> Interference with shift rod, Interference with shift rod
914racer
post May 22 2025, 02:19 PM
I converted a 4 to 6 in a 71. I also have a short shifter and the necessary spacer installed. The shift rod in the tunnel is scraping a gusset and causing a loud squeaking when put in reverse or 1st and slightly less squeak sound going into 4th and 5th. I have a video taken in the tunnel showing how it's interfering with the shift rod. Has anyone else had this issue and have a solution other than drilling a hole with a hole saw on the top of the tunnel and grinding some of the gusset for clearance? Thanks
brant
post May 22 2025, 03:00 PM
we all had to bend the shift rod.
Edit
Re read
Inside the tunnel is likely the seatbelt anchor
post May 22 2025, 03:23 PM
914-6 GT in waiting
Most common problem is a too long seatbelt bolt that interferes with the rod.
Montreal914
post May 23 2025, 08:44 AM
The tail shifter tunnel rod was suported by the rear and front bushing. In its function the rod was rotating on its axis and sliding back and forth (no lateral movement).
The side shiter tunnel rod actually moves left and right at the shifter and pivots in the rear bushing (like a spherical bushing). To allow this left and right motion, the tunnel partial bulkhead through which the rod goes through was enlarged in 73 to allow its lateral movement. Unfortunately, it is very difficult to access that bulkhead to elarge it on the 70-72 cars.
I guess the rod bending trick is the easiest solution. (IMG:style_emoticons/default/smile.gif)
rudedude
post May 23 2025, 09:56 AM
All I had to do was loosen the shifter base and move it a tiny bit. It is probably rubbing on a sheet metal support in the tunnel.
ChrisFoley
post May 23 2025, 12:55 PM
I am Tangerine Racing
If I'm not mistaken, the short shifter kit exacerbates the rubbing issue. The spacer is smaller than the length added to the shift lever, which means the rod still sits lower in the tunnel at the front, compared with the stock shifter. Not only that, the distance that the coupler swings left and right is increased by the short shift increased lever arm.
3 User(s) are reading this topic (1 Guests and 0 Anonymous Users)
2 Members: porschetub, dcecc1968
- Lo-Fi Version Time is now: 23rd May 2025 - 01:57 PM
