SVG223 |
Member ![]() ![]() Group: Members Posts: 59 Joined: 6-February 22 From: Benton Arkansas Member No.: 26,317 Region Association: None ![]() |
195/65/15 Stock Fuchs. Turning radius restricted. Just parking, and U-turns. Would a 1/2" wheel spacer help?
Attached thumbnail(s) ![]() ![]() ![]() ![]() |
bkrantz |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,241 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains ![]() ![]() |
What are your camber and caster settings?
SVG223 |
What are your camber and caster settings? Got no clue. The front wheels look straight up perpendicular to the ground. It doesn't look like much negative camber when the car is on the ground. The car is on jack stands in these pictures. The car handles stable at high speed. I will look into the alignment as a possible cause. Thanks. It's not a big deal, I just remember the car I had in the 80s had a tighter turning circle. My Grand Cherokee turns tighter. |
mgp4591 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,562 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region ![]() ![]() |
I'd think a 195/65 sounds a little tall. Stock size is much thinner than a 195 and the cars I've seen only run a 55 or 60 in a 195. I'm not sure about stock wheels and tires, only what I'm seeing...I've got 17s.
gonzo54 |
Orange Crush ![]() ![]() Group: Members Posts: 252 Joined: 10-May 19 From: Seal Beach, CA Member No.: 23,112 Region Association: Southern California ![]() ![]() |
I have the same size tires with no interference/rubbing
Attached thumbnail(s) ![]() |
mgp4591 |
Oops, double post,
SVG223 |
SVG223 |
I'd think a 195/65 sounds a little tall. Stock size is much thinner than a 195 and the cars I've seen only run a 55 or 60 in a 195. I'm not sure about stock wheels and tires, only what I'm seeing...I've got 17s. The car came with 205/70/15, I didn't know that size would fit. They had plenty of tread but I got rid of them when I looked up the date code. |
SVG223 |
After considering the questions posed by @bkrantz , I am now thinking I have a little too much caster. In my 15 minutes of research, having too much caster has some benefits I may not want to do without.
mgp4591 |
I'd think a 195/65 sounds a little tall. Stock size is much thinner than a 195 and the cars I've seen only run a 55 or 60 in a 195. I'm not sure about stock wheels and tires, only what I'm seeing...I've got 17s. The car came with 205/70/15, I didn't know that size would fit. They had plenty of tread but I got rid of them when I looked up the date code. Seeing your post about too much caster, that may be why I see so many running a smaller size...the guys I know run the in the full caster position. |
mgp4591 |
I'd think a 195/65 sounds a little tall. Stock size is much thinner than a 195 and the cars I've seen only run a 55 or 60 in a 195. I'm not sure about stock wheels and tires, only what I'm seeing...I've got 17s. The car came with 205/70/15, I didn't know that size would fit. They had plenty of tread but I got rid of them when I looked up the date code. Smaller sidewalls will also give you quicker response... |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,765 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
I’ve ran 195x65x15 with 2.0 Fuchs on quite a few 914’s without tire rub. Also 205x60x15. You should be able to set it up so no rubbing occurs.
Currently I have 205x60x15 on 6” cookies without tire rub. Nothing special was done to make everything fit. |
burton73 |
Senior member, and old dude ![]() ![]() ![]() ![]() Group: Members Posts: 3,782 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California ![]() ![]() |
Are you saying in a parking situation super tight turn or are you talking about general turning on the road or a Right turn?
I used these on my 6 https://www.elephantracing.com/porsche/914/...rub-prevention/ By the way PMB can fix you up with this Best Bob B ![]() |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,122 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
That doesn't look right.
Does your car show any signs of ever being hit in the front? Are both inner fenders smooth inside the front trunk? Or do they show signs of buckling? (IMG:style_emoticons/default/popcorn[1].gif) |
SVG223 |
Are you saying in a parking situation super tight turn or are you talking about general turning on the road or a Right turn? I used these on my 6 https://www.elephantracing.com/porsche/914/...rub-prevention/ By the way PMB can fix you up with this Best Bob B ![]() Just parking, and U-turns. I don't think I want to limit my steering range. I will need to think about this for a bit. I may back off of the caster some. I may try a small wheel spacer. Not sure. |
SVG223 |
That doesn't look right. Does your car show any signs of ever being hit in the front? Are both inner fenders smooth inside the front trunk? Or do they show signs of buckling? (IMG:style_emoticons/default/popcorn[1].gif) Everything looks smooth and straight. I'm adding a picture of the strut tower for an alignment reference. |
SVG223 |
Strut tower for vague alignment reference.
It looks like I have 0 front camber by looking at the wheel angle to the road. It looks like I have a good bit of positive caster. Attached thumbnail(s) ![]() |
That doesn't look right. Does your car show any signs of ever being hit in the front? Are both inner fenders smooth inside the front trunk? Or do they show signs of buckling? (IMG:style_emoticons/default/popcorn[1].gif) Everything looks smooth and straight. I'm adding a picture of the strut tower for an alignment reference. Show us some pics of the front fenders from inside the trunk ... (IMG:style_emoticons/default/idea.gif) |
SVG223 |
That doesn't look right. Does your car show any signs of ever being hit in the front? Are both inner fenders smooth inside the front trunk? Or do they show signs of buckling? (IMG:style_emoticons/default/popcorn[1].gif) Everything looks smooth and straight. I'm adding a picture of the strut tower for an alignment reference. Show us some pics of the front fenders from inside the trunk ... (IMG:style_emoticons/default/idea.gif) Attached thumbnail(s) ![]() |
The good news, your fenders look fine.
However, what the heck is going on with your suspension? The top rubber is completely whacked on both sides. (IMG:style_emoticons/default/blink.gif) Do you have the car jacked up in the air on both sides with the suspension hanging freely? (IMG:style_emoticons/default/confused24.gif) ![]() |
Lo-Fi Version | Time is now: 23rd February 2025 - 08:07 AM |
