> Cleaning Magnesium, What is the best way?
ctc911ctc
post Apr 2 2025, 03:22 PM
Hi,
I have been at it for a few weeks, using GUNK, Brake Cleaner, Electronic cleaners, scrubbing with drill driven scrubbing attachments, Dawn and then assorted other potions.
I am left with a dull stained magnesium. I know that Vapor Blast is the best way, however, I cannot lug the engine to the Blaster outfit,
Has anything worked well for you?
Thank you Teeners!
post Apr 2 2025, 03:42 PM
914-6 GT in waiting
What's your goal? No matter how clean and shiny you make mag, it's going to go grey. It's a very reactive metal so it won't stay shiny for long.
ctc911ctc
post Apr 2 2025, 04:00 PM
QUOTE(mepstein @ Apr 2 2025, 03:42 PM) *
Good guidance, thank you - I will post some pics, my goal is to get it more uniformed, it is stained in a variety of places within white/gray as well as darker stains that may be oil, etc.
More to come
post Apr 2 2025, 05:04 PM
914-6 GT in waiting
Here’s a mag trans that I’m rebuilding for myself. It looked pretty rough until I vapor blasted it (glass bead and water under pressure). It looks like aluminum until I drop it in the ultrasonic and then it turns back to grey. But I have a feeling you’re talking about a complete engine, not individual parts. Dry ice blasting might do it but the downside is when it blows a lot of debris into the nooks and crannies of the car. There’s not a lot engine showing in a 914 so maybe live with the discoloration until it’s time to overhaul the engine one day.
mgphoto
post Apr 2 2025, 05:55 PM
"If there is a mistake it will find me"
Aren’t our engines aluminum?
post Apr 2 2025, 06:03 PM
914-6 GT in waiting
QUOTE(mgphoto @ Apr 2 2025, 07:55 PM) *
I thought he was referring to a 914-6 engine but I’m just assuming…, yes, the fours are aluminum.
914sgofast2
post Apr 2 2025, 07:06 PM
The Type 4 engines in our typical 914's are all aluminum cases, with aluminum heads and cast iron cylinders. The transmissions are magnesium cases. The 914-6 has a Porsche 911 engine with aluminum heads, cast iron cylinders, and a magnesium engine case.
For a very detailed description of how to thoroughly clean a Type 4 engine case at home without any type of blasting, go to the Samba.com website and search in the VW Type 411/412 Forum for the thread on doing a 1.8 liter engine's "cheap, junk rebuild". The same info can be found on the ShopTalkForum.com website for Type 4 engines by searching for the "Cheap, Junk Rebuild" of a 1.8 liter engine by the same author.
wonkipop
post Apr 2 2025, 07:27 PM
QUOTE(mepstein @ Apr 2 2025, 06:03 PM) *
except for the fan shroud casting. i believe that is magnesium alloy.
its the one bit that is in fact very visible.
post Apr 2 2025, 07:36 PM
914-6 GT in waiting
QUOTE(wonkipop @ Apr 2 2025, 09:27 PM) *
bkrantz
post Apr 2 2025, 08:03 PM
QUOTE(wonkipop @ Apr 2 2025, 07:27 PM) *
Yup. After blasting mine I painted with clear epoxy.
bkrantz
post Apr 2 2025, 08:06 PM
Here's a photo from a year and a half later, after one (short) season on the road. The housing is a little darker but still looks silver.
wonkipop
post Apr 2 2025, 10:42 PM
QUOTE(bkrantz @ Apr 2 2025, 08:06 PM) *
neat.
much better than painting it silver like a lot of folks do.
really hits the mark appearance wise. (IMG:style_emoticons/default/beerchug.gif)
ctc911ctc
post Apr 3 2025, 09:17 AM
Here are some pics,
I cannot have it hydro blasted - pecan shells are not working, soft wire brushes seem to do the trick..
Engine condition prior to brushing
After Brushing
Cam Chain Box Prior
Cam Chain Box After
I will be brushing the fins and other smaller parts - trying not to MAR the parts but I believe that ship sailed
More to come
8 User(s) are reading this topic (4 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 3rd April 2025 - 10:26 AM
