sixaddict |
Senior Member ![]() ![]() ![]() Group: Members Posts: 915 Joined: 22-January 09 From: Panama City Beach, FL Member No.: 9,961 Region Association: South East States ![]() ![]() |
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() Group: Members Posts: 4,872 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
sixaddict |
Hey Bruce
Actually need 6 but I have nothing against buying a couple at a time. The distance btw mounting holes is 2.5”. Thanks I think I have a couple of them. Should be the same as are used on the 2 barrel Webers. |
Dominic |
Dominic ![]() ![]() ![]() Group: Members Posts: 993 Joined: 14-January 03 From: Vacaville, CA Member No.: 149 Region Association: Northern California ![]() |
914ltd |
Member ![]() ![]() Group: Members Posts: 243 Joined: 18-April 03 From: Peoria, IL Member No.: 581 Region Association: None ![]() ![]() |
I have 6 that are 40mm high and 40mm bore, 2.5 mount holes. They are cast. $60
for set. $12 ship. I also have 2 stainless 55mm tall with 46mm bore, chromed steel And 4, 50mm high, 37mm bore. cast $10 each Brad 914 Limited Inc. Brad Mayeur 1162 N. Byerly Hills Dr. East Peoria, IL. 61611 309-868-4667 P914LTD@yahoo.com Attached thumbnail(s) ![]() ![]() |
sixaddict |
Brad
I decided to go new…good deal but.trying to stay original. Thanks |
sixaddict |
Thinking you are right…..need to figure what the heck I have as hole spacing is
2 3/4” (about 69.85mm) quote name='Dominic' date='Apr 9 2025, 05:30 PM' post='3200424'] [quote name='sixaddict' post='3200270' date='Apr 8 2025, 06:10 PM'] Looking for a set of velocity stacks for Weber 3 barrel 40mm carbs for a six. Like this ![]() Thanks [/quote] BTW, I don't think the stacks are 40mm on the 40 IDA's, they are the same size as the 46 IDA's, I believe they are all 46mm stacks. [/quote] |
Lo-Fi Version | Time is now: 17th April 2025 - 12:22 PM |
