Vicious |
Newbie ![]() Group: Members Posts: 30 Joined: 31-October 22 From: South Dakota, USA Member No.: 26,958 Region Association: Upper MidWest ![]() |
The engine cooling fan on the motor that came with my car has several broken fins/blades. Looking for a replacement i can only seem to find used part? Does no one produce oem style or aftermarket replacements for this? Is used my only option?
Sorry if this has been covered. Did not find anything in the search. |
914werke |
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,177 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest ![]() ![]() |
Whats the problem with a solid OE pre-owned part?
Hate to break it to you but many if not most repop's aren't = quality to their originals ! To your Q: no Ive never seen a new impeller. |
Vicious |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,132 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
Not enough money in it to make new fans IMHO. Used ones are available, often for a reasonable amount of money. Just make sure not to get the "lightweight racing fan", because you already have one of those--it's a fan with blades broken off.
--DD |
Vicious |
JamesM |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,067 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region ![]() |
Just make sure not to get the "lightweight racing fan", because you already have one of those--it's a fan with blades broken off. --DD Got a good chuckle out of that, thank you Would be funnier if it were a joke. People actually sell them like this. |
mgphoto |
"If there is a mistake it will find me" ![]() ![]() ![]() Group: Members Posts: 1,371 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California ![]() |
brant |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,921 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains ![]() ![]() ![]() |
No blades is a good way to get no cooling for your heads
Probably ok if you rebuild the motor every weekend |
Root_Werks |
Village Idiot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,617 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest ![]() ![]() |
Here's a used one, couldn't tell you if it'd work on your 914 or not:
https://www.thesamba.com/vw/classifieds/det....php?id=1963112 |
GregAmy |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,468 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States ![]() ![]() |
If $299 is the going price for a good used one then I bet a lot of them will come out of the woodwork. Like the one sitting on the shelf in my garage attic storage.
cholland_ |
Member ![]() ![]() Group: Members Posts: 56 Joined: 11-October 06 From: Toronto, Ontario Member No.: 7,029 Region Association: None ![]() |
I've got one I've been trying to sell for about three years for $50 with no takers. Mine's even been blasted and repainted.
technicalninja |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,473 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region ![]() ![]() |
Verify timing marks.
My 75 1.8 fan has a single mark only at base timing of 7-8. It did not have either the TDC mark OR the total timing mark of 27-30. The 73 2.0L fan I replaced it with had TDC white and total timing red. You need the TDC mark for leak down testing. Using a flexible dress tape measure 1/2 way round both directions (splint difference) and make a 2nd TDC mark for the opposing cylinders. |
Root_Werks |
I've got one I've been trying to sell for about three years for $50 with no takers. Mine's even been blasted and repainted. @Vicious There you go! |
Vicious |
Vicious |
No blades is a good way to get no cooling for your heads Probably ok if you rebuild the motor every weekend Or if you have a VERY VERY LARGE duct (I dubbed it a "sewer pipe") feeding cold air directly from the headlight buckets straight through the car to the fan inlet. Quite a few 914-4 racers used to do that, to take advantage of a rule written for the LBCs (Little British Cars) that allowed cooling air to be ducted in from the headlight buckets. IIRC, the cars that ran that way would rebuild about once per season. Assuming they didn't have to spend any real time at a stop or at very low speeds. --DD |
GregAmy |
Or if you have a VERY VERY LARGE duct (I dubbed it a "sewer pipe") feeding cold air directly from the headlight buckets straight through the car to the fan inlet. I'm guessing SCCA Club racers still had some fandage going on. After all, Ginther had Porsche money, club racers do not...Chris Foley would know, I think he came up with that idea back in the 90s. His F Production race car (still for sale) has it. - GA |
Would be funnier if it were a joke. People actually sell them like this. Not to name names or anything, but an ebay search might turn up a certain business selling "lightweight racing fans" that are just normal fans with a blade or two broken off here and there. I suppose they get more money for those than if they more truthfully listed them as "partly functional fans, missing some blades". --DD |
Artfrombama |
Member ![]() ![]() Group: Members Posts: 265 Joined: 21-January 24 From: Alabama Member No.: 27,870 Region Association: South East States ![]() ![]() |
Whatever fan you source, would be wise to check #1TDC with a dial indicator to verify the notches on the fan/shroud are correct.My $.02
Vicious |
Whatever fan you source, would be wise to check #1TDC with a dial indicator to verify the notches on the fan/shroud are correct.My $.02 Looks like I'm making a deal for a very nicely restored family from cholland that has no indicator marks on it so will need to do that either way. That will require some more research. By the time this cars on the road I'm sure i will have annoyed at least half the forum with my constant questions |
Lo-Fi Version | Time is now: 31st March 2025 - 03:13 AM |
