> Into the Tunnel, Last chance to see before we button it up
zoomCat
post Mar 7 2025, 12:32 PM
Here's a view of the tunnel from the bottom with no floor pans:
This is an early car with a side shift conversion, stainless fuel lines, and the 914/6 hand throttle. The speedometer, throttle, and heater cables have not been installed.
I'll be adding a few more photos, but I'm putting these up with high resolution and only get one per post.
zoomCat
post Mar 7 2025, 12:44 PM
Another view:
NARP74
post Mar 7 2025, 12:48 PM
If only all that was accessible so you didn't have to build a ship in a bottle to work on it.
Thank you.
zoomCat
post Mar 7 2025, 12:50 PM
A better shot of the hand throttle:
And the business end:
Note that the bushing and nubbin on the end are missing here. I have put in a simple grommet to keep it from rattling around, but I'm looking for the real thing or a suitable substitute. Aase has NOS nubbins, yay!
jc73-914
post Mar 7 2025, 12:54 PM
cool ... thx for posting
zoomCat
post Mar 7 2025, 01:01 PM
This shows the clearance for the shift rod through the support. Early cars such as this had a circular hole, since the tail shifters had no lateral motion of the rod, only linear motion along the length and rotation. The hole was widened to accommodate the side shift conversion. This is roughly where neutral would be:
And here is where it would be for 1st/Reverse. It may not be apparent from this angle, but the rod would definitely collide with the support if it hadn't been modified.
Root_Werks
post Mar 7 2025, 01:16 PM
Village Idiot
So clean!
Looks great and yes, thank you for posting the pictures. Neat to see the inside of the tunnel like that.
zoomCat
post Mar 7 2025, 01:17 PM
The small brake line at the back is a bit convoluted, it has runs from the firewall to the access port in the tunnel where is joined by a union with the long line that runs the rest of the length to the front:
zoomCat
post Mar 7 2025, 01:18 PM
Another angle on the brake line:
zoomCat
post Mar 7 2025, 01:27 PM
And the brake union, normally accessible from the access port above it (behind in this picture). This also shows why long seat belt bolts interfere with the shifter.Attached Image
technicalninja
post Mar 7 2025, 01:33 PM
Nicely done!
The "attention to detail" is excellent.
And you've made us envious of your super sanitary tunnel...
(IMG:style_emoticons/default/first.gif)
ctc911ctc
Really like the rubber bumpers on the stainless fuel lines. Great idea. Not sure if I can do the same with the fuel lines that I purchased as a replacement in my 70, hmmm
zoomCat
post Mar 7 2025, 01:37 PM
I took a bunch of pictures from different angles, at fairly high resolution. If anybody has any specific requests I can try to get it out there.
mlindner
post Mar 7 2025, 02:14 PM
Very nice Guy, that tunnel is a busy place. Thanks for sharing.
ClayPerrine
post Mar 7 2025, 03:50 PM
QUOTE(zoomCat @ Mar 7 2025, 12:50 PM) *
For the end of the hand throttle rod you can use a vacuum cap. It works well.
worn
post Mar 7 2025, 07:36 PM
QUOTE(technicalninja @ Mar 7 2025, 11:33 AM) *
Nicely done!
No kidding. Abject envy.
Montreal914
post Mar 8 2025, 12:01 AM
Thank you for sharing this beautiful work!
Excellent documentation and very valuable pictures. Been studying the inside tunnel and capturing all the available web pictures (most of which come from here… obviously (IMG:style_emoticons/default/first.gif)). I will add those to my collection. Alway wondered how the side shift rod fitted in an early tunnel. Like the clearance for the lateral motion.
Really nice work!!! (IMG:style_emoticons/default/pray.gif)
DennisV
post Mar 8 2025, 09:30 AM
QUOTE(zoomCat @ Mar 7 2025, 10:50 AM) *
Thanks for sharing these photos. They will be helpful to a lot of people.
Regarding the "nub". I looked at NOS when putting ours back together. Given how our original disintegrated, I wasn't confident NOS would survive long. If you run into trouble with it, I created a 3D model.
brant
post Mar 8 2025, 09:53 AM
Put mechanics wire into the tunnel before you install the bottom cover to pull the cables through the routing ….
Much easier to install the cables (throttle/clutch/speedo) when the time comes) by attaching to the wire to pull them
930cabman
post Mar 8 2025, 09:56 AM
QUOTE(ClayPerrine @ Mar 7 2025, 04:50 PM) *
great tip, I have not been 100% pleased with the kit I installed, partially because it's a tough area to access. I will try a rubber cap on the end and also some sort of "bushing" to minimize the sloppiness at the bracket/rod
- Lo-Fi Version Time is now: 1st April 2025 - 05:17 PM
