> Will not start after a 13-year hibernation, 1973 2.0 D-Jet
Alden
post Mar 26 2025, 07:33 PM
Ran well before storing in a dry shed.
Evaluated the fuel system and installed new:
fuel tank
fuel level sending unit
fuel tank screen
fuel filter
Cohline 2240 & Gates Barricade fuel hose
rebuilt Bosch 3 port fuel pump
(4) Standard Motor Products JF67 Injectors
Verified the stainless-steel tunnel and engine fuel lines are clear.
Applied 12 volts directly to the fuel pump to prime system. Fuel is circulating (can hear the gurgling of the return in the tank).
Ignition in the ON position the fuel pump primes (can hear running for 1-2 seconds).
Ignition in the START position fuel pump runs (verified with voltmeter, can't hear running due to engine cranking).
Ignition in the ON position apply throttle can hear fuel injectors click.
Engine will run with starting fluid.
Could it be fuel pressure? Fuel pressure regulator go bad from non-use or E10 fuel?
(E10 fuel destroyed my Cohline 2134 fuel hose and Bosch fuel pump)
Don't know if this could be a factor, sometimes in the START position, nothing, have to return to ON position and retry. Failing ignition switch?
What else should I look for?
Found a video from May 2017, started after sitting for 5 years.Attached File  Clip3.mov ( 2.42mb ) Number of downloads: 14
davep
post Mar 26 2025, 07:54 PM
914 Historian
Yes, it could certainly be the ignition switch, they do like to fail. The best solution is to add a heavy solenoid near the starter and use the wire from the ignition switch to activate the solenoid and it will in turn activate the starter. It was a bad idea to put such a heavy load on the ignition switch since it causes them to burn out. Look for Mark Henry's Ford solenoid solution.
http://www.914world.com/bbs2/index.php?showtopic=308904
Dlee6205
post Mar 26 2025, 08:41 PM
QUOTE(Alden @ Mar 26 2025, 09:33 PM) *
Check your fuel pressure with a gauge and go from there.
914outlaw
post Mar 26 2025, 09:08 PM
Dave
“ Ignition in the ON position apply throttle can hear fuel injectors click”
Can you check if each one is working properly? You them click, is it all of them?
emerygt350
post Mar 27 2025, 05:13 AM
verify fuel pressure. Try not to mess with anything else for the time being (if in fact it did "ran when parked").
The ignition is designed so you have to turn it off between starts attempts.
rgalla9146
post Mar 27 2025, 05:27 AM
Are your supply and return lines reversed ?
The ports on the fuel pump are marked.
Easy mistake to make.
Olympic 914
post Mar 27 2025, 06:51 AM
I see you are out in the Philly area.
Maybe someone from the Philly 914 MOB will respond. lots of talented guys out there.
someone may be close enough to come visit and get you going.
TheCabinetmaker
post Mar 27 2025, 10:10 AM
I drive my car everyday
I agree with Rgalla. Typical symptoms of reversed supply and return lines. Been there!
The fuel should not be returning to the tank while not running. The system will hold pressure.
VaccaRabite
post Mar 27 2025, 10:20 AM
En Garde!
Confirm fuel pressure with a gauge at the fuel pressure regulator.
It is very possible to switch the feed and return line somewhere, and that will keep you from running.
Your pressure regulator is a metal plate that pushes against a spring. Ethanol should not harm it. That said, put a gauge there and you will know for sure. My guess is that your fuel lines got reversed when you changed hoses. Really simple to do - I have done it myself.
Zach
rick 918-S
post Mar 27 2025, 10:49 AM
Hey nice rack! -Celette
QUOTE(TheCabinetmaker @ Mar 27 2025, 11:10 AM) *
(IMG:style_emoticons/default/agree.gif) easy to do.
- Lo-Fi Version Time is now: 31st March 2025 - 03:13 AM
