roundtwo |
Member ![]() ![]() Group: Members Posts: 314 Joined: 9-February 20 From: Petaluma, CA Member No.: 23,905 Region Association: Central California ![]() ![]() |
Two Weber 40 IDF’s made in Spain. One other 40 IDF body. Manufacturer unknown but not newish, cheap ass ebay carb.
See all parts Note inside of carbs have some rust. EMPI intakes have some damage where they fasten to engine? Everything included. I will pack it all, you pay just shipping or… Prefer pick up in San Francisco Bay Area, petaluma. Todd.belforte@gmail.com ![]() |
roundtwo |
roundtwo |
technicalninja |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,522 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region ![]() ![]() |
I'll take those
PM incoming |
abes914 |
Member ![]() ![]() Group: Members Posts: 366 Joined: 30-March 11 From: Long Beach Member No.: 12,880 Region Association: Southern California ![]() ![]() |
Second in line just in case things changes…
roundtwo |
roundtwo |
technicalninja |
Payment sent!
(IMG:style_emoticons/default/ninja.gif) |
Ron914 |
Member ![]() ![]() Group: Members Posts: 214 Joined: 19-April 22 From: Huntington Beach,Ca Member No.: 26,487 Region Association: Southern California ![]() ![]() |
Rick , If you decide you don't want these my girlfriend's son wants them . You just barely beat me to them . Snaked by the @technicalninja again |
Ron914 |
Rick , If you decide you don't want these my girlfriend's son wants them . You just barely beat me to them . Snaked by the @technicalninja again Its not the first time the early bird missed out @bdstone914 |
technicalninja |
@Ron914
Those will need throttle shafts replaced. Rebuilding those carbs is GRAVY! Replacing the throttle shafts is NOT! The throttle shafts take massive patience. You have to dremel the butterfly screws and all of the dinged section of the shafts for removal and remove a super bitchy tiny roll pin at the accelerator pump drive flange. After installation of the new junk, you have to peen the butterfly screws so they don't come out and get ingested by the engine. You have to do this WITHOUT bending the new throttle shafts which is a PIA. Any mistakes and either your throttles stick, or they drop the screws into the open intake. Avoid carbs that require throttle shaft replacement. I've been building carbs for decades. I've MADE throttle shaft bushings before. This type of crap is not new to me. One ULTRA nice thing about these Webers is the fact that they don't use bushings, they use actual caged bearings, so the bearing/bushing alignment is not a problem, and they don't wear out like a bushing. They have no lubricant however and are more prone to rusting up. You might of "missed a bullet" here but should I decided to part ways I'll hit you up first. |
technicalninja |
For folks looking for inexpensive carbs...
The one thing you absolutely need with a 40 ID carb on a 2.0l mild engine or smaller is 27MM venturis. Pierce is my parts source. They have them. https://www.piercemanifolds.com/ But I recently ran across cheap Chinese clones on E-bay that come with 27mm out of the box. I detest Chinese parts, but other members had had good luck with them. You can purchase the Chinese carbs for less than the big rebuild kits and venturis from Pierce. This is an option... |
Ron914 |
@Ron914 Those will need throttle shafts replaced. Rebuilding those carbs is GRAVY! Replacing the throttle shafts is NOT! The throttle shafts take massive patience. You have to dremel the butterfly screws and all of the dinged section of the shafts for removal and remove a super bitchy tiny roll pin at the accelerator pump drive flange. After installation of the new junk, you have to peen the butterfly screws so they don't come out and get ingested by the engine. You have to do this WITHOUT bending the new throttle shafts which is a PIA. Any mistakes and either your throttles stick, or they drop the screws into the open intake. Avoid carbs that require throttle shaft replacement. I've been building carbs for decades. I've MADE throttle shaft bushings before. This type of crap is not new to me. One ULTRA nice thing about these Webers is the fact that they don't use bushings, they use actual caged bearings, so the bearing/bushing alignment is not a problem, and they don't wear out like a bushing. They have no lubricant however and are more prone to rusting up. You might of "missed a bullet" here but should I decided to part ways I'll hit you up first. I didn't miss a bullet ,I missed a karate chop from the technical ninja . My all most stepson wanted them ,Good price but I will relay your message .Thanks for first dibs if you change your mind. |
914werke |
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,207 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest ![]() ![]() |
Ninja if you are inclined to a offer a part or two LMK ISO of a float plate as one I was rebuilding had its post snap (IMG:style_emoticons/default/sad.gif)
technicalninja |
@914werke
Let me look at what shows up. If I understand correctly, you need the upper casting which has the mount for the float cast in. That stuff comes with an extra trash Chinese carb and if the top plate looks usable you can have that puppy for FREE! If the bodies are not savable, I will have a bunch of extra 40 IDF junk as well... |
Lo-Fi Version | Time is now: 17th April 2025 - 12:29 PM |
