> 5 Lug Conversion - Rear Rotors, Which Rear Rotor?
914sgofast2
post Jun 28 2025, 03:10 PM
I am collecting parts to do a five (5) lug conversion on my 1970 Porsche 914-4. I have a set of rear hubs which have had the five new studs installed, and I am wondering what rear rotors to use.
Can I just buy a pair of rear rotors for a 914-6 and use them with my existing rear brake calipers? Or do I need to get my existing 4 lug rear rotors drilled to fit over the five lug rear hubs?
I am trying to avoid having to replace my existing rear calipers (from a 4 cylinder car) with a set of calipers from a 914-6.
Thanks. I know a lot of people have done this conversion so they can run the Porsche 911 style Fuchs wheels, which is what I am planning on doing. My car is an early build, having been built in December 1969, if that makes any difference.
Puebloswatcop
post Jun 28 2025, 03:17 PM
QUOTE(914sgofast2 @ Jun 28 2025, 04:10 PM) *
You can find a machine shop to convert the ones you have or if want new ones PMB sells them already drilled.
Dave_Darling
post Jun 28 2025, 05:45 PM
914 Idiot
Both options will work.
The Six rear rotors may rub a little on the caliper bridge as they seem to be very very slightly larger in diameter than the four ones. (Or were last I looked into this. Been quite a while.) Sometimes there's no rub, and often loosening the caliper mount bolts and pushing outward on the caliper body while tightening the bolts has worked for others.
--DD
nditiz1
post Jun 28 2025, 06:03 PM
I purchased these from autohausaz
Sebro Coated Disc Brake Rotor; Rear
P/N: S9-90135240118
2x$87.99
No rub on my calipers.
914sgofast2
post Jun 30 2025, 01:44 PM
Thanks to everyone for responding with my options for doing the rear 5 lug conversion.
- Lo-Fi Version Time is now: 1st July 2025 - 05:09 AM
