Root_Werks |
Village Idiot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,653 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest ![]() ![]() |
Looking for a set of Pedrini rims for my Bug. Since I have factory front disc brakes, I believe I need the late hub-centric style.
Willing to pay for a set that are already restored or a set that need refinishing. Don't want anything that needs repair work. Currently running aftermarket BRM's and while okay, they don't have the quality of factory wheels. -Dan Attached thumbnail(s) ![]() |
JOEPROPER |
The answer is "no" unless you ask... ![]() ![]() ![]() Group: Members Posts: 1,198 Joined: 21-November 15 From: White Plains New York Member No.: 19,387 Region Association: North East States ![]() ![]() |
Is there a date code that I should look for? I have a set, maybe 5. I'll check.
Root_Werks |
@914ltd had a early set for sale here, the part number was 914.361.013.00. I don't know what a late part number would be?
Thanks for checking! -Dan |
914sgofast2 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 712 Joined: 10-May 13 From: El Dorado Hills, CA Member No.: 15,855 Region Association: None ![]() |
There is a month and year date code stamped on the rear of the Pedrini wheels showing their time of manufacture. On my car the Pedrini wheels are stamped 11/70. It is very faint and difficult to see. The stamping was done between the mounting holes on the flat surface which bolts against the hub. As a result, the date code can't be read unless the wheel is removed from the car. Unfortunately, I don't know when the change in the hub centric design was made. However, try Jeff Bowlsby's website because he probably has the info you are looking for on his site somewhere. (Bowlsby.com)
914xr75 |
Member ![]() ![]() Group: Members Posts: 184 Joined: 24-March 18 From: Whittier, CA Member No.: 21,996 Region Association: Southern California ![]() |
Freezin 914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 926 Joined: 27-July 14 From: Wisconsin Member No.: 17,687 Region Association: Upper MidWest ![]() ![]() |
Late ones end with 01.
Root_Werks |
Lo-Fi Version | Time is now: 25th April 2025 - 07:39 PM |
