| SteveNMaine |
Feb 9 2025, 06:26 AM
Member ![]() ![]() Group: Members Posts: 94 Joined: 12-August 24 From: Maine Member No.: 28,288 Region Association: None |
Hey, has anyone restored the compressed shape of a 914 thermostat? The one I have has expanded and does not appear to have any leaks.
I have removed the solder on the threaded end which revealed a ball bearing. I removed the ball bearing and tested for leaks by compressing the unit and plugging the hole. It kept the semi-compressed shape for several hours and when I removed the plug, air rushed in and it expanded again. Is there a way to restore it to its completely compressed shape at idle so-to-speak? |
| mepstein |
Feb 9 2025, 08:55 AM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,294 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
Not really.
| Krieger |
Feb 9 2025, 09:37 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,829 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None
Awesome powder coating makes brand new and correct ones for our car. A few years back I sent them an original one of my 914 they "restored". I believe they reused the ends of mine and replaced the center bellows and whatever gas is inside. It was almost the same cost as one of their new thermostats.
| Jack Standz |
Feb 9 2025, 01:18 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 625 Joined: 15-November 19 From: Happy Place (& surrounding area) Member No.: 23,644 Region Association: None
I have not restored one. I think Hot VWs did an article on it years ago that you might find in their archives.
But, it looked tedious, so I've collected working ones from any junkyard motors over the years, including VW buses. |
| JeffBowlsby |
Feb 9 2025, 01:45 PM
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,141 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None
| 930cabman |
Feb 9 2025, 01:55 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,375 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States
I am probably in the minority here, but my recent (2 years ago) 2056 build I did not have a working t stat and thought I would try things out and see how it goes.
Well, it works great without the t stat. Warms up very quickly so far as repairing the original, not sure if it's possible. AFAIK it is a sealed unit |
| 914sgofast2 |
Feb 9 2025, 08:32 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 782 Joined: 10-May 13 From: El Dorado Hills, CA Member No.: 15,855 Region Association: None |
The originals can be repaired if the bellows does not have hairline cracks. But after 50+ years, good luck with that. The "magic" fluid used in the thermostats is simply denatured rubbing alcohol. I remember finding an article somewhere on how to fix them on either the 914World.com, PelicanParts.com, or on the Samba.com websites. You will need some good soldiering skills to do it properly. I found it easier to just buy a new thermostat from AwesomePowdercoat.com.
| SteveNMaine |
Feb 10 2025, 07:11 AM
The originals can be repaired if the bellows does not have hairline cracks. But after 50+ years, good luck with that. The "magic" fluid used in the thermostats is simply denatured rubbing alcohol. I remember finding an article somewhere on how to fix them on either the 914World.com, PelicanParts.com, or on the Samba.com websites. You will need some good soldiering skills to do it properly. I found it easier to just buy a new thermostat from AwesomePowdercoat.com. Yes, I found those restore/repair instructions as well. I am going to try to fix it before I order a new one. |
| ClayPerrine |
Feb 10 2025, 12:11 PM
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,526 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille
And if you do use them, please check them to make sure they work. Having the flaps stay closed could potentially ruin your engine.
So with the flaps connected, use a heat gun to warm up the thermostat and make sure the flaps open up fully. |
| DC_neun_vierzehn |
Feb 10 2025, 07:59 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 613 Joined: 16-November 20 From: Coastal Delaware Member No.: 24,893 Region Association: MidAtlantic Region
I see a few parts for 914s, but I don’t see a thermostat. https://www.awesomepowdercoat.com/type-iv-p...hermostat-parts |
| jvmarino |
Feb 10 2025, 08:24 PM
Member ![]() ![]() Group: Members Posts: 100 Joined: 22-March 09 From: Baltimore Member No.: 10,188 Region Association: None |
| SteveNMaine |
Feb 13 2025, 11:58 AM
Hey, has anyone restored the compressed shape of a 914 thermostat? The one I have has expanded and does not appear to have any leaks. I have removed the solder on the threaded end which revealed a ball bearing. I removed the ball bearing and tested for leaks by compressing the unit and plugging the hole. It kept the semi-compressed shape for several hours and when I removed the plug, air rushed in and it expanded again. Is there a way to restore it to its completely compressed shape at idle so-to-speak? I went through the procedure on www.ratwell.com/technical/Thermostats.html and it worked perfectly. |
| SteveNMaine |
Mar 28 2025, 04:22 AM
I was able to restore it.
| brant |
Mar 28 2025, 09:14 AM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,113 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains
better to run a working thermostat than to leave it off entirely.
your motor... but the warm up difference does promote longevity of the motor. |
| rick 918-S |
Mar 30 2025, 09:04 AM
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 21,144 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region
I repaired one. It worked but I would rather purchase a new one. I have purchased from Awesome Powder Coat. Great experience.
| Puebloswatcop |
Mar 30 2025, 07:09 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,690 Joined: 27-December 14 From: Mineola, Texas Member No.: 18,258 Region Association: Southwest Region |
I agree with Rick. I too repaired one once. The results were a bit disapointing. It worked but would never open the flaps completely. So it is worth the $144. at APC
| SVG223 |
Mar 30 2025, 09:58 PM
Member ![]() ![]() Group: Members Posts: 115 Joined: 6-February 22 From: Benton Arkansas Member No.: 26,317 Region Association: None |
I've got one on the way from Awesome Powder Coat. I don't know how long it has been driven without one. It takes way too long to warm up without it.
| Ron914 |
Dec 18 2025, 02:14 PM
Member ![]() ![]() Group: Members Posts: 473 Joined: 19-April 22 From: Huntington Beach,Ca Member No.: 26,487 Region Association: Southern California
Has anyone purchased one of these yet .Almost $100 difference ?
| Ron914 |
Dec 18 2025, 02:19 PM
I now see what I missed
| porschetub |
Dec 18 2025, 06:11 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,977 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
I now see what I missed Do you mean the one that AA sell ?, they say ( George ) that they have had no issues with them but they just say that about all sorts they sell so take that as you like ,these unit have no "failsafe" like the OEM one , if they fail the cooling flaps close and the result isn't nice . Best to research as I did certainly not the best option to save $100 IMO. cheers. |
Lo-Fi Version | Time is now: 19th December 2025 - 05:44 AM |
