| 914Wes |
Apr 16 2025, 10:38 AM
Newbie ![]() Group: Members Posts: 45 Joined: 9-March 22 From: SO CAL Member No.: 26,388 Region Association: Southern California |
I have most of the parts needed to build a nice 2258 (78mm stroke 96mm bore) type 4 engine. Listing these off the top of my head, may be missing a few parts from the list.
Early W/EA engine case with the reinforced area behind the jugs unused DPR German 78mm counter weight stroker crank, new German flywheel, New 5.325 Chromoly 'H' Beam Connecting Rod Set, 22mm Pin, with ARP Bolts. New Biral AA cylinders 96mm New Entended billet pushrod tubes from CSP in Germany New Bare AA 2.0 casting heads ready for machine work. Dellorto 45 carbs off a 2270 but have been sitting now and would need a rebuild. New CSP bellcrank carb linkage New gasket set, and seals. New oil cooler. 123 ignition with 3 Pin Permatune CDI box. 911 style ignition on a type 4. New Webcam 86a with lifters + cam gear and all hardware. Good used thermostat NOS KS cam and crank bearings new valve covers all the little gaskets and hardware new or nos, flywheel bolts, bearing etc. 1.7 rocker arms with 911 swivel rockers Im sure I have more I am forgetting at the moment. Can pickup from Bruce Stones shop in Riverside. Can ship as well or I can have the parts dropped off to European Motorworks and built into an engine. Will sell everything for $4000 as a black friday package. |
| 914Wes |
Nov 27 2025, 08:19 AM
Type 4 Engine Package – Complete Parts List Engine Case • Early W/EA reinforced Type 4 case .............. $550 Crankshaft / Flywheel / Rods • DPR 78mm German counterweighted stroker crank (unused) .............. $750 • New OEM German flywheel ....................................................... $300 • 5.325" Chromoly H-beam rod set w/ ARP bolts ........................ $280 Cylinders / Heads / Valve Train • AA Biral 96mm cylinders (new) ............................................... $450 • AA 2.0 bare casting heads (pair, new) .................................... $650 • CSP extended billet pushrod tubes .......................................... $260 • 1.7 rocker arms w/ new 911 swivel adjusters ............................. $220 Induction • Dellorto 45 DRLA carbs (used, need rebuild) ............................. $800 • CSP bellcrank carb linkage .................................................... $190 Ignition • 123 Distributor (used) ............................................................... $300 • Permatune 3-pin CDI (new) ....................................... $600 • Total ignition value ............................................................. $900 Camshaft & Internal • Webcam 86A cam kit (cam, lifters, gear, hardware) .................. $750 • NOS KS cam bearings ................................................................ $120 • NOS KS crank bearings .............................................................. $120 Cooling & Misc • New oil cooler ......................................................................... $90 • New gasket & seal set ................................................................ $75 • Good used thermostat .............................................................. $100 • New valve covers .................................................................... $50 • Hardware, flywheel bolts, misc fasteners ................................. $60 [HR] Total Value: $7,225 |
| IronHillRestorations |
Nov 27 2025, 09:53 AM
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,896 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None
This is a great deal! GLWTS Wes!
| cgnj |
Dec 2 2025, 11:49 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 697 Joined: 6-March 03 From: Medford, NJ Member No.: 403 Region Association: None
Wes,
PM'ed my contact info. Regards, Carlos |
| 914Wes |
Dec 3 2025, 12:00 PM
Pending
| TRP |
Dec 3 2025, 04:02 PM
Member ![]() ![]() Group: Members Posts: 136 Joined: 2-September 23 From: Morgan Hill, CA Member No.: 27,559 Region Association: None
Dang! Well, it's a blessing I guess. The temptation to completely bypass building a 2056 and going straight to 2.3 was reallllly strong with this one!
Lo-Fi Version | Time is now: 4th December 2025 - 03:03 AM |
