 Region Association: Southwest Region |
... and I was just perfecting the "one-hand on the coffee and steering wheel while shifting" technique. (IMG:style_emoticons/default/biggrin.gif) I need a cup holder bad!
Olympic 914 |
Jan 14 2025, 10:26 AM
Group: Members Posts: 1,713 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
mb911 |
Jan 14 2025, 10:40 AM
914 Guru Group: Members Posts: 7,473 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Cairo94507 |
Jan 14 2025, 06:11 PM
Michael Group: Members Posts: 10,204 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
Shower daily? (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/av-943.gif)
Jan 14 2025, 10:54 PM
Custom Member Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
An old cylinder sitting on the passenger floor works well.
There is also a bolt on rennline cup holder you can use |
ClayPerrine |
Jan 15 2025, 06:59 AM
I bought one of the 911 cup holders that is designed to mount to the seat rail. Here is a picture of it:
Then I took out the 6x1.0 screw in the knee pad below the heater controls, and replaced it with a stud and a long coupler nut. I bolted the cup holder to the coupler nut. That way I could swing it out of the way when not in use, and it was easy to reach from the driver's seat. Even a large Wataburger cup would fit with no problems. But it won't hold a can or bottle because it has no bottom. There are others out there that are similar with bottoms to support cans. After I put in the Cayman shifter, I moved the cupholder to the mount on the front of the shifter. |
FlacaProductions |
Jan 15 2025, 09:35 AM
Senior Member Group: Members Posts: 1,871 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
Superhawk996 |
Jan 15 2025, 10:07 AM
914 Guru Group: Members Posts: 6,713 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Germans could never understand Merica’ and its fascination with cupholders. (IMG:style_emoticons/default/rolleyes.gif)
mxkinn01 |
Jan 15 2025, 02:08 PM
Member Group: Members Posts: 252 Joined: 18-June 17 From: Las Vegas, NV Member No.: 21,195 Region Association: Southwest Region |
burton73 |
Jan 15 2025, 02:50 PM
Senior member, and old dude Group: Members Posts: 3,754 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
I personally like the idea If you need one for a trip. I like the fixes you guys are coming up with that you just put it on and take it off easily I'm liking it although I'm never going to go for a run that long but, maybe a little water to take pills but then I got to pee.
The ones with the stock astray slot is also a very clever way of doing it as nobody smokes anymore or should I say that very few of our people smoke anymore, sorry Jimmy and JD Best Bob B (IMG:style_emoticons/default/bye1.gif) (IMG:style_emoticons/default/bye1.gif) |
ClayPerrine |
Jan 15 2025, 03:57 PM
I personally like the idea If you need one for a trip. I like the fixes you guys are coming up with that you just put it on and take it off easily I'm liking it although I'm never going to go for a run that long but, maybe a little water to take pills but then I got to pee. The ones with the stock astray slot is also a very clever way of doing it as nobody smokes anymore or should I say that very few of our people smoke anymore, sorry Jimmy and JD Best Bob B (IMG:style_emoticons/default/bye1.gif) (IMG:style_emoticons/default/bye1.gif) The only thing smoking these days is the engine on a 914... due to the oil leaks. (IMG:style_emoticons/default/happy11.gif) |
Lo-Fi Version | Time is now: 5th February 2025 - 12:05 PM |
