gandalf_025 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,481 Joined: 25-June 09 From: North Shore, Massachusetts Member No.: 10,509 Region Association: North East States ![]() |
Looking for the front fuel line grommet for my 1970.. Somehow misplaced mine and I can't seem to find one new.. It is the one with openings for both fuel lines to go through.
part no. 91435654300 also labeled 25/1 on a few diagrams I have seen. Thanks |
914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,089 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
Let me look in warehouse tomorrow. Freebie IF I have one.
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() Group: Members Posts: 4,803 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
@gandalf_025
' date='Feb 5 2025, 05:01 PM' post='3190472'] Looking for the front fuel line grommet for my 1970.. Somehow misplaced mine and I can't seem to find one new.. It is the one with openings for both fuel lines to go through. part no. 91435654300 also labeled 25/1 on a few diagrams I have seen. Thanks [/quote] I may have one it Mark does not. I think the early one has two equal size holes. |
bdstone914 |
@gandalf_025
Now that I think about it i believe the 1970 uses two smaller grometts unlike the larger block one on later cars. @914sixer |
gandalf_025 |
Well. I wasn't aware there were different grommets for early and late cars..
I have no idea if they are different from a 4 to a 6. either.?? My car is up on a lift in an unheated garage and it is snowing so I won't be able to see exactly which version I actually need.. Thanks Guys.. But I guess I need to do more research.... |
914werke |
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,139 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest ![]() ![]() |
Now that I think about it i believe the 1970 uses two smaller grometts unlike the larger block one on later cars. I dont ever recall seeing a setup like that, what I do recall on ealy cars is that the plastic lines were not tipped with metal hardlines.. but the grommet would have asemtrical sized holes. Only later did they go to the x2 smaller dia. hose/holesThe other difference on that late grommet is the 3rd hole for the 4mm vapor line. I have them HERE |
914Sixer |
I did NOT have one. Check with Bruce
bdstone914 |
Now that I think about it i believe the 1970 uses two smaller grometts unlike the larger block one on later cars. I dont ever recall seeing a setup like that, what I do recall on ealy cars is that the plastic lines were not tipped with metal hardlines.. but the grommet would have asemtrical sized holes. Only later did they go to the x2 smaller dia. hose/holesThe other difference on that late grommet is the 3rd hole for the 4mm vapor line. I have them HERE I member parting out one early cars that had two single grommets. Not sure if PET even lists them. |
bdstone914 |
@gandalf_025
date='Feb 6 2025, 01:05 PM' post='3190603'] Well. I wasn't aware there were different grommets for early and late cars.. I have no idea if they are different from a 4 to a 6. either.?? My car is up on a lift in an unheated garage and it is snowing so I won't be able to see exactly which version I actually need.. Thanks Guys.. But I guess I need to do more research.... [/quote] Get in there when you can and check the hole(s) for the fuel lines |
gandalf_025 |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,786 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
Chris at tangerine racing usually has the needed parts.
bdstone914 |
914werke |
thats why I love this place, after playing & working on these cars for years you can still learn something.
aturboman |
Member ![]() ![]() Group: Members Posts: 147 Joined: 18-October 11 From: CA Member No.: 13,687 Region Association: None ![]() |
914werke |
I don't believe it changed to the large single grommet until late 74 possibly 75 when the pump got moved up front. Nope. 73-74 certainly used the 2 hole grommet. I have broken a lot of cars but looking back, fewer of the very early cars thus my unfamiliarity (or is it just old age (IMG:style_emoticons/default/rolleyes.gif) ). Now comes the originality question what MY did the factory change the chassis & simplify the grommet .. 70-71, 71-72? |
gandalf_025 |
Just to clarify, my car is a relatively
early 914/6. # 619 |
914Sixer |
Same gromet as VW speedometer cable
Attached thumbnail(s) ![]() |
gandalf_025 |
And then this…????
For a couple of rubber grommets..??? ![]() |
bdstone914 |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,150 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
And then this…???? For a couple of rubber grommets..??? How is is NOT obvious that this is a scammer??? (IMG:style_emoticons/default/confused24.gif) http://www.914world.com/bbs2/index.php?s=&...t&p=2942463 |
Lo-Fi Version | Time is now: 14th March 2025 - 11:36 AM |
