914werke |
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,177 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest ![]() ![]() |
So Encountered a situation that puzzled me a bit: when working on a customers 74
L-jet 1.8L car found that plumbing the OE FI back onto car the hose sizing didnt work (IMG:style_emoticons/default/sad.gif) Particularly the Plenum outlet to the Decel valve on the R. of the eng bay. The Decel valve has 3 ports the 4mm on one side & on the other a Large hose to the intake Y then the smaller of the two on that side to the plenum (according to the hose diagram) but the plenum port is significantly smaller !! I checked with my parts stash (IMG:style_emoticons/default/rolleyes.gif) & indeed there is two plenums otherwise identical except for this port similar to early vs late plenums on D-Jet. Can someone someone more knowledgeable than I on L-Jet advise the MY this change took place & or if there are = Decel valve changes? Whoops wrong forum (IMG:style_emoticons/default/headbang.gif) section |
Lo-Fi Version | Time is now: 30th March 2025 - 09:34 PM |
