Craigers17 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 834 Joined: 5-August 17 From: Rome, GA Member No.: 21,317 Region Association: South East States ![]() ![]() |
Just for shits and grins, have you tried to run something through the tube that has a little less girth? I'd be interested to see if you could push something smaller through there and actually physically see it or grab it at the accelerator end of the tunnel. This would at least give you a good idea if the thing was still all together and mostly "open". If so, you'd have a good idea that, as previously mentioned, maybe the end is just a little corroded, out of round, etc.
Tdskip |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,727 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None ![]() ![]() |
Tdskip |
Just for shits and grins, have you tried to run something through the tube that has a little less girth? I'd be interested to see if you could push something smaller through there and actually physically see it or grab it at the accelerator end of the tunnel. This would at least give you a good idea if the thing was still all together and mostly "open". If so, you'd have a good idea that, as previously mentioned, maybe the end is just a little corroded, out of round, etc. I did get a coat hanger into the opening and it seemed ok. Will try something a big larger. I think the tube is slightly collapsed near the opening. Thanks for the suggestion! |
PlaysWithCars |
Senior Member ![]() ![]() ![]() Group: Members Posts: 532 Joined: 9-November 03 From: Southeast of Seattle Member No.: 1,323 Region Association: Pacific Northwest ![]() ![]() |
Slide a Phillips screw driver and wooble it around..the the tube is out of round ... A reassuring technical description from an ace engine builder. (IMG:style_emoticons/default/lol-2.gif) fully appreciate the practical approach. |
Tdskip |
Philips head wobble technique didn’t work (or at least not yet).
Tried a drill bit (with nice grips so gently) and it’s catching on something. Should I get power to the drill bit to see if I can remove the edge it is catching on? Seem a bit desperate, which wouldn’t be a wrong conclusion at this point. Ha. ![]() |
Superhawk996 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,894 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch ![]() ![]() |
Should I get power to the drill bit to see if I can remove the edge it is catching on? Seem a bit desperate, which wouldn’t be a wrong conclusion at this point. Ha. Bad plan The tube doesn’t go straight for any significant distance and you’ll drill into the side of it (or through it) if not careful. Review the picture of what you’re dealing with http://www.914world.com/bbs2/index.php?showtopic=373723 |
Tdskip |
Should I get power to the drill bit to see if I can remove the edge it is catching on? Seem a bit desperate, which wouldn’t be a wrong conclusion at this point. Ha. Bad plan The tube doesn’t go straight for any significant distance and you’ll drill into the side of it (or through it) if not careful. Review the picture of what you’re dealing with http://www.914world.com/bbs2/index.php?showtopic=373723 That’s why I asked first! Those pictures are very helpful, thanks for the link. |
Superhawk996 |
Be aware there is a lot of variance in how and when the cable tube begins to bend
Here is my car when I rebuilt the tubes from scratch - the accel cable tube goes in straight for a while You might get by with a variable speed drill and turning it very slowly but I’d only do that as an absolute last resort ![]() I might try a rat tail file first before the drill A file is a lot better at dealing with hardened material if there is some sort of weld / braze slag inside the tube |
Tdskip |
Any chance the replacement cables have larger fittings?
Ron914 |
Member ![]() ![]() Group: Members Posts: 169 Joined: 19-April 22 From: Huntington Beach,Ca Member No.: 26,487 Region Association: Southern California ![]() ![]() |
Good morning Tom , @Tdskip
I found these photos on the internet somewhere of the tunnel exposed to help me see what goes on in there . I don't know what year of 914 they came from but the helped and I saved them for future use if ever needed. ![]() ![]() ![]() |
Ron914 |
Attached thumbnail(s) ![]() |
Superhawk996 |
Any chance the replacement cables have larger fittings? You already posted a picture of it in the tube hitting some obstruction so you know it fits. The rest is a question of what is in the tube or why it’s not straight enough to allow the cable fitting to pass. Focus on why your tube is not allowing the cable to pass: 1) tube kinked at firewall and doesn’t go straight long enough 2) residual plastic sleeve stuck in the tube 3) rust bump or brazing debris as deformed the interior of the tube 4) tube can be inspected from inside the tunnel via access panel at rear of tunnel You’ve been vague about what you’ve tried and what’s going on. Drill should be the last resort once you are sure the tube is straight. If you break a drill off in the tube there is a whole new level of being screwed. |
Tdskip |
Thanks for all of the replies and attempts to help.
1) old cable came out fine 2) old cable can be reinserted without issue 3) new cable is blocked from going in once it gets partially into the firewall 4) I have inserted an Allen key and wobbled it around 5) I have not tried tapping for further forcing of the new cable past where it gets stuck for fear of it getting really stuck 6) I have not drilled anything and won’t This leads me to a strong suspicion that the new cable is the wrong size diameter |
Tdskip |
Ron914 |
You probably don't remember me Tom but I purchased a smog pump from you and a couple of other things last year at your shop cleanup you had . Your problem is definitely a strange one with that tube blockage.
Tdskip |
OK - got it!
In the end it was the tube being much more bent out of alignment than I realized. The plastic sheath would go in because it was flexible but the threaded metal pallet can’t bent so it got stuck. After looking at all the pictures again I figured out how it should be aligned and that did the trick. Thank You all very much. |
Tdskip |
You probably don't remember me Tom but I purchased a smog pump from you and a couple of other things last year at your shop cleanup you had . Your problem is definitely a strange one with that tube blockage. Of course I remember Ron, it was a pleasure to meet you! |
Ron914 |
You probably don't remember me Tom but I purchased a smog pump from you and a couple of other things last year at your shop cleanup you had . Your problem is definitely a strange one with that tube blockage. Of course I remember Ron, it was a pleasure to meet you. likewise |
914werke |
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,177 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest ![]() ![]() |
Dlee6205 |
Member ![]() ![]() Group: Members Posts: 56 Joined: 9-December 22 From: Burnsville, NC Member No.: 27,017 Region Association: South East States ![]() |
YES! Carefully ... Ive had to do this MANY times due to tubes bent outta shape. (IMG:style_emoticons/default/agree.gif) Same. Between the aftermarket cables and the tubes sometimes being bent, I trim down the back edge so it clears. It doesn't take much. Glad you got it resolved. |
Lo-Fi Version | Time is now: 31st March 2025 - 03:31 AM |
