| burlybryan |
Apr 14 2025, 06:59 PM
Member ![]() ![]() Group: Members Posts: 139 Joined: 25-May 20 From: Saint Paul Member No.: 24,311 Region Association: None
I have a hex bar linkage and I want to install a CSP linkage. Do you think I can reuse my existing throttle cable bracket and cable? The orientation/angle appears like it should work, but wanted to check because I figure someone else has done this before.
Thanks! Bryan ![]() |
| porschetub |
Apr 14 2025, 10:03 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,957 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
I have a hex bar linkage and I want to install a CSP linkage. Do you think I can reuse my existing throttle cable bracket and cable? The orientation/angle appears like it should work, but wanted to check because I figure someone else has done this before. Thanks! Bryan ![]() Think you will be fine ? if not you could modify the one you have if the cable is too long , I used one on my last build but it was a generic Chinese copy ,replaced the crappy loose joints with CB Performance ones ,never found twin carbs SO easy to setup on a T4 . Cheers. |
| 914werke |
Apr 14 2025, 11:09 PM
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,458 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest
Itll work!
| 930cabman |
Apr 15 2025, 04:55 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,329 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States
I have several hex bar setup's on the shelf, not happy with that configuration. I fabricated a simple bell crank and have not looked back. Got some ends from Pegasus, threaded rod from the corner hardware store and some bits laying around my shop.
Bell crank for the win (IMG:style_emoticons/default/beerchug.gif) |
| Spoke |
Apr 15 2025, 06:04 AM
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,271 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None
Do you think I can reuse my existing throttle cable bracket and cable? ![]() I didn't need to reuse any hardware from my existing linkage with Tangerine's bell crank linkage. Attached image(s)
| burlybryan |
Apr 15 2025, 08:15 AM
Thanks guys. I'll give it a go. I have a spare throttle cable and could always flip the bracket if needed too.
| neyen14 |
Nov 16 2025, 04:16 PM
Member ![]() ![]() Group: Members Posts: 93 Joined: 2-December 07 From: New York Member No.: 8,408 Region Association: North East States |
Can anyone with CSP linkage to dual Weber's please post pics?... the pics on the directions they sent aren't clear.
1. It looks like the directions say to remove the idle speed screw but doesn't say put it in the front of the carb, is the set up solid enough to only need one idle speed screw? 2. I have the linkage bars to each carb in the most direct lines.... I would have to put the gas pedal in the rear targa compartment to accelerate.... Sumting wong 3. #1 and #3 plug wires in the way Attached thumbnail(s) |
| neyen14 |
Nov 16 2025, 04:39 PM
Can anyone with CSP linkage to dual Weber's please post pics?... the pics on the directions they sent aren't clear. 1. It looks like the directions say to remove the idle speed screw but doesn't say put it in the front of the carb, is the set up solid enough to only need one idle speed screw? 2. I have the linkage bars to each carb in the most direct lines.... I would have to put the gas pedal in the rear targa compartment to accelerate.... Sumting wong 3. #1 and #3 plug wires in the way Do I install the linkage bars with the carbs full open then close them?.... then install throttle cable, return spring etc? |
| mjrrti |
Nov 17 2025, 01:13 AM
High Desert Member ![]() ![]() Group: Members Posts: 53 Joined: 4-February 14 From: Apple Valley, Ca Member No.: 16,959 Region Association: Southern California |
I think you need to rotate the bell crank 180 so the cable connection is on the other side and in the middle of the case half’s. The way you have it the cable when pulled would try to close the throttle plates. Then sync the carbs at idle with linkage unhooked from bell crank using a snail gauge. Next adjust the rods so they bolt to bell crank without moving it when you drop the bolt through the bracket ends and install the nut. That should get you close and you can then re sync the carbs by fine tuning the rod length on the side without the idle screw with both jam nuts loose on the ends. I think I got mine really close that way and only had to adjust the one rod on one side maybe a half turn or less to get the carbs in perfect sync. You can adjust one rod with it idiling and hear it smooth out when they sync. Then check it at higher RPMS with a snail gauge to make sure it is good at higher RPMS. Hope that helps that is the best I can explain it. Maybe someone else will chime in with a better method.
| MedFly914 |
Nov 17 2025, 11:20 AM
Newbie ![]() Group: Members Posts: 48 Joined: 10-July 20 From: Alhambra Ca Member No.: 24,478 Region Association: Southern California |
Dual Weber 44's
| MedFly914 |
Nov 17 2025, 11:24 AM
Oops, this pic is with the 40 Dellortos.
| MedFly914 |
Nov 17 2025, 11:33 AM
| neyen14 |
Nov 17 2025, 12:15 PM
I think you need to rotate the bell crank 180 so the cable connection is on the other side and in the middle of the case half’s. The way you have it the cable when pulled would try to close the throttle plates. Then sync the carbs at idle with linkage unhooked from bell crank using a snail gauge. Next adjust the rods so they bolt to bell crank without moving it when you drop the bolt through the bracket ends and install the nut. That should get you close and you can then re sync the carbs by fine tuning the rod length on the side without the idle screw with both jam nuts loose on the ends. I think I got mine really close that way and only had to adjust the one rod on one side maybe a half turn or less to get the carbs in perfect sync. You can adjust one rod with it idiling and hear it smooth out when they sync. Then check it at higher RPMS with a snail gauge to make sure it is good at higher RPMS. Hope that helps that is the best I can explain it. Maybe someone else will chime in with a better method. Thank you this is helpful |
| neyen14 |
Nov 17 2025, 12:17 PM
Lo-Fi Version | Time is now: 17th November 2025 - 10:43 PM |
